Flushen naar jullie proxy
  • 129 views sinds 30-01-2008
  • Tallguy
Tallguy
There is no place like 127.0.0
Ik probeer te flushen naar Wildhagen of Dsmarty's proxy, maar dit lukt niet.
Kunnen jullie de goede gegevens doorgeven a.u.b. ??
Heb poorten 2064 en 80 geprobeerd, maar krijg dit terug:[07/31/00 09:32:49] rc564 r=4607/0, d=3201/0, 12.6 Mkeys/sec, tot=33
[07/31/00 09:32:49] desII r=0/50, d=0/20, 0.0 Mkeys/sec, tot=0
[07/31/00 09:32:49] ogr r=0/50, d=0/20, 0.0 Mnodes/sec, tot=0
[07/31/00 09:32:49] csc r=0/50, d=0/20, 0.0 Mkeys/sec, tot=0
[07/31/00 09:32:49] Status: Uptime: 0.00:11:44, 2 listeners, 1 uplink
[07/31/00 09:32:49] Status: 0 active clients (peak: 0, mean: 0.00)
[07/31/00 09:33:05] rc564 r=4607/0, d=3201/0, 12.3 Mkeys/sec, tot=33
[07/31/00 09:33:05] desII r=0/50, d=0/20, 0.0 Mkeys/sec, tot=0
[07/31/00 09:33:05] ogr r=0/50, d=0/20, 0.0 Mnodes/sec, tot=0
[07/31/00 09:33:05] csc r=0/50, d=0/20, 0.0 Mkeys/sec, tot=0
[07/31/00 09:33:05] Status: Uptime: 0.00:12:00, 2 listeners, 1 uplink
[07/31/00 09:33:05] Status: 0 active clients (peak: 0, mean: 0.00)
[07/31/00 09:33:18] Uplink: Packet from 212.187.18.145 failed validation.
[07/31/00 09:33:18] Uplink: [1] connection to 212.187.18.145 changed state
from 0 (ESTNONE) to 1 (ESTCONNWAIT)
from 1 (ESTCONNWAIT) to 50 (ESTREADY)
[07/31/00 09:33:21] rc564 r=4607/0, d=3201/0, 12.0 Mkeys/sec, tot=33
[07/31/00 09:33:21] desII r=0/50, d=0/20, 0.0 Mkeys/sec, tot=0
[07/31/00 09:33:21] ogr r=0/50, d=0/20, 0.0 Mnodes/sec, tot=0
[07/31/00 09:33:21] csc r=0/50, d=0/20, 0.0 Mkeys/sec, tot=0
[07/31/00 09:33:21] Status: Uptime: 0.00:12:16, 2 listeners, 1 uplink
[07/31/00 09:33:21] Status: 0 active clients (peak: 0, mean: 0.00)
specs | 3360wP met SE3000
  • wildhagen
wildhagen
Blablabla
Zou je je proxyper.ini ff willen pasten ? Ik heb wel een vermoeden, maar wìl het ff zeker weten.
Virussen? Scan ze hier!
Ehh die van wildhagen zit toch niet op dat ip ? van dsmarty weet ik het niet.
Address: 212.187.18.145
  • Tallguy
Tallguy
Dit is zoals ik 'm voor Dsmarty heb staan:
[KeyServer]
ipaddress=proxy.dsmarty.com
port=80
connectperiod=30
connectivity=normal
;bindip= ; IP to talk out to keyserver from
uuehttpmode=2
; 0=normal,1=uue,2=http,3=http+uue
; 4=socks4,5=socks5,6=genproxy,7=genproxy+uue
httpproxy=10.1.1.15
httpport=80
;httpid=
[ports]
;listenaddress= ; IP to accept clients on
port=2064
;port2=23 ; must be root for ports < 1000
;port3=80
testport=3064
timeout=30
[console]
logfileconsole=
logfileconsolerotation=weekly
consoleverbosity="general stats keyblock server client buffers timestamp attention errlow errsevere"
timestampflags=129
[rc564]
logfilekeyblock=pproxyrc5
logfilekeyblockrotation=daily
expertmode=1
minkeysready=0
minkeysdone=0
maxkeysready=0
maxkeysdone=0
[misc]
proxymessage="Tai-Pan Personal Proxy!"
pidfile=rc5desproxy.pid
statusperiod=15
;logfilecompressor=logcompressor.sh
[ignoredip]
[allowedip]
[desII]
contestclosed=1
[ogr]
contestclosed=1
[csc]
contestclosed=1
Poort 2064 proberen hielp niet echt.
  • wildhagen
wildhagen
Blablabla
ik was er al een beetje bang voor...
probeer eens dit :
minkeysready=1
minkeysdone=0
maxkeysready=2
maxkeysdone=1
Dit zou iig moeten werken !
  • DSmarty
Dat zou idd het probleem kunnen zijn!
:) grin helemaal niets vragen dat is ook een manier. Nouja ik zwijg maar want ik zit gewoon 3 dagen met een oude client te ogr'n ;)
  • Tallguy
Tallguy
Negatief resultaat :'(
Zit wel firewall tussen met proxy, maar perproxy deed het wel gewoon naar dnet USA.
Nog andere ideëen?
als ik ping naar 213.46.82.39 of naar keyproxy.tcw.cx krijg ik ook time-out meldingen.
  • Chaos
Tsja, kwello is weer lekker bezig de laatste paar dagen...
  • Tallguy
Tallguy
Ping doet het nu af en toe wel, perproxy zegt dat ie de handshake aan het doen is, maar verder nog geen flush mogelijk.
  • Chaos
Er zijn op dit moment wel mensen aan het flushen, dus het probleem ligt iig niet bij mij. Kwello dondert nu iedere 10 minuten een andere router eruit, zal daar dus wel door komen...
  • Tallguy
Tallguy
Hmmm...het schijnt niet uit te maken welke proxy ik ook gebruik,, ding wil niet flushen, alleen maar naar dnet USA zelf en da's niet de bedoeling.
Krijg wel reply's op mijn ping, maar daar blijft 't bij. Heb 5700 blokkies voor jullie! ;)
  • 4of9
  • Laatst online: 15-04 15:52
laat maar :(
had niet goed gelezen
Aspirant Got Pappa Lid | De toekomst is niet meer wat het geweest is...
Ik heb niets verabderd ik flush altijd naar dnet ben blij dat ik eindenlijk mijn stats kunt zien ;)
  • DSmarty
Ik zie al wel dat je flushed op poort 80, en die poort staat niet open bij mij!
proxy.dsmarty.com is bereikbaar op poorten 21, 25 & 2064
(aka "maandflush.keyserver.org")
  • Tallguy
Tallguy
Dsmarty,
Wellicht dat je over het hoofd hebt gezien had ik gezegd dat ik poort 2064 ook al had geprobeerd. Eigenlijk alle poorten die jullie ooit hebben doorgegeven op het forum.
Heb gisteren maar laptop via ISDN naar Wildhagen laten verwijzen en 10000 blokkies opgehaald. Dan maar zo.
PS Heb gisteren wel 3 xtra koetjes in farm hangen ;)
  • DSmarty
Mocht het echt absoluut niet lukken, dan wil ik je wel helpen via Email, gewoon buffers toezenden die jij klaar hebt (die kan ik dan lokaal flushen) en nieuwe buffers toemailen.
Suc6... DSmarty
