Misschien ben je hiermee geholpen, het is een stukje script wat vanaf de commandline aangeroepen kan worden.
Het script verwacht 5 parameters:
- Subject = tekst van de onderwerp-regel
- Attachment = path&bestandnaam van het attachment
- Recipient = geadresseerde
- Bodyfile = path&bestandnaam van een tekstdocumentje met de body-tekst
- SaveIt = true of false, geeft aan of na het versturen het bericht bewaard blijft.
succes
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
| 'Set up the objects required for Automation into lotus notes
Dim Maildb 'The mail database
Dim UserName 'The current users notes name
Dim MailDbName 'THe current users notes mail database name
Dim MailDoc 'The mail document itself
Dim AttachME 'The attachment richtextfile object
Dim Session 'The notes session
Dim EmbedObj 'The embedded object (Attachment)
Dim Subject
Dim Attachment
Dim Recipient
Dim Bodyfile
Dim SaveIt
Dim filesys
Dim readfile
Dim contents
'5 parameters zijn verplicht
If WScript.arguments.count <> 5 Then
WScript.Echo _
"Usage: sendmail.vbs <Subject, Attachment , Recipient , Bodyfile , SaveIt>"
WScript.quit
End If
'Assign arguments to named variables
Subject = WScript.arguments(0)
Attachment = WScript.arguments(1)
Recipient = WScript.arguments(2)
Bodyfile = WScript.arguments(3)
SaveIt = WScript.arguments(4)
'Start a session to notes
Set Session = CreateObject("Notes.NotesSession")
'Get the sessions username and then calculate the mail file name
'You may or may not need this as for MailDBname with some systems you
'can pass an empty string
UserName = Session.UserName
MailDbName = Left(UserName, 1) & Right(UserName, (Len(UserName) - InStr(1, UserName, " "))) & ".nsf"
'Open the mail database in notes
Set Maildb = Session.GETDATABASE("", MailDbName)
If Maildb.ISOPEN = True Then
'Already open for mail
Else
Maildb.OPENMAIL
End If
'Set up the new mail document
Set MailDoc = Maildb.CREATEDOCUMENT
MailDoc.Form = "Memo"
MailDoc.sendto = Recipient
MailDoc.Subject = Subject
set filesys = CreateObject("Scripting.FileSystemObject")
set readfile = filesys.OpenTextFile(Bodyfile, 1, false)
contents = readfile.ReadAll
readfile.close
MailDoc.Body = contents
MailDoc.SAVEMESSAGEONSEND = SaveIt
'Set up the embedded object and attachment and attach it
If Attachment <> "" Then
Set AttachME = MailDoc.CREATERICHTEXTITEM("Attachment")
Set EmbedObj = AttachME.EMBEDOBJECT(1454, "", Attachment,"Attachment")
MailDoc.CREATERICHTEXTITEM ("Attachment")
End If
'Send the document
MailDoc.PostedDate=Now() 'Gets the mail to appear in the sent items folder
MailDoc.SEND 0, Recipient
'Clean Up
Set Maildb = Nothing
Set MailDoc = Nothing
Set AttachME = Nothing
Set Session = Nothing
Set EmbedObj = Nothing
Wscript.Quit |
