Hallo mensen ik heb met onderstaande documentatie
http://www.raxnet.net/products/cacti/docs/INSTALL-WIN32.htm
Cacti geinstalleerd. Alleen nu werkt het niet want ik krijg de volgende foutmelding
c:\cmd.php
Cannot find module (IP-MIB): At line 0 in (none)
Cannot find module (IF-MIB): At line 0 in (none)
Cannot find module (TCP-MIB): At line 0 in (none)
Cannot find module (UDP-MIB): At line 0 in (none)
Cannot find module (SNMPv2-MIB): At line 0 in (none)
Cannot find module (SNMPv2-SMI): At line 0 in (none)
Cannot find module (UCD-SNMP-MIB): At line 0 in (none)
Cannot find module (UCD-DEMO-MIB): At line 0 in (none)
Cannot find module (SNMP-TARGET-MIB): At line 0 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 0 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 0 in (none)
Cannot find module (UCD-DLMOD-MIB): At line 0 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 0 in (none)
Cannot find module (SNMP-MPD-MIB): At line 0 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 0 in (none)
Cannot find module (SNMP-NOTIFICATION-MIB): At line 0 in (none)
Cannot find module (SNMPv2-TM): At line 0 in (none)
'w' is not recognized as an internal or external command,
operable program or batch file.
'grep' is not recognized as an internal or external command,
'awk' is not recognized as an internal or external command,
The system cannot find the path specified.
'cat' is not recognized as an internal or external command,
'ps' is not recognized as an internal or external command,
'wc' is not recognized as an internal or external command,
'uptime' is not recognized as an internal or external command,
Content-type: text/html
X-Powered-By: PHP/4.3.1
Nu is mijn vraag hoe komt dit. Komt dit doordat ik toch niet de juiste php met snmp support gebruik omdat ik deze niet kon vinden. op php.net Of doe ik nog iets anders verkeerd.
Ik hoop dat iemand mij kan helpen. Want ook hier kan ik het niet echt vinden.
http://www.raxnet.net/boa...6b067492d4426c69a69927680
Ik gebruik overigens Windows 2000 AV Server met
Apache 1.3.27 win32 no src
Cacti-0.6.8a
Mysql 3.23.56
php-4.3.1-win32
rrdtool-1.0.35.x86distr
Wat mis ik ??
c:\cmd.php
Cacti-0.6.8a
Mysql 3.23.56
php-4.3.1-win32
Wat mis ik ??
