ik wil graag m'n BIOS upgraden zodat ik ook een athlon XP in me mobo kan prikken (QDI KinetiZ 7E/A
). Ik heb nu dus al die bestanden gedownload, ik lees de reedme maar ik snap echt niet wat ze nou allemaal willen. Ik wil jullie niet als helpdesk hebben
maar ik kan wel een beetje engels, maar dit snap ik echt niet meer!
alvast bedankt!
29
30
31
32
33
34
35
36
| K7V8363 KINETIZ 7B/E BIOS V4.0LCP release note
This disk contains three files:K7B_V40.BIN,README.TXT and AWDFLASH.EXE
1.The checksum of K7B_V40.BIN is 2FAE(Hex);
2. How to use AWDFLASH.EXE utility:
This is a flash memory write/read utility.
IMPORTANT NOTE:
The AWDFLASH utility could not correctly run in windows (virtual 8086)
MS-DOS mode. It must be proceeded with the following steps:
1.Create a bootable system floppy diskette by typing "FORMAT A:/S"
from the dos prompt under DOS6.XX or WINDOWS9X environment.
2.Boot system with diskette.
3.Then run the AWDFLASH utility.
Usage:
AWDFLASH [BIOSfile1] [BIOSfile2] [/<sw>[/<sw>...]]
BIOSfile1: New BIOS Name For FLASH Programming
BIOSfile2: BIOS File For Backing-up the Original BIOS
<command> function definition:
cc: clear CMOS; cp: clear PnP;
cd: clear DMI.
/sn: No Original BIOS Backup. If this option is chosen:
Be sure your new BIOS is compatible with your MB. If not, the system
are damaged.
/sy: Backup Original BIOS to Disk File.
Examples:
AWDFLASH ****.BIN /py/sn/cd/cp
Warning:
Avoid power-off incidently in upgrading procedure, or system would fail
to reboot!
UPDATE DATE:03/07/2003 |
alvast bedankt!
