[rh9] i810 onboard => geen geluid
  • 52 views sinds 30-01-2008
Net rh9 geinstalleerd, hiervoor mandrake 9. En bij beide geen geluid. Ik heb een p4pe moederbord met onboard geluidskaart i810.
Module is geladen, ik hoor gewoon geen geluid en krijg geen foutmelding.
Weet iemand iets?
hmm wa's de output van modprobe etc?
cat /proc/pci
is misschien ook handig om ff erbij te hebben :)
PCI devices found:
Bus 0, device 0, function 0:
Host bridge: Intel Corp. 82845G/GL [Brookdale-G] Chipset Host Bridge (rev 2).
Prefetchable 32 bit memory at 0xf8000000 [0xfbffffff].
Bus 0, device 1, function 0:
PCI bridge: Intel Corp. 82845G/GL [Brookdale-G] Chipset AGP Bridge (rev 2).
Master Capable. Latency=64. Min Gnt=8.
Bus 0, device 29, function 0:
USB Controller: Intel Corp. 82801DB USB (Hub #1) (rev 2).
IRQ 5.
I/O at 0xd800 [0xd81f].
Bus 0, device 29, function 1:
USB Controller: Intel Corp. 82801DB USB (Hub #2) (rev 2).
IRQ 9.
I/O at 0xd400 [0xd41f].
Bus 0, device 29, function 2:
USB Controller: Intel Corp. 82801DB USB (Hub #3) (rev 2).
IRQ 9.
I/O at 0xd000 [0xd01f].
Bus 0, device 29, function 7:
USB Controller: Intel Corp. 82801DB USB EHCI Controller (rev 2).
IRQ 11.
Non-prefetchable 32 bit memory at 0xed800000 [0xed8003ff].
Bus 0, device 30, function 0:
PCI bridge: Intel Corp. 82801BA/CA/DB PCI Bridge (rev 130).
Master Capable. No bursts. Min Gnt=6.
Bus 0, device 31, function 0:
ISA bridge: Intel Corp. 82801DB ISA Bridge (LPC) (rev 2).
Bus 0, device 31, function 1:
IDE interface: Intel Corp. 82801DB ICH4 IDE (rev 2).
IRQ 9.
I/O at 0xf000 [0xf00f].
Non-prefetchable 32 bit memory at 0x10000000 [0x100003ff].
Bus 0, device 31, function 5:
Multimedia audio controller: Intel Corp. 82801DB AC'97 Audio (rev 2).
IRQ 9.
I/O at 0xa800 [0xa8ff].
I/O at 0xa400 [0xa43f].
Non-prefetchable 32 bit memory at 0xec000000 [0xec0001ff].
Non-prefetchable 32 bit memory at 0xeb800000 [0xeb8000ff].
Bus 1, device 0, function 0:
VGA compatible controller: nVidia Corporation NV17 [GeForce4 MX440] (rev 163).
IRQ 5.
Master Capable. Latency=64. Min Gnt=5.Max Lat=1.
Non-prefetchable 32 bit memory at 0xee000000 [0xeeffffff].
Prefetchable 32 bit memory at 0xf0000000 [0xf7ffffff].
Prefetchable 32 bit memory at 0xef800000 [0xef87ffff].
Bus 2, device 5, function 0:
Ethernet controller: PCI device 14e4:4401 (Broadcom Corporation) (rev 1).
IRQ 9.
Master Capable. Latency=32.
Non-prefetchable 32 bit memory at 0xed000000 [0xed001fff].
Bus 2, device 11, function 0:
SCSI storage controller: Adaptec AHA-2940/2940W / AIC-7871 (rev 0).
IRQ 11.
Master Capable. Latency=32. Min Gnt=8.Max Lat=8.
I/O at 0xb800 [0xb8ff].
Non-prefetchable 32 bit memory at 0xec800000 [0xec800fff].
  • Lancer
  • Laatst online: 13-09 13:43
Lancer
What the......
Hmmm, ik denk dat er nog meer niet werkt op je systeem. Je IDE interface wil waarschijnlijk ook niet naar UDMA. e.e.a. wordt waarschijnlijk voor een deel veroozaakt door de 82801DB revisie van je chipset. Die wordt volgens mij nog niet ondersteund (al wel in de 2.5 kernels). Ik heb net een laptop ingericht met dezelfde 82801DB. Ik heb met de hand de kernel source aangepast in een 2.4.21-pre6
Je kunt niet in een systeem meten zonder het systeem te beinvloeden.... (gevolg van de Heisenberg onzekerheidsrelatie)
Is de kernel 2.5 al stabiel met die chipset? Want dan update ik naar 2.5.
  • Lancer
Lancer
What the......
2.5 is op eigen risico, daarom heb ik zelf maar even de 2.4 kernel aangepast (misschien dat de verandering ook als in 2.4.21-pre7 zit, .....uuhhh, ik zie net dat 2.4.20-9 de aanpassing ook al heeft.
  • Lancer
Lancer
What the......
Je kunt ook eens de ALSA sounddrivers proberen van www.freshrpms.net. Let op, na installatie staan alle kanalen op 0/mute
oh dan ga ik over naar 2.4.20-9 :) bedankt
  • Lancer
Lancer
What the......
Update...., met ALSA werkt 't zeker (tenminste bij mij)
ok, 2.4.20-9 geinstalleerd en nog werkt het geluid niet. Netwerkkaart werkt ook niet meer! Heel vaag.
Moet je een optie aanzetten in de kernel die ik misschien over het hoofd heb gezien?
[ Voor 31% gewijzigd door Verwijderd op 23-04-2003 13:21 ]
  • Lancer
Lancer
What the......
Nee, dat niet. Voor je netwerkkaart kun je de Broadcom driver gebruiken. Unzippen, make en make install. http://www.ee.surrey.ac.u...iles/bcm4400-1.0.2.tar.gz
ALSA kun je op www.freshrpms.net neerhalen
Lijkt me dat de topicstart niet voldoet aan de eisen die we er in NOS aan stellen. Topicstart is weinig informatief en van het type helpdesk.
Lees NOS policy - updated 01/04/03 maar eens door.
