ICQ History Extracten
  • 287 views sinds 30-01-2008
Ik heb nog een oude ICQ History file liggen:
"ICQnummer".idx
"ICQnummer".dat
Deze wil ik graag met een programmatje doorbrowsen / zoeken of extracten naar een textfile.
Wie weet zo'n progje of kan me helpen?
Alvast Bedankt!
  • danslo
  • Laatst online: 19:28
.dat kan van alles zijn.. open eens in wordpad ofzo
  • pven
Misschien dat je iets aan het onderstaande hebt:
Exporting your settings.
There are two steps you must do to successfully backup your ICQ Contact
list and settings.
STEP 1 : Backing up your DB
- Go (using the windows explorer) to your ICQ Directory.
- Go to the Database Directory (see NOTE 1)
- Copy your DB (see NOTE 2) to a safe place (see NOTE3).
STEP 2 : Backing up your ICQ Settings
- Open regedit (Start > Run > Regedit)
- Go to the key “HKEY_CURRENT_USER\Software\Mirabilis\ICQ”
- Select Registry > Export Registry File from the menu
- Type in the filename (example: icq.reg) and press OK.
That’s it! Your ICQ Contact List and ICQ Settings are backuped!
NOTE 1: Finding your DB Directory
Example: ICQ is installed in “C:\Program Files\ICQ” and
your ICQ version is “2001b”
--> The DB can be found in “C:\Program files\ICQ\2001b”.
Other versions are 98a, 99a, 99b, 2000a, 2000b
Very old versions ICQ store the DB into “Directory where
you put ICQ\DB” (ex. C:\Program Files\DB).
NOTE 2 : Copying your DB
Your DB consists of two parts: the .IDX file and the .DAT
file. Don’t forget to copy them both!
TIP: Use a compression tool to compress your DB to save
some disk space.
NOTE 3 : What is a safe place?
A safe place ISN’T the internet! Don’t upload your DB to an
FTP or something like that because other users can find it
by doing a simple search. And no, it doesn’t help when you
change the UIN before the .DAT and .IDX file cos’ your UIN
is also stored inside them.
A safe place might be on a CD (which you don’t lend to
friends!) or a floppy (if it fits on it).
Importing a backup.
Again, two steps.
STEP 1 : Importing the DB
- Reinstall ICQ and choose for “Existing User” when ICQ
asks you to choose between it and “New User”.
- Let ICQ run with your UIN and then shut it down.
- Copy your DB into the DB Directory of the version that is
installed (if your backup was from version 2000a and you
now use 2001a then copy it to 2001a)
- Go to the ICQ directory.
- Open the file DBConvert.exe
- Select your UIN from the upper list box and press next.
- After the DB is imported, “Reindex Done” will appear in
the textbox.
- Press next and then press done
STEP 2 : Importing your settings
- Double-click the .reg file you made
- Select “Yes” when it asks you if you want to import it.
- When importing is done, you will get a message box and
press “OK”
That’s it! You’ve successfully imported your ICQ Contact List and
Settings.
Volgens mij kan het ook gelezen worden als je de juiste ICQ-versie voor dat idx- en dat-bestand installeert, maar dan moet je dus wel de juiste versie weten.
|| Unprompted (AI-blog) || slotje.com for sale || Dank pven! ||
  • Varienaja
  • Laatst online: 14-06-2025
Varienaja
Wie dit leest is gek.
*Enorme schop*
Ik vond op mijn computer een ICQ log, dat ooit met ICQ 2000b is gemaakt. Ik wil graag eens terug lezen wat ik in die tijd zoal chatte met iedereen. Ik kan het 66423828.dat-bestand wel openen in notepad, maar daar staan allemaal rare tekens doorheen, dus dat leest voor geen meter.
Ik dacht daarom maar icq2000b te installeren, dan kan ik per contactpersoon de history opslaan als een .txt-bestandje. Ik heb dus icq2000b geinstalleerd. Die wil graag inloggen op de server, maar dat mislukt (logisch, want het protocol zal in de loop der jaren wel veranderd zijn), en daardoor wil het programma niet opstarten.
Sja.. en dan weet ik niet zo goed meer hoe ik m'n history leesbaar moet krijgen. Op internet vind ik geen conversie-programma's, en ook icq5 downloaden en installeren geeft me geen toegang tot m'n oude chatsessies.
Heeft een van jullie een goed idee?
Siditamentis astuentis pactum.
  • Gerco
  • Laatst online: 17-10 03:39
Gerco
Professional Newbie
Probeer "ICQ DB Extract" op deze pagina eens.
- "Als ik zou willen dat je het begreep, legde ik het wel beter uit!" | All number systems are base 10!
