29
30
31
32
33
34
35
36
37
38
39
40
| /home/mark/webserver/config/run-mrtg > /home/mark/webserver/config/run-mrtg.log
SNMP Error:
Received SNMP response with error code
error status: noSuchName
index 1 (OID: 1.3.6.1.2.1.2.2.1.10.19216811)
SNMPv1_Session (remote host: "192.168.1.1" [192.168.1.1].161)
community: "public"
request ID: 1238316366
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at /usr/local/lib/perl5/site_perl/5.6.1/SNMP_util.pm line 458
SNMPGET Problem for ifInOctets.19216811 ifOutOctets.19216811 sysUptime sysName on public@192.168.1.1:
at /usr/local/bin/mrtg line 1620
WARNING: skipping because at least the query for ifInOctets.19216811 on 192.168.1.1 did not succeed
SNMP Error:
index 1 (OID: 1.3.6.1.2.1.2.2.1.10.1000150)
SNMPv1_Session (remote host: "10.0.0.150" [10.0.0.150].161)
community: "public"
request ID: -137495079
timeout: 2s
retries: 5
backoff: 1)
SNMPGET Problem for ifInOctets.1000150 ifOutOctets.1000150 sysUptime sysName on public@10.0.0.150:
WARNING: skipping because at least the query for ifInOctets.1000150 on 10.0.0.150 did not succeed
ERROR: Target[192.168.1.1][_IN_] ' $$target[0]{$mode} ' did not eval into defined data
ERROR: Target[192.168.1.1][_OUT_] ' $$target[0]{$mode} ' did not eval into defined data
WARNING: Skipping Update of 192.168.1.1, inlast is not defined
WARNING: Skipping Update of 192.168.1.1, outlast is not defined
ERROR: Target[10.0.0.150][_IN_] ' $$target[1]{$mode} ' did not eval into defined data
ERROR: Target[10.0.0.150][_OUT_] ' $$target[1]{$mode} ' did not eval into defined data
WARNING: Skipping Update of 10.0.0.150, inlast is not defined
WARNING: Skipping Update of 10.0.0.150, outlast is not defined
-bash-2.05b$ |
hierbij dan ook maar mijn config file:
29
30
31
32
33
34
35
36
37
38
39
| ###################################################################### ### Interface 1 >> Descr: 'fxp0' | Name: '' | Ip: '192.168.1.1' | Eth: '' ### Target[192.168.1.1]: 19216811:public@192.168.1.1: SetEnv[192.168.1.1]: MRTG_INT_IP="192.168.1.1" MRTG_INT_DESCR="fxp0" MaxBytes[192.168.1.1]: 12500000 Title[192.168.1.1]: Traffic Analysis for 192.168.1.1 -- kim.digipoint.org PageTop[192.168.1.1]: <H1>Traffic Analysis for 192.168.1.1 -- kim.digipoint.org</H1> <TABLE> <TR><TD>System:</TD> <TD>kim.digipoint.org in Unknown</TD></TR> <TR><TD>Maintainer:</TD> <TD>mrtg@digipoint.org</TD></TR> <TR><TD>Description:</TD><TD>fxp0 </TD></TR> <TR><TD>ifType:</TD> <TD>ethernetCsmacd (6)</TD></TR> <TR><TD>ifName:</TD> <TD></TD></TR> <TR><TD>Max Speed:</TD> <TD>12.5 MBytes/s</TD></TR> <TR><TD>Ip:</TD> <TD>192.168.1.1 (kim.digipoint.org)</TD></TR> </TABLE> ### Interface 3 >> Descr: 'xl0' | Name: '' | Ip: '10.0.0.150' | Eth: '' ### Target[10.0.0.150]: 1000150:public@10.0.0.150: SetEnv[10.0.0.150]: MRTG_INT_IP="10.0.0.150" MRTG_INT_DESCR="xl0" MaxBytes[10.0.0.150]: 1250000 Title[10.0.0.150]: Traffic Analysis for 10.0.0.150 -- kim.digipoint.org PageTop[10.0.0.150]: <H1>Traffic Analysis for 10.0.0.150 -- kim.digipoint.org</H1> <TABLE> <TR><TD>System:</TD> <TD>kim.digipoint.org in Unknown</TD></TR> <TR><TD>Maintainer:</TD> <TD>root@digipoint.org</TD></TR> <TR><TD>Description:</TD><TD>xl0 </TD></TR> <TR><TD>ifType:</TD> <TD>ethernetCsmacd (6)</TD></TR> <TR><TD>ifName:</TD> <TD></TD></TR> <TR><TD>Max Speed:</TD> <TD>1250.0 kBytes/s</TD></TR> <TR><TD>Ip:</TD> <TD>10.0.0.150 (kim.digipoint.org)</TD></TR> </TABLE> workdir: /home/mark/webserver/default/mrtg/ |
Uit deze config file heb ik een paar interfaces (3) verwijders omdat deze toch helemaal uit ge #'d waren.
ik zie echt niet in wat er nu mis kan zijn met mijn config file...
heeft iemand van jullie een id?
wat betrefd snmpd, die heb ik alleen vanuit de ports geinstalled en word @boot gestard. Daar heb ik NIETS aan geconfigd!
Toch lijkt SNMP de fout te genereren ?? of vraagt mtrg om niet bestaande info ? dus ligt de fout toch bij mrtg ?
[ Voor 29% gewijzigd door xychix op 07-05-2003 12:57 ]
Every failure offers you a new opportunity! | Lokatie database|GoT - Notepad
