Arcserve Backup 9.0 SCSI Tape Driver wil niet geladen worden
K heb een novell netware 5.1 server met sp 5 geinstalleerd. Op deze server heb ik Arcserve 9.0 geinstalleerd, om een goeie disaster recovery te kunnen uitvoeren. Eigenlijk is alles in orde behalve de tapestreamer, alles gaat goed totdat tapesvr.nlm word geladen. De tape word gezien door arcserve.
Is het misschien mogelijk dat tapesvr.nlm geupdate moet worden ofzo?
Wanneer die NLM geladen wordt, wat gaat er dan mis? Doet het nie? Foutmelding? Welke tape-drive?
De NLM word geladen zodra arcserve gestart word met het commando astart.
Hieronder zie je de log van mn Arcserve start:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
Apr-16 13:27:54    Using configuration file SYS:\ARCSERVE\ASCONFIG.INI.
Apr-16 13:27:56
Apr-16 13:27:57    Loading SYS:\ARCserve\NLM\PFC.NLM /NC /PFASCONFIG.INI /M
                   /FSYS:\ARCserve\NLMINFO.LOG
Apr-16 13:27:58    CA Pre Flight Check (Build  575.012 11/19/02)
Apr-16 13:27:58    Version 9.00       November 19, 2002
Apr-16 13:27:59    Option [IncludeNCFFiles] is DISABLED
Apr-16 13:27:59    PFC: Checking only NLM information
Apr-16 13:28:17    PFC: Information is saved to file
                   SYS:\ARCSERVE\NLMINFO.LOG
Apr-16 13:28:18    PFC: NLMs found meet the requirement
Apr-16 13:28:21
Apr-16 13:28:21    Loading SYS:\SYSTEM\TLI.NLM
Apr-16 13:28:22    [TLI.NLM] is ALREADY loaded.
Apr-16 13:28:22
Apr-16 13:28:23    Loading SYS:\SYSTEM\BTRIEVE.NLM
Apr-16 13:28:23    [BTRIEVE.NLM] is ALREADY loaded.
Apr-16 13:28:24
Apr-16 13:28:24    Loading SYS:\ARCserve\NLM\CSDBAPIB.NLM
Apr-16 13:28:25    ARCserve Database API (Build  575.000 10/31/02)
Apr-16 13:28:25    ARCserve Database API is loaded
Apr-16 13:28:25    Version 9.00       October 31, 2002
Apr-16 13:28:29
Apr-16 13:28:29    Loading SYS:\SYSTEM\DSAPI.NLM
Apr-16 13:28:30    [DSAPI.NLM] is ALREADY loaded.
Apr-16 13:28:30
Apr-16 13:28:31
Apr-16 13:28:31
Apr-16 13:28:32    Loading SYS:\ARCSERVE\NLM\CANWPABD.NLM
Apr-16 13:28:32    CANWPABD: Searching for valid Adapters, Please wait.
Apr-16 13:28:37    CANWPABD:
Apr-16 13:28:37    CANWPABD: BINDING : ADAPTER [CPQSCSI.HAM]  /  [3] DEVICES
Apr-16 13:28:38    CANWPABD: DEVICE[0] : 6[V500-A0-D6:0] Compaq 53C875 Slot 0
                   ID 6 QUANTUM ATLAS Not Registered
Apr-16 13:28:38    CANWPABD: DEVICE[1] : 8[V500-A0-D0:0] Compaq 53C875 Slot 0
                   ID 0 COMPAQ ST34572W Not Registered
Apr-16 13:28:39    CANWPABD: DEVICE[2] : *[V500-A0-D2:0] SONY    SDT-7000
                   021 Is Registered
Apr-16 13:28:40    CANWPABD:
Apr-16 13:28:40    CANWPABD: Searching for valid Adapters, Please wait.
Apr-16 13:28:41    BrightStor ARCserve 9.0 SCSI Board Driver (Build  575.000
                   10/31/02)
Apr-16 13:28:41    Version 9.00       October 31, 2002
Apr-16 13:28:46    SCSI Board Driver is ready
Apr-16 13:28:49
Apr-16 13:28:49    Loading SYS:\ARCserve\NLM\PFC.NLM /NC /PFASCONFIG.INI
Apr-16 13:28:50    CA Pre Flight Check (Build  575.012 11/19/02)
Apr-16 13:28:50    Version 9.00       November 19, 2002
Apr-16 13:28:51    Option [IncludeNCFFiles] is DISABLED
Apr-16 13:28:52    PFC: Checking server configuration, Please wait ...
Apr-16 13:28:52    1 host adapter(s) found
Apr-16 13:29:09    BrightStor ARCserve server has valid job queue and queue
                   user
Apr-16 13:29:09    1 device(s) found on host adapter [BOARD0]
Apr-16 13:29:40    PFC: Information is saved to file
                   TESTSERVER/SYS:\ARCSERVE\PFC.LOG
Apr-16 13:29:41    PFC: Server Configuration is OK
Apr-16 13:29:44
Apr-16 13:29:44    Loading SYS:\ARCserve\NLM\CATIRPC.NLM
Apr-16 13:29:46    CA RPC Interface (Build  575.006 11/11/02)
Apr-16 13:29:46    Version 9.00       November 11, 2002
Apr-16 13:29:47    Module SYS:\ARCserve\NLM\CATIRPC.NLM was loaded
                   successfully.
Apr-16 13:29:47
Apr-16 13:29:48    Loading SYS:\ARCserve\NLM\ASDB.NLM
Apr-16 13:29:48    BrightStor ARCserve 9.0 Database (Build  575.013
                   11/20/02)
Apr-16 13:29:49    Version 9.00       November 20, 2002
Apr-16 13:29:53    NLM ASDB : BrightStor ARCserve Database is ready
Apr-16 13:29:56
Apr-16 13:29:56    Loading SYS:\ARCserve\NLM\ARCSERVE.NLM
Apr-16 13:29:58    BrightStor ARCserve 9.0 Scheduler (Build  575.009
                   11/14/02)
Apr-16 13:29:58    Version 9.00       November 14, 2002
Apr-16 13:30:04    BrightStor ARCserve scheduler is ready
Apr-16 13:30:07
Apr-16 13:30:08    Loading SYS:\ARCserve\NLM\POOLUTIL.NLM
Apr-16 13:30:09    CA File System Pool Utility Module (Build  575.013
                   11/20/02)
Apr-16 13:30:10    Version 9.00       November 20, 2002
Apr-16 13:30:10    Module SYS:\ARCserve\NLM\POOLUTIL.NLM was loaded
                   successfully.
Apr-16 13:30:11
Apr-16 13:30:11    Loading SYS:\ARCserve\NLM\DISCOVER.NLM
Apr-16 13:30:13    CA Discovery Module (Build  575.004 11/06/02)
Apr-16 13:30:14    Version 9.00       November 6, 2002
Apr-16 13:30:14    Module SYS:\ARCserve\NLM\DISCOVER.NLM was loaded
                   successfully.
Apr-16 13:30:14
Apr-16 13:30:15    Loading SYS:\ARCserve\NLM\TAPESVR.NLM
Apr-16 13:30:16    ARCserve 6 SCSI Tape Driver (Build 96.016 01/20/99)
Apr-16 13:30:16    Version 6.10       January 20, 1999
Apr-16 13:30:16    Loading TAPESVR.NLM, Computer Associates release...
Apr-16 13:33:24    CSLOADER.NLM : Module SYS:\ARCserve\NLM\TAPESVR.NLM did
                   not load. Please switch to the Console Screen for more
                   information.
[ Voor 1% gewijzigd door Koffie op 16-04-2003 16:16 ]
Dit is trouwens nog een test met een tapesvr.nlm van een oudere versie want die van versie 9 werkte helemaal niet, bij versie 6 word hij af en toe gestart, maar ziet dan geen adapter en ook geen devices. Dus ja misschien kan je er nu wat meer mee.
Ik heb heel veel gelezen over het aanpassen van asconfig.ini maar wist niet zeker of dat wel het goeie was.
  • paulhekje
  • Laatst online: 23-10 09:19
is je tape unit wel goed aangesloten, termination?
|=|=|=||=|=|=||=|=|=| http://www.vanwijck.com |=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=|
ja dat is in ieder geval in orde anders had ik dit niet gekregen..
021 Is Registered
10/31/02)
Heb je misschien een tape library option die je kan gebruiken ?
ja die heb ik via de client in windows, maar deze ziet ook geen tapedrive, terwijl deze wel goed staat op de server. Het enige probleem wat ik heb is dat tapesvr.nlm niet geladen word, en daardoor ziet de client waarschijnlijk de tape niet. Op de website van Arcserve, staan heel wat updates voor deze tapesvr.nlm en standard.nlm, maar dit zijn allemaal updates voor de 7.0 terwijl ik werk met de 9.0 versie van arcserve. Wie weet dan een plek waar ik een update kan downen voor die 9.0 ?
Hier kan nu een slotje op, want heb probleem zelf op weten te lossen. Ik had eerst het programma arcserve geinstalleerd op de server en daarna nwtape.cdm geladen. Hierdoor snapte arcserve het niet, dus nu ik een reinstall heb gedaan wel..
Als nog bedankt voor jullie hulp
