samba en anoniem aanloggen
  • bokkie11
  • Laatst online: 25-08 19:21
hoi
ik heb hier mandrake 9.0 draaien met samba
alles werkt perfect alleen ik moet elke keer inloggen als ik op de shares wil komen
hier is me smb.conf
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not made any basic syntactic errors.
#======================= Global Settings =====================================
[global]
 log file = /var/log/samba/log.%m
 smb passwd file = /etc/samba/smbpasswd
 load printers = yes
 socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
 domain master = yes
 encrypt passwords = yes
 public = yes
 dns proxy = no
 netbios name = webserver
 writeable = yes
 print command = lpr-cups -P %p -o raw %s -r   # using client side printer drivers.
 server string = Samba Server %v
 printing = cups
 default = data
 local master = yes
 workgroup = prog_domain
 os level = 34
 auto services = global
 printcap name = lpstat
 security = user
 max log size = 50
[data]
 comment = Public Stuff
 writable = yes
 public = yes
 path = /var/www/html/data
 guest ok = Yes
[datasource]
 writable = yes
 public = yes
 guest ok = Yes
ik dacht dat als je bij public yes in vult dat dan zonder naam en wachtwoord kan maar dat werkt niet
[ Voor 4% gewijzigd door bokkie11 op 12-05-2003 12:10 ]
M3 SR+ deep bleuMidnight grey/ Black /areo Bestel 19/8 restrictie 1/11 vin 11-12 aflevering 14-12
  • Puntslash
Na mijn weten moet je in de [global] pcguest aangeven.. exact weet ik het niet..
  • JeroenT
  • Laatst online: 30-08 04:27
JeroenT
hoi!
Security op share zetten..
Stukje van mijn smb.conf
[global]
        password level = 1
        hide dot files = yes
        domain master = yes
        browseable = yes
        preserve case = yes
        security = share
        local master = yes
        workgroup = HOME
        server string = Gateway
        socket options = TCP_NODELAY IPTOS_LOWDELAY IPTOS_THROUGHPUT
        netbios name = Server
        short preserve case = yes
        os level = 90
        wins support = true
        default = global
        case sensitive = no
        max log size = 1024
[ Voor 93% gewijzigd door JeroenT op 12-05-2003 12:25 ]
