Tony hawk goes vice city?
  • 112 views sinds 30-01-2008
  • Walkman
Van gamesradar :
Activision have revealed the first ever details of the next Tony Hawk game - and it's not part of the Pro Skater series.
Following both the commercial and critical success of the four titles in the Tony Hawk's Pro Skater series, the Hawkmeister will next pop up in a game called Tony Hawk's Underground.
Developers Neversoft managed to make each successive Pro Skater title a significant leap forward from its predecessor but, having taken that series as far as they can, they are now developing a grittier, more story-driven skating title.
Underground sees you having to work your way up the ranks from novice to pro with the ongoing narrative being pieced together via cut-scenes. Crucially though, you'll actually be able to step off your skateboard, which will add an almost action-adventure element to proceedings. In the trailer of the game we saw at E3, skaters were not only able to run around areas that they wouldn't be able to skate on, but they could even clamber up drainpipes, along ledges and across roofs in order to reach otherwise inaccessible areas too. At one point, you even steal and drive a car, so clearly the whole game world is significantly more interactive than that of the Pro Skater series.
There's also a whole new level of flexibility on the creative side of things. A sophisticated create-a-character tool will enable you to download your own face texture and play as yourself. You then get to choose a genuine skateboarder to skate with (expect many of the usual Pro Skater suspects to make an appearance).
You will also be able to create your own skate-parks (expect a much wider array of environments than in the Pro Skater create modes), tricks and goals (for instance, where icons that you need to collect are placed). It's even possible to adjust the time of day you skate at, which obviously has a dramatic impact on the lighting. You'll also have a much wider range of areas to 'board your way through, including the inside of buildings (we saw one character skating through a strip club - nice).
Tony Hawk's Underground is released for PS2, Xbox and Gamecube in the autumn and, if it lives up to its early promise, this one will be a scorcher.
Het wordt wel heel interactief, maar auto's rijden in een skate game? Klimmen....ik weet zo net nog niet of dit nou wel interessant gaat worden...
  • Vanitas
  • Laatst online: 27-04 17:28
Dit lijkt me dus wel leuk.
Hopelijk werken ze het een beetjhe goed uit zodat het ook nog goed te spelen is.
Het is alleen wel een beetje GTA inderdaad, behalve de wapens dan.
Even though I walk through the valley of the shadow of death. I will fear no evil.
  • NoTimeRemains
  • Laatst online: 22:01
NoTimeRemains
I know
Koel concept maar wordt het dan niet TE zeg maar?
This is the Way.
_/-\o_
maar dat adventure element zitten ze al mee te pielen sinds deel III :/, naja in herfst alweer... en nog geen screenshots? :? en geen pc versie? hopelijk komt O2 snel met meer info :D
Lijkt me toch een achteruitgang.
De beste uit de serie is nog steeds 2 als je het mij vraagt, simpel skaten. Goals die ook nog met skaten te maken hebben, kickflip die gap, ollie over dat ding, grinden van die rail.
In 3 gingen ze al "rare" goals erin doen. "Zet die machine aan door over de rand een FS 50-50 grind te doen".. En nu in 4 "Jaag de vogels weg door een lip trick te doen in hun buurt".
Tony Hawk moet weer een skategame worden, waarin je gewoon relaxed kunt rondrijden als in vier, en waar je goals ook alleen skaten zijn.
  • 4Real
  • Laatst online: 14-09-2024
lijkt me wel grappig concept :)
vast het idee van Bam Margera :P Climb up drains & skate of the roof
Jackass / cKy for ever!! :D
  • Neejoh
  • Laatst online: 14-10 09:47
Hmm, ik vind het eigelijk wel een heel goed idee. Ik vond het soms namelijk enorm irrie dat je niet van je board af kon stappen, en ff snel een trapje op kon klimmen. En je kan gewoon niet aan blijven modderen door wéér eenzelfde game te produceren. 2 was goed, maar 3 was meer van hetzelfde. IMO daardoor ook de slechtste uit de serie. In 4 zag je dat ze een andere weg in wilden slaan, en dat hebben ze IMO goed gedaan. Dat is tenminste een stap vooruit!
Ook dit idee bevalt mij goed.
  • Neejoh
Ok, als je het allemaal nog niet helemaal duidelijk is, kijk deze 2 filmpjes even achter elkaar :)
Deel 1
Deel 2
Je kan dus ook je eigen Tricks maken enzo :) Je eigen SuperSpecials :D
  • Walkman
Wow, ziet er goed uit....volgens mij worden die levels echt supergroot (dus echt richting vice city), denk toch wel dat ik dat spel een kans ga geven...alleen dat zelf trucjes maken hoeft van mij niet zo...
[ Voor 35% gewijzigd door Walkman op 17-05-2003 20:41 ]
  • corné
  • Laatst online: 14-11-2024
oewww ik kan nu al niet meer wachten :D
geen pc :(
ze moeten er een keer mee ophouden :(
