Omdat het ondertussen duidelijk is wat het probleem is (IE+OE), verplaats ik je vraag WOS -->
Software AlgemeenRailLuc schreef op 04 mei 2003 @ 13:49:
1,14 GB zijn alle DBX-bestanden van OE. Die bestanden dragen de naam van de mappen in OE. Als ik zo'n map leeg haal, blijft het dbx-bestand echter gewoon op de oude grootte?
Klopt, die moet je kleiner maken, het wordt niet realtime kleiner gemaakt uit performance oogpunt. OE gebruik ik al lang niet meer, maar uit een link in de SA FAQ:
Compact Your OE Folders
Like most database programs, OE does not actually remove an item from a *.dbx file when you delete a message. Instead it merely tags the item for removal at a later time, mainly when you next compact your folders. Until then, the deleted message is still occupying disk space, which can cause OE to perform more slowly when accessing the *.dbx file. To recover disk space and keep your files as small as possible, you need to compact your folders regularly. In the OE Folder list (View| Layout| Folder List), click Outlook Express so that no mail or news folder is open. Now click File| Work Offline so that no new messages will be arriving. Finally, click File| Folder| Compact All Folders. This process can take several minutes and you should not attempt to use your computer until it is finished. If an error occurs, such as "cannot compact, folder in use", just close OE, wait a second or two, then re-open OE and begin the process again. This will compact not only your news folders, but also all of your mail folders and the all-important Folders.dbx. To compact only news folders, click Tools| Options| Maintenance| Clean up Now, then click Compact.
To compact a single mail folder, just click once on the folder to select it, then click File| Folder| Compact. To compact a single newsgroup folder, right-click on the newsgroup, then click Properties| Local File| Compact.
RailLuc schreef op 04 May 2003 @ 14:09:
Ik zit met één probleem: de Postvak In-dbx is 463 MB en ik kan berichten uit het postvak in halen wat ik wil, die blijft zo groot. Bij de andere mappen werkt het wel.
Dat zei je 20 minuten eerder ook al min of meer, het is niet nodig het daarvoor binnen 24 uur omhoog te schoppen
Voor 9% gewijzigd door
F_J_K op 04-05-2003 14:13
