Groot Asus P4C800 Topic
  • 64 views sinds 30-01-2008
  • Goku33
  • Laatst online: 30-08 23:17
Veel mensen komen bij hun zoektocht naar een goed Canterwood moederbord toch uit op de Asus P4C800, leek het mij wel een goed idee om een topic te starten waarin mensen hun (oc)ervaringen kunnen uitwisselen en elkaars vragen kunnen beantwoorden. Bij deze dan maar :*)
Pagina op de website van Asus:
http://www.asus.com/produ...et478/p4c800/overview.htm
Specs:
Intel 875P chipset
Leveraging the Intel 875P chipset to support 3.2 GHz+ P4 CPU on 800MHz FSB, Dual DDR 400 memory, Intel Hyper-Threading Technology, Intel Performance Acceleration Technology, and a full-range of advanced features, P4C800 really delivers a full-value, high-performance solution for today's most demanding tasks.
Dual-Channel DDR400
Dual-channel DDR technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market. System bottlenecks are eliminated with balanced architecture and peak bandwidths up to 6.4GB/s.
Intel PAT
P4C800's built-in Intel PAT (Intel Performance Acceleration Technology) is a trigger for extreme performance. It helps to boost performance by 3~5%.
AI NET (Gigabit LAN)
The AI Series supports Gigabit LAN by integrating the 3COM 3C940 controller, equipped with a unique net-diagnosing utility-- VCT (Virtual Cable Tester). The controller intelligently detects net connection status up to 100 meters from a remote location and reports the distance of bad cable.
AI AUDIO (6-channel digital audio)
AI series motherboards employed the world's first intelligent audio CODEC. The 6-channel AD1985 audio CODEC automatically detects and identifies what types of peripherals are plugged into the audio I/O jacks and notifies users of inappropriate connection, meaning there will be no more confusion of Line-in, Line-out and Mic jacks.
AI Overclocking
A unique option in BIOS that enables quick overclocking up to 30% (depends on CPU and RAM). It automatically detects and optimizes every relevant parameter to provide both performance and stability.
The BIOS in AI Series also keeps all the special design for overclocking:
-- Flexible CPU Core Voltage Adjustments in 0.025V increments over defaults
-- SFS (Stepless Frequency Selection) up to 400MHz at 1MHz increanerts
-- Adjustable FSB/DDR ratio. Fixed AGP/PCI frequencies
-- ASUS C.P.R.(CPU Parameter Recall)
AGP8X/Pro
AGP8X (AGP 3.0) is the next generation VGA interface specification that enables enhanced graphics performance with high bandwidth up to 2.12GB/s.
ICH5R with Integrated SATA and RAID 0
Intel is the world’s first chipset maker to integrate Serial ATA (SATA) and RAID 0 functions into the South Bridge. The latest ICH5R chipset now delivers 150MB/s fast data transfer (SATA) and striping performance (RAID 0) to enhance computing efficiency. (Supported WinXP only)
8 USB 2.0 ports supports
USB 2.0 is the latest connectivity standard for next generation components and peripherals.
Backwards compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer speeds up to 40 times faster at 480Mb/s, for easy connectivity and ultra-fast data transfers.
CrashFree BIOS 2
Whenever BIOS gets corrupted, ASUS CrashFree BIOS 2 allows users to reboot the computer and perform an smart auto-recovery procedure through the motherboard support CD.
Q-Fan
This unique technology intelligently and automatically adjusts CPU fan speeds according to system load and temperature, enabling users to work in a distraction-free environment with minimal noise.
Nog een paar plaatjes erbij:
Afbeeldingslocatie: http://www.asus.com/products/mb/socket478/p4c800/p4c800_l.jpg
^Van de officiele asus site, maar volgens mij klopt die niet...
Afbeeldingslocatie: http://www.hothardware.com/reviews/images/ic7_p4c800/P4C800/board.jpg *klik*
^Dit is wel een goed plaatje
Afbeeldingslocatie: http://images.ukgamer.com/reviews/asus/p4c800/boxfront_large.jpg *klik*
Afbeeldingslocatie: http://www.asus.com/products/mb/socket478/p4c800/ai-logo120.gif
Reviews:
Abit IC7-G vs. Asus P4C800 @ hothardware.com
Asus P4C800 & Intel D875PBZ @ gamepc.com
Asus P4C800 @ lostcircuits.com
Asus P4C800 @ extremetech.com
Asus P4C800 @ hardwarezone.com
Asus P4C800 @ anandtech.com
Asus P4C800 @ ukgamer.com
Asus P4C800 @ legionhardware.com
Pricewatch:
Asus P4C800
Asus P4C800 Deluxe
  • Goku33
Ik plaatste deze topic omdat ik waarschijnlijk zelf binnenkort een heel nieuw systeem ga kopen.
Mijn vraag: wat is het verschil tussen de gewone uitvoering en de Deluxe versie?
  • Goku33
Jupz, maar deze plank leek me wel een eigen topic waard. Is toch wat overzichtelijker ipv al die verschillende moederborden door elkaar... :)
Goku333 schreef op 05 May 2003 @ 21:01:
Ik neem aan dat op de Global site van http://www.asus.com.tw de verschillen te vinden zijn tussen de normale en deluxe versie. Ik neem aan zoals in de meeste gevallen dat de deluxe versie wat meer features heeft. Zoals de Gigabyte 8KNXP Ultra die beschikt over SCSI terwijl de 8KNXP deze mist.
  • BalusC
BalusC
Carpe diem
Jammer van je startpost, maar je had jezelf de moeite bespaard door de sticky goed door te nemen: Abbadon in "Dit graag lezen eer je een topic opent" B)
