Quote uit de EULA van Office.
Limitations on Reverse Engineering, Decompilation, and Disassembly. You may not reverse engineer, decompile, or disassemble the Software, except and only to the extent that such activity is expressly permitted by applicable law notwithstanding this limitation.
INTELLECTUAL PROPERTY RIGHTS. All title and intellectual property rights in and to the Software (including but not limited to any images, photographs, animations, video, audio, music, text, and "applets" incorporated into the Software), the accompanying printed materials, and any copies of the Software are owned by Licensor or its suppliers. All title and intellectual property rights in and to the content that is not contained in the Software, but may be accessed through use of the Software, is the property of the respective content owners and may be protected by applicable copyright or other intellectual property laws and treaties. This EULA grants You no rights to use such content. If this Software contains documentation that is provided only in electronic form, you may print one copy of such electronic documentation. You may not copy the printed materials accompanying the Software. All rights not specifically granted under this EULA are reserved by Licensor and its suppliers.
Dit is dus met recht een warez verzoek.
Voor 59% gewijzigd door
Luppie op 13-05-2003 13:31
Heb je iets aan mijn antwoord ? Een thumbs-up wordt zeker op prijs gesteld.
