[gentoo] Pinnacle PCTV Rave . geen kanalen
ok ik heb dus dat kaartje
is nix mis mee werkt onder win maar nu gentoo
maar als ik scantv draait vind hij helemaal nix
met pal en west-europa als instellingen
ik heb i2c en v4l modules gemaakt enzo
m`n modules.autoload ziet er zo uit
(als ik het in modules.conf zet gebeurt er nix gentoo reset die file weer terug naar wat het eerst was)
# i2c
alias char-major-89     i2c-dev
options i2c-core        i2c_debug=1
options i2c-algo-bit    bit_test=1
# bttv
alias char-major-81     videodev
alias char-major-81-0   bttv
options bttv            card=39 radio=0
options tuner           debug=1
verder ziet lsmod erzo uit
tuner                   8384   1  (autoclean)
tvaudio                11164   0  (autoclean) (unused)
bttv                   63200   0
videodev                5568   2  [bttv]
i2c-algo-bit            6536   1  [bttv]
i2c-dev                 3908   0  (unused)
i2c-core               12228   0  [tuner tvaudio bttv i2c-algo-bit i2c-dev]
dmesg zegt dit
29
30
31
32
33
34
35
36
37
38
i2c-core.o: i2c core module
i2c-dev.o: i2c /dev entries driver module
i2c-core.o: driver i2c-dev dummy driver registered.
i2c-algo-bit.o: i2c bit algorithm module
Linux video capture interface: v1.00
bttv: driver version 0.7.91 loaded
bttv: using 2 buffers with 2080k (4160k total) for capture
bttv: Host bridge is VIA Technologies, Inc. VT8363/8365 [KT133/KM133]
bttv: Bt8xx card found (0).
PCI: Found IRQ 5 for device 00:09.0
PCI: Sharing IRQ 5 with 00:09.1
bttv0: Bt878 (rev 17) at 00:09.0, irq: 5, latency: 32, memory: 0xe3001000
bttv0: detected: Pinnacle PCTV [card=39], PCI subsystem ID is 11bd:0012
bttv0: using: BT878(Pinnacle PCTV Studio/Ra) [card=39,autodetected]
i2c-algo-bit.o: Adapter: bt848 #0 scl: 1  sda: 1 -- testing...
i2c-algo-bit.o:1 scl: 1  sda: 0
i2c-algo-bit.o:2 scl: 1  sda: 1
i2c-algo-bit.o:3 scl: 0  sda: 1
i2c-algo-bit.o:4 scl: 1  sda: 1
i2c-algo-bit.o: bt848 #0 passed test.
i2c-dev.o: Registered 'bt848 #0' as minor 0
i2c-core.o: adapter bt848 #0 registered as adapter 0.
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: miro: id=31 tuner=4 radio=no stereo=no
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
tvaudio: TV audio decoder + audio/video mux driver
tvaudio: known chips: tda9840,tda9873h,tda9874h/a,tda9850,tda9855,tea6300,tea6420,tda8425,pic16c54 (PV951)
i2c-core.o: driver generic i2c audio driver registered.
i2c-core.o: driver i2c TV tuner driver registered.
tuner: probing bt848 #0 i2c adapter [id=0x10005]
tuner: chip found @ 0xc0
bttv0: i2c attach [client=NoTuner,ok]
i2c-core.o: client [NoTuner] registered to adapter [bt848 #0](pos. 0).
bttv0: registered device video0
bttv0: registered device vbi0
spurious 8259A interrupt: IRQ7.
als ik nu v4l-conf draait krijg ik dit
bash-2.05b# v4l-conf
v4l-conf: using X11 display :0.0
WARNING: Your X-Server has no DGA support.
mode: 1024x768, depth=16, bpp=16, bpl=2048, base=unknown
/dev/video0 [v4l2]: ioctl VIDIOC_QUERYCAP: Invalid argument
WARNING: couldn't find framebuffer base address, try manual
         configuration ("v4l-conf -a <addr>")
/dev/video0 [v4l]: configuration done
geen dga terwijl in m`n /etc/X11/XF86Config dit staat
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
#    SubSection  "extmod"
#      Option    "omit xfree86-dga"   # don't initialise the DGA
#extension
#    EndSubSection
uitgecomment dus hij zou wel geladen moeten worden
raar dus
verder als ik m`n externe dvd speler erop aansluit via s-video
krijg ik ook geen beeld
iemand enig idee ?
  • pinball
pinball
Electric Monk
nog een goede reden om oost- ipv west-europa te kiezen?
Whenever you find that you are on the side of the majority, it is time to reform.
nee sorry ik bedoelde west europa
  • pinball
pinball
Electric Monk
probeer eens wat verschillende 'pll=' (0/1/2) settings in je modules.conf, wil wel eens helpen
options bttv card=39 radio=0 pll=1
[ Voor 6% gewijzigd door pinball op 15-04-2003 19:16 ]
  • Memphisto
  • Laatst online: 17:54
Uhm ik weet niet hoe oud die kaart van jouw is, maar de mijne (pctv, geen rave of pro) is net nieuwen en is schijnbaar iets aan die tuner verandert, dus om de mijne werkend te krijgen gebruik ik de tda9887 tuner.
Ik hoop dat dat voor jouw ook geld
Deep into that darkness peering, long I stood there, wondering, fearing, doubting, dreaming dreams no mortal ever dreamed before.
hmm die van mij is ook net nieuwe
wat is de cardnr daarvan ?
btw
pll werkt niet
[ Voor 17% gewijzigd door Verwijderd op 15-04-2003 20:44 ]
  • Memphisto
Het cardnr heb ik niet mee gegeven (autodetect)
als ik em op autodetect zet krijg ik hetzelfde
  • MikeN
  • Laatst online: 17:41
Verwijderd schreef op 15 April 2003 @ 17:03:
# i2c
# bttv
bttv                   63200   0
Even los van het werkelijke probleem, dit soort moduleopties hoort wel degelijk in je modules.conf. Je kan ze erin krijgen door /etc/modules.d/i386 te editen en daarna update-modules te draaien.
Ik had het zelfde probleem alleen dan met mandrake en me pinnacle, bleek dat de bttv driver niet goed was die ik standaard bij mandrake kreeg (9.1)
Heb toen een nieuwe driver genomen en de boel was gelijk opgelost
hier ook een pctv rave , enigste wat ik doe is modprobe bttv card=39 en enter rammen
kernel opties :
CONFIG_I2C=m
CONFIG_I2C_ALGOBIT=m
CONFIG_I2C_PROC=m
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_PROC_FS=y
CONFIG_VIDEO_BT848=m
ik heb idd die kernel opties niet ingesteld
waar doe ik dat ?
  • Arioch
  • Laatst online: 10-07 18:08
Arioch
<geek>
Verwijderd schreef op 17 April 2003 @ 19:06:
waar doe ik dat ?
vim /usr/src/linux/.config
ik neem aan dat ik dan die kernel opnieuwe moet compilen
:S
andere vraag
scantv zoekt naa east-europ frequency`s maar die zijn naar mijn weten bij elke kabelexploitant verschillen, kan je scantv ook alle frequency`s af laten zoeken ?
Lekker informatief :?
Verwijderd schreef op 15 April 2003 @ 21:47:
Lekker informatief wel :/
waar doe ik dat ?
Basiskennis van je OS
Verwijderd schreef op 22 April 2003 @ 13:07:
:S
MSN smileys werken niet op GoT en dat doet je topic ook al geen goed.
Let er even op dat als je eenmaal een topic hebt getypt die aan de policy voldoet dat dergelijke replies nou niet bepaald bijdragen aan het oplossen van je probleem (weinig informatief) of kunnen veroorzaken dat je topic als nog dicht gaat (basiskennis).
Dus voortaan graag wat meer informatieve replies, zoals het vermelden wat je precies gedaan hebt en wat daarvan het resultaat was met melding. :)
Back ontopic :)
