[perl] Net::DHCPClient
  • 174 views sinds 30-01-2008
iemand die de leste stable versie van Net::DHCPClient heeft draaien?
geeft errors hier.
mebbe ni compat me perl 5.6 ?
of Raw::IP compat prob ?
Dan draai je toch even cpan en installeer je een andere versie?
  • tomato
Hoe compact kun je een topic openen zeg... lees je verhaal nog eens door :z
En wat gaat er mis?
root@hekate:/home/cnf/Devel/Projects/DhcpdNuke% ./clear.pl
"my" variable %options masks earlier declaration in same scope at /usr/local/share/perl/5.8.0/Net/DHCPClient.pm line 273.
Use of uninitialized value in split at /usr/local/share/perl/5.8.0/Net/DHCPClient.pm line 371.
Use of uninitialized value in pattern match (m//) at /usr/lib/perl5/Net/RawIP.pm line 254.
Use of uninitialized value in pattern match (m//) at /usr/lib/perl5/Net/RawIP.pm line 270.
Use of uninitialized value in subroutine entry at /usr/lib/perl5/Net/RawIP.pm line 270.
host_to_ip: failed at /usr/lib/perl5/Net/RawIP.pm line 270.
to be exact
This is perl, v5.8.0 built for hppa-linux-thread-multi
cpan> i Net::RawIP CPAN: Storable loaded ok
Going to read /root/.cpan/Metadata
Database was generated on Thu, 15 May 2003 07:16:56 GMT
Strange distribution name [Net::RawIP]
Module id = Net::RawIP
CPAN_USERID SKOLYCHEV (Sergey V. Kolychev <ksv@al.lg.ua>)
CPAN_VERSION 0.1
CPAN_FILE S/SK/SKOLYCHEV/Net-RawIP-0.1.tar.gz
MANPAGE Net::RawIP - Perl extension for manipulate raw ip packets with interface to B<libpcap>
INST_FILE /usr/lib/perl5/Net/RawIP.pm
INST_VERSION 0.1
cpan> i Net::DHCPClient Strange distribution name [Net::DHCPClient]
Module id = Net::DHCPClient
DESCRIPTION Interface to DHCP as a client
CPAN_USERID JWALGENB (Josh Walgenbach <jwalgenb@indiana.edu>)
CPAN_VERSION 1.0
CPAN_FILE J/JW/JWALGENB/Net-DHCPClient-1.0.tar.gz
DSLI_STATUS bdpO (beta,developer,perl,object-oriented)
MANPAGE Net::DHCPClient - A DHCP Client API
INST_FILE /usr/local/share/perl/5.8.0/Net/DHCPClient.pm
INST_VERSION 1.0
Perl 5.6.x en 5.8.x zijn niet volledig compatible als ik me niet vergis. Zo te zien heeft Dhcpdnuke dan ook een lagere versie dan 5.8.x nodig.
tipje: Maak a.u.b. de volgende keer je posts wat duidelijker ;) Jij bent de persoon die geholpen wordt en op deze manier lukt dat dus niet echt :)
op perl 5.6 krijg ik exact de zelfde fout melding
  • dusty
  • Laatst online: 21-02 00:06
dusty
Celebrate Life!
Zie onze FAQ over het juist openen van topics, dan weet je ook meteen waarom deze gesloten is.
Back In Black!
"Je moet haar alleen aan de ketting leggen" - MueR
