[Digicam] Mounten mislukt
  • Oxi
  • Laatst online: 14-11-2022
Camera: Nikon Coolpix 3100
Distro: RedHat Linux 9.0 (2.4.20-9 kernel).
Ik heb deze camera nu een week en 'ineens' kan ik me camera niet meer mounten. De camera is USB Storage Device compliant en als ik em in de pc van me vader (XP Pro) plug dan herkent ie em netjes en kan ik foto's bekijken. Maar op me linux bak niet meer :(
# mount -t auto /dev/sda1 /zooi/camera
mount: /dev/sda1 is not a valid block device
# cat /proc/scsi/scsi
Attached devices:
Host: scsi0 Channel: 00 Id: 00 Lun: 00
Vendor: NIKON Model: NIKON DSC E3100 Rev: 1.00
Type: Direct-Access ANSI SCSI revision: 02
# cat /proc/bus/usb/devices
S: Manufacturer=NIKON
S: Product=NIKON DSC E3100
S: SerialNumber=000004621306
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr= 0mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=04(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I: If#= 0 Alt= 1 #EPs= 3 Cls=ff(vend.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0000 ProdID=0000 Rev= 0.00
# cat /var/log/messages
Apr 27 15:48:54 bram kernel: Initializing USB Mass Storage driver...
Apr 27 15:48:54 bram kernel: usb.c: registered new driver usb-storage
Apr 27 15:48:54 bram kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Apr 27 15:48:54 bram kernel: Vendor: NIKON Model: NIKON DSC E3100 Rev: 1.00
Apr 27 15:48:54 bram kernel: Type: Direct-Access ANSI SCSI revision: 02
Apr 27 15:48:54 bram kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Apr 27 15:48:54 bram kernel: SCSI device sda: 251904 512-byte hdwr sectors (129 MB)
Apr 27 15:48:54 bram kernel: sda: Write Protect is off
Apr 27 15:48:54 bram kernel: sda: sda1
Apr 27 15:48:54 bram kernel: USB Mass Storage support registered.
Apr 27 15:48:55 bram kernel: usb_control/bulk_msg: timeout
Apr 27 15:49:12 bram kernel: smb_request: result -104, setting invalid
Apr 27 15:49:12 bram kernel: smb_retry: successful, new pid=3370, generation=2
Apr 27 15:49:13 bram kernel: smb_retry: successful, new pid=3382, generation=2
Apr 27 15:49:13 bram kernel: smb_request: result -104, setting invalid
Apr 27 15:49:13 bram kernel: smb_retry: successful, new pid=3388, generation=2
Apr 27 15:49:13 bram kernel: smb_retry: successful, new pid=3395, generation=2
Apr 27 15:49:14 bram kernel: smb_retry: successful, new pid=3401, generation=2
Apr 27 15:49:14 bram kernel: smb_request: result -104, setting invalid
Apr 27 15:49:14 bram kernel: smb_retry: successful, new pid=3407, generation=2
Apr 27 15:50:10 bram kernel: usb-storage: host_reset() requested but not implemented
Apr 27 15:50:20 bram kernel: scsi: device set offline - command error recover failed: host 0 channel 0 id 0 lun 0
Apr 27 15:50:20 bram kernel: SCSI error: host 0 id 0 lun 0 return code = 6070000
Apr 27 15:50:20 bram kernel: ^ISense class 0, sense error 0, extended sense 0
Apr 27 15:50:20 bram kernel: sda: I/O error: dev 08:00, sector 0
Apr 27 15:50:20 bram kernel: I/O error: dev 08:00, sector 0
Apr 27 15:50:20 bram kernel: unable to read partition table
Apr 27 15:51:42 bram kernel: usb.c: USB disconnect on device 00:0b.1-1 address 2
# fdisk /dev/sda
Unable to open /dev/sda
Hij geeft dus aan "unable to read partition table" terwijl windows dat WEL kan. Kaart formatteren heeft ook niet geholpen. Andere USB poort werkte ook niet :/
Ik begin een beetje uit ideeen te raken hiervoor :'(
I wouldn't give his troubles to a monkey on a rock
  • Oxi
Op PTP Compliant zetten en dan kan ik met 'gtkam' toch bij me foto's. Maar ik kan ze nog steeds niet normaal mounten :'(
  • blouweKip
  • Laatst online: 12-09 21:42
Welke kernel gebruikte je toen je hem nog wel kon mounten? heb je bijgehouden of je nog dingen gewijzigd hebt op je distro?
"For my friends, anything; for my enemies, the law."
  • Oxi
Me computer crashte 's nachts en 's ochtend heb ik em opnieuw opgestart. Heb niets geinstalleerd/geupgrade.
dat crashen komt waarschijnlijk omdat bijna al me fans uit gaan 's nachts en met me waterkoeling heb ik geen cpu fan meer enzo dus oververhitte NB
  • blouweKip
Tja, misschien is er data corrupt op je redhat partitie, dan is het een kwestie van herinstalleren (of misschien ff de kernel opnieuw compilen)
