Maxtor D740X 7200rpm scoort ver onder de maat.
In sisoft sandra haalt mijn schijf 18804 Kb/s terwijl een vergelijkbare schijf 29810 haalt!
Dit is mijn score :
SiSoftware Sandra
Test Status
SMP Test : No
Total Test Threads : 1
SMT Test : No
Dynamic MP/MT Load Balance : No
Processor Affinity : No
Windows Disk Cache Used : No
Use Overlapped I/O : Yes
Command Queue Depth : 4 command(s)
Test File Size : 255MB
File Server Optimised : No
Benchmark Breakdown
Buffered Read : 36 MB/s
Sequential Read : 28 MB/s
Random Read : 5 MB/s
Buffered Write : 30 MB/s
Sequential Write : 21 MB/s
Random Write : 6 MB/s
Average Access Time : 10 ms (estimated)
Drive
Drive Class : Fixed
Total Space : 55.9GB
Free Space : 18.9GB, 34%
Performance Tips
Notice 5008 : To change benchmarks, click Options.
Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.
Notice 5006 : Only compare the results with ones obtained using the same version!
Tip 5202 : Use cache on to measure Windows performance.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
In de cpu/geheugen test scoort mijn sys beter als vergelijkbare systemen volgens sisoft.
bij DMA settings enzo:
SiSoftware Sandra
General Capabilities
Channel : Master
Type : ATA
Removable Device : No
Model : MAXTOR 6L060J3
Revision : A93.0500
Serial Number : 663205618518
ATA/ATAPI Approved Version : 5.21
Cache Buffer Type : Multi-Sector with Read Cache
Cache Buffer Size : 1819kB (3639 sectors)
Drive Geometry
Unformatted Bytes Per Sector : 21298
Unformatted Bytes Per Track : 32256
CHS Geometry : 16383 x 16 x 63
CHS Total Sectors : 16514064
LBA Total Sectors : 117266688
Number of ECC Bytes : 4
Disk Capacity : 55.9GB
Translation Mode Geometry
CHS Geometry : 4047 x 16 x 255
CHS Total Sectors : 16511760
Properties
IORDY Support : Yes
IORDY Disableable : Yes
LBA Support : Yes
DMA Support : Yes
Features
SMART Support : Yes
Security Support : Yes
Power Management Support : Yes
Advanced Power Management Support : No
Power-up in Standby : No
Packet Command Interface : No
Removable Media : No
Look-Ahead Buffer : Yes
Write-Back Cache : Yes
Host Protect Area : Yes
Microcode Update : Yes
Acoustic Management : Yes
48-bit LBA : No
Device Config Overlay : Yes
Active Features
SMART Enabled : No
Security Enabled : No
Power Management Enabled : Yes
Look-Ahead Buffer Enabled : Yes
Write-Back Cache Enabled : Yes
Host Protect Area Enabled : Yes
Acoustic Management Enabled : Yes
Transfer Modes Support
Maximum Block Transfer : 16
Transfer Width : 16-bit
Max PIO Mode : PIO-4
Max DMA MW Mode : MWDMA-2
Max UDMA Mode : UDMA-6
Transfer Modes Active
Current Block Transfer : 16
Current Active Mode : UDMA-6
Performance Tips
Warning 3100 : SMART not enabled; consider enabling for safety.
Warning 3103 : Acoustic Management enabled. Peformance may be impaired.
Acoustic management?! Dat heb ik niet aangezet, hoe doe ik het uit? en al staat het een 10 Mb/s lijkt me erg veel performance loss.
Weet iemand wat het probleem kan zijn?
[edit] het moet natuurlijk ver en RPM zijn zZzZz }:O
  • epias
Met AMSET kun je het acoustic management van de drive veranderen. Heb je al een andere kabel geprobeerd...
  • BalusC
BalusC
Carpe diem
Al in de FAQ gekeken voor tips/suggesties in dit soort gevallen .. :?
Mijn IDE configuratie werkt niet lekker, hoe komt dat? B)
Edit: ik heb de titel fixed .. "7200RTM" sloeg bij nader inzien toch nergens op :+
[ Voor 19% gewijzigd door BalusC op 11-05-2003 09:10 ]
