Nieuwe BETA Bios FIX voor NF7(-S) SATA probleem beschikbaar
  • 48 views sinds 30-01-2008
Er zijn alweer nieuwe BETA BIOS UPDATE beschikbaar :
Beta BIOS release 14 beta 1 for NF7-S/NF7 v2.0
http://fae.abit.com.tw/download/beta/nf7/v2.0/nf7d14b1.zip
Release information:
0. Please use AWDFLASH 8.23D or later to update NF7 series BIOS. With
incorrect AWDFLASH version, the GUID will be erased, and leads to
IEEE1394 peer to peer function failed. AWDFLASH 8.23K is included in
this BIOS package.
1. Fixed CPU temperature too high issue.
2. Raised highest CPU FSB up to 300 MHz for "user define mode" in
SoftMenu.
3. Fixed SATA RAID-0 data corruption issue by adding a new option
"EXT-P2P's Discard Time" in "integrated Peripherals". The default
setting is "30 us" ; which is recommended by NVidia. In case the problem
is still there, try "1 ms" please.
4. Changed DDR400 DRAM timing according to NVidia's recommendation.
5. Updated BPL to v3.01 according to NVidia's recommendation.
6. BIOS Compile Date: 5/14/2003.
Beta BIOS release 19 beta 0 for NF7/NF7-S v1.0/1.1/1.2
NF7-M v1.2
http://fae.abit.com.tw/download/beta/nf7/v1.x/nf719b0.zip
this BIOS package.
SoftMenu.
setting is "3.8 us". Please change it to "30 us"; which is recommended
by NVidia. In case the problem is still there, try "1 ms" please.
4. BIOS Compile Date: 5/13/2003.
Dus Lekker Updaten.
  • martijn12345
  • Laatst online: 26-04 21:07
martijn12345
Geen inspiratie
Waarom een nieuw topic openen, en niet gewoon in het grote NF7 topic posten :?
Geen inspiratie
  • BalusC
BalusC
Carpe diem
Dank je voor de mededeling :)
/overbodig
Je had dit beter kunnen posten in tweakers.net/meuktracker of gewoon in Het grote Abit NF7 S Topic B)
