Waar jullie het over hebben is het overclokken van je FSB. Goed geheugen is hierbij van belang. Het volgende komt van
http://www.athlonoc.com/
With FSB overclocking, your hardware might just not be able to take it. This form of overclocking is ESPECIALLY dependent on good memory as if you start running your memory at 133mhz (in asynchronous mode) and your system bus at 100mhz for the base line, things heat up for your memory really quick.
FSB Memory Speed (Synchronous) Memory Speed (Asynchronous)
100mhz 100 mhz 133 mhz
105mhz 105 mhz 140 mhz
110mhz 110 mhz 146.6 mhz
115mhz 115 mhz 153.3 mhz
125mhz 125 mhz 166.6 mhz
133mhz 133 mhz 177.3 mhz
