Pproxy problems?
  • ZeroVince
Om de een of andere reden kunnen de clients niet naar poort 2064 flushen, terwijl de pproxy gewoon up is. Flushen naar de twee andere poorten die open staan namelijk 21 en 8080 werken wel. Heb er ook over gedacht dat het een probleem met de firewall kan zijn, maar dat lijkt me niet want daar hebben we niks aan veranderd en bovendien kunnen we daar remote niet veel aan doen dus hoop ik dat het probleem ergens anders ligt..
Wat details:
Originally posted by BigJ:
and for some reason im unable to connect on the regular port, i had to tell it to flush to port 21...
[Apr 25 09:11:25 UTC] Connected to elitehackers.keyserver.org:2064...
[Apr 25 09:12:19 UTC] Connect to host 24.214.100.184:2064 failed.
                      EDISCONNECT: connection lost
[Apr 25 09:12:50 UTC] Connect to host 24.214.100.184:2064 failed.
[Apr 25 09:13:21 UTC] Connect to host 24.214.100.184:2064 failed.
[Apr 25 09:13:52 UTC] Connect to host 24.214.100.184:2064 failed.
[Apr 25 09:14:22 UTC] Connect to host 24.214.100.184:2064 failed.
[Apr 25 09:14:53 UTC] Connect to host 24.214.100.184:2064 failed.
[Apr 25 09:20:25 UTC] Connected to elitehackers.keyserver.org:21...
[Apr 25 09:28:42 UTC] The perproxy says: "Grazing the meadows!"
[Apr 25 09:28:42 UTC] Refreshed project state data from server. (cached)
[Apr 25 09:28:42 UTC] RC5-72: Sent 1 packet (1.00 stats units) to server.
[Apr 25 09:28:42 UTC] Connection closed.
[KeyServer]
ipaddress=chaos.keyserver.org
port=2064
connectperiod=600
connectivity=normal     ; normal,offline,lurk,lurkonly
;bindip=                        ; IP to talk out to keyserver from
;uuehttpmode=0
    ; 0=normal,1=uue,2=http,3=http+uue
    ; 4=socks4,5=socks5,6=genproxy,7=genproxy+uue
;httpproxy=wwwproxy.corporation.com
;httpport=8080
;httpid=
maxservers=4
[ports]
;listenaddress=                 ; IP to accept clients on
port=2064
port2=21                       ; must be root for ports < 1000
port3=8080
testport=3064
timeout=30
acceptincoming=1
[04/25/03 09:39:54 UTC] distributed.net Personal Proxy (build 332)
[04/25/03 09:39:54 UTC] Visit http://www.distributed.net/ for details.
[04/25/03 09:39:54 UTC] Proxy starting up.
[04/25/03 09:39:54 UTC] Verbosity set to: all (-1)
[04/25/03 09:39:57 UTC] Notice: connectivity mode is normal
[04/25/03 09:39:57 UTC] Notice: Loaded 0 ignoredip addresses from ini file
[04/25/03 09:39:57 UTC] Notice: Loaded 0 allowedip addresses from ini file
[04/25/03 09:39:57 UTC] Notice: Primary listener bound to (all devices):2064
[04/25/03 09:39:57 UTC] Notice: Test listener bound to (all devices):3064
[04/25/03 09:39:57 UTC] Notice: Listener 1 bound to (all devices):21.
[04/25/03 09:39:57 UTC] Notice: Listener 2 bound to (all devices):8080.
[04/25/03 09:40:01 UTC] rc5-72 r=30001/30001, d=0/1, 0.0 Mkeys/sec, tot=0/0 bloc
ks
[04/25/03 09:40:01 UTC] ogr r=1200/1200, d=0/3, 0.0 Mnodes/sec, tot=0/0 stubs
[04/25/03 09:40:01 UTC] Status: Uptime: 0.00:00:04, 4 listeners, 0 uplinks
[04/25/03 09:40:01 UTC] Status: 0 active clients (peak: 0, mean: 0.00)
[04/25/03 09:40:01 UTC] Client: Accepted connection from 155.72.100.4:11384
Enig idee waar het aan kan liggen?
  • budi
  • Laatst online: 02-11 14:22
Als je telnet naar poort 2064, gebeurt er dan verder niets, of zegt hij 'connection refused'?
Zo kun je in elk geval makkelijk concluderen of de poort open staat.
[ Voor 33% gewijzigd door budi op 25-04-2003 21:21 ]
MY Systemconfiguration: 10fingers@5chars/s; 2legs@5km/h; 1mouth@14k4; 2ears@18Khz; 2eyes@-6&-7
  • ZeroVince
C:\>telnet elitehackers.keyserver.org 2064
Bezig met verbinding maken met elitehackers.keyserver.org...Kan geen verbinding
met de host maken, op poort 2064: De verbinding is mislukt
[ Voor 4% gewijzigd door ZeroVince op 25-04-2003 21:42 ]
  • [eNeRGy]
  • Laatst online: 24-04-2025
firewall draaien? firewall/portforwarding rules?
  • Pim.
  • Registratie: Mei 2001
  • Laatst online: 07-08 06:58
Pim.
Aut viam inveniam, aut faciam
als ik http://elitehackers.keyserver.org 2064/ open in me webbrouwser kom ik op doofpot.nl.
ik hoor doorgegooit te worden naar de D.net site (mischien een apache/IIS instelling ) ???
"The trouble with quotes from the Internet is that you can never know if they are genuine." - Elvis Presley | Niet met me eens ? DM ME
  • DSmarty
Lijkt me een typische firewall/portmapping kwestie.
Toch nog maar eens goed checken of poort 2064 wel open staat cq gemapped is naar de juiste lokale machine.
  • mcB
  • Laatst online: 02-11 16:02
mcB
Kijk eens in je messages op de server.
Misschien dat na een restart van de server er een poortconflict is ontstaan waadoor de perproxy de poort niet krijgt.
Strix (Skullflame)
  • ZeroVince
Vanaf hier kan ik dus helaas niet bij de proxy, die staat ergens in de states en degene die b.v. even naar de firewall of messages op de server kan kijken heeft nog niet op mijn PM (personal message) gereageerd (en er staan ook nog een paar anderen die ik had gestuurd enkele dagen geleden op "unread" dus ik heb niet veel hoop dat het erg snel via die weg kan)..
Waar zou ik remote naar kunnen kijken?
Vreemd dat je op doofpot.nl uit kwam ./Proxy! :?
[ Voor 21% gewijzigd door ZeroVince op 25-04-2003 23:21 ]
  • Jive
  • Laatst online: 22-05 22:10
Jive
MooMooMastah
elitehackers.keyserver.org telnet zegt dat het een windows doos is .... (isa-proxy in de weg mischien ??)
op poort 2064 krijg ik geen connectie ... en op 21 & 8080 krijg ik ook geen response trouwens ...
het laatst geflushede pakketje is overigens 4 uur geleden geflushed voor OGR en 26 & 32 mins voor rc5 .... de perproxy draait dus nog wel en ontvangt nog wu's
lijkt mij een heel raar probleem ...
Jive's Box
Jive @ DNET
  • ZeroVince
Thanks heren, deze kan dicht.. :)
Yeah, been having a lot of storms here, and the cable has been going out. I reset the settings on the firewall, it got messed up somehow, should be working again now.
