Dell XPS 17 Intel i7 2630 Nvidia GT555 3Gb Hd1: OCZ Vertex 2 SSD 60 GB Hd2: 500Gb
dcc32 /?
[ Voor 8% gewijzigd door Erkens op 06-05-2003 11:55 . Reden: typfout is menselijk he ;) ]
Dit staat in je Delphi6 -> Bin map
We adore chaos because we like to restore order - M.C. Escher
The IDE lets you set various options through the menus; the command-line compiler gives you access to these options using the hyphen (-) delimiter. Options must be separated by blanks. For example:
DCC32 -IC:\DELPHI -DDEBUG SORTNAME -$R- -$U+
You can also use the /delimiter for options:
DCC32 /IC:\DELPHI/DDEBUG SORTNAME /$R-/$U+
Note: The command-line compiler options are not case-sensitive.
The following table lists the command-line options. In addition to the listed options, all single-letter compiler directives can be specified on the command line, as described in Compiler directive options.
29
30
31
32
33
34
35
36
37
38
| Option Description Aunit=alias Set unit alias B Build all units CC Console target CG GUI target Ddefines Define conditional symbol Epath Executable output directory Foffset Find runtime error GD Detailed map file GP Map file with publics GS Map file with segments H Output hint messages Ipaths Include directories J Generate an object file JP Generate C++ object file Kaddress Set image base address LEpath Package directory LNpath Package source code directory LUpackage Use packages M Make modified units Npath dcu/dpu output directory Opaths Object directories P Look for 8.3 file names Q Quiet compile Rpaths Resource directories TXext Target file extension Upaths Unit directories V Turbo Debugger debug information External debug informationVN Generate namespace debugging information in Giant format (used for C++) VR Generate an rsm file containing debug symbols W Output warning messages Z Disable implicit package compilation (Never build dcps) $directive Compiler directives --Help Show Help screen listing options. Also, if you type dcc32 alone on the command line, a list of command-line compiler options appears on your screen. --version Show name and version of the product. |
Kopie-pasta uit de helpfile
[ Voor 0% gewijzigd door FendtVario op 06-05-2003 13:34 . Reden: Kopie uit D7 help, maar weet zeker dat ie er bij zes ook bij zit ]
www.fendt.com | Nikon D7100 | PS5
