[debian] Screen(s) found, maar toch geen X
  • 45 views sinds 30-01-2008
Ik heb een probleem,
Na een lange tijd niet met linux gewerkt te hebben (desktop)
draai ik het nu weer, probleem is dat ik met mijn (nieuwe) videokaart alleen niet ver kom.
vroeger met me Geforce 4 ti4400 en me voodoo banshee werkte het altijd en met me Ati niet..
oke..
specs:
standaard 15" schermpje.. 1024x768 @ 60hz
Videokaart is een ati rage 128pro 32mb agp
Dist: Debian 3.0 testing/unstable
kernel: 2.2.20-compact
Xfree: 4.2.1
29
30
31
32
33
34
35
36
37
38
39
40
root@asmooh:/home/rc5/stats# startx
xauth:  creating new authority file /root/.Xauthority
X: warning; process set to priority -11 instead of requested priority -10
This is a pre-release version of XFree86, and is not supported in any
way.  Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org.  Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.2.1.1 (Debian 4.2.1-6 20030225230350 branden@progeny.com) / X
Window System
(protocol Version 11, revision 0, vendor release 6600)
Release Date: 18 October 2002
        If the server is older than 6-12 months, or if your card is
        newer than the above date, look for a newer version before
        reporting problems.  (See http://www.XFree86.Org/)
Build Operating System: Linux 2.4.20-586tsc i686 [ELF]
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.0.log", Time: Sun May  4 05:53:51 2003
(==) Using config file: "/etc/X11/XF86Config-4"
Skipping "/usr/X11R6/lib/modules/fonts/libspeedo.a:spencode.o":  No symbols foun
d
(EE) Unable to find a valid framebuffer device
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to debian-x@lists.debian.org.
X connection to :0.0 broken (explicit kill or server shutdown).
mijn config file: http://www.digatitech.com/XF86Config-4
weet iemand wat ik pricies in de config moest zetten?
ik heb wel 1x X gehad, maar..... toen had ik geen toesenbord en ook geen muis..
dus daar kom je ook niet ver mee..
overgens heb ik in bash wel gewoon toetsebord
iemand enig idee?
  • Hagar
  • Laatst online: 14-10-2025
Hagar
Diabootic
en
Section "Device"
Identifier "Generic Video Card"
Driver "ati"
Option "UseFBDev" "true"
EndSection
Daar had je zelf ook op kunnen komen lijkt me :)
Ik heb zelf geen ervaring met ati onder linux, maar je moet met modconf de ati framebuffer moet laden of die optie uit je config uit zetten. Welke van de twee de "beste" oplossing is kan ik je niet vertellen ;)
* Hagar heeft tot noch toe alleen met nvidia kaartjes te maken gehad
Nu ook zonder stropdas
hmm, vaag :-/
maar krijg opeens nog meer errors
root@asmooh:~# apt-get install bitchx
Reading Package Lists... Done
Building Dependency Tree... Done
The following NEW packages will be installed:
  bitchx
0 packages upgraded, 1 newly installed, 0 to remove and 2  not upgraded.
Need to get 1466kB of archives. After unpacking 6463kB will be used.
Get:1 ftp://download.xs4all.nl unstable/main bitchx 1:1.0-0c19-8 [1466kB]
Fetched 1466kB in 2s (503kB/s)
Gdk-WARNING **: locale not supported by C library
Gtk-WARNING **: cannot open display:
debconf: unable to initialize frontend: Gnome
debconf: (DISPLAY problem?)
debconf: falling back to frontend: Dialog
dpkg: `ldconfig' not found on PATH.
dpkg: `start-stop-daemon' not found on PATH.
dpkg: `install-info' not found on PATH.
dpkg: `update-rc.d' not found on PATH.
dpkg: 4 expected program(s) not found on PATH.
NB: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin.
E: Sub-process /usr/bin/dpkg returned an error code (2)
root@asmooh:~#
Hagar schreef op 04 May 2003 @ 04:27:
en
ik heb nu beeld maar het zelfde probleem als eerst
geen toetsebord en geen muis
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Je hebt voor debconf aangegeven dat hij een X applicatie als configuratiemanier moet gebruiken, hij kan X niet opstarten , dus dan lijkt me een vrij logische actie om X op te starten, of de configuratie van debconf te veranderen..
Lees ook eens NOS policy - updated 01/04/03 door om te zien wat we wel van een startposting verwachten, dit topic gaat dicht.
God, root, what is difference? | Talga Vassternich | IBM zuigt
