proxy via script onder linux starten werkt niet
ik heb de dnetc opstart script aangepast voor mijn proxy
swordfish:~# /etc/init.d/proxy
Usage: /etc/init.d/proxy {[-]start|[-]stop|[-]reload}
swordfish:~# /etc/init.d/proxy start
swordfish:~# /etc/init.d/proxy reload
swordfish:~# /etc/init.d/proxy stop
hij werkt zonder problemen
ik heb het volgende gedraaid en rechten gecontroleerd
cd /etc/init.d &&
ln -sf ../init.d/proxy ../rc0.d/K29proxy &&
ln -sf ../init.d/proxy ../rc1.d/K29proxy &&
ln -sf ../init.d/proxy ../rc2.d/K29proxy &&
ln -sf ../init.d/proxy ../rc3.d/S92proxy &&
ln -sf ../init.d/proxy ../rc4.d/S92proxy &&
ln -sf ../init.d/proxy ../rc5.d/S92proxy &&
ln -sf ../init.d/proxy ../rc6.d/K29proxy
als ik dan er na server reboot geeft die aan
cat: /home/victor/proxyper/rc5proxy.pid: No such file or directory
kill: usage: kill [-s sigspec | -n signum | -sigspec] [pid | job]... or kill -l [sigspec]
dit is logisch als proxy niet draait
maar bij opstarten start de proxy niet op
wie weet wat ik fout doe?
29
30
31
32
33
swordfish:~# cat /etc/init.d/dnetc
#! /bin/sh
# distributed.net client startup/shutdown script generated by 'dnetc -install'
# Use 'dnetc -uninstall' to stop the client from being started automatically.
# Don't forget to change buffer/.ini file perms if you wish to run suid'd.
CLIENT=/usr/dnetc/dnetc
STARTOPTS="-ini ${CLIENT}.ini"
#STARTOPTS will need to be in quotes if it has white space in it
test -f $CLIENT || exit 0
case "$1" in
        *start)
                $CLIENT -quiet -shutdown  # only allow one instance to run.
                $CLIENT -quiet $STARTOPTS # -quiet is 'mandatory' here.
        *stop)  # sends SIGTERM to all running clients.
                $CLIENT -quiet -shutdown  # remove '-quiet' to see activity.
        *reload)        # sends SIGHUP to all running clients.
                $CLIENT -quiet -restart   # remove '-quiet' to see activity.
                echo "Usage: $0 {[-]start|[-]stop|[-]reload}"
                exit 1
esac
exit 0
29
30
31
32
33
34
swordfish:~# cat /etc/init.d/proxy
#! /bin/sh
#CLIENT=/usr/dnetc/dnetc
CLIENT=/home/victor/proxyper/proxyper
#STARTOPTS="-ini ${CLIENT}.ini"
case "$1" in
        *start)
                $CLIENT -hide
                kill `cat /home/victor/proxyper/rc5proxy.pid`
                $CLIENT -hide
                exit 1
esac
exit 0
[ Voor 5% gewijzigd door Verwijderd op 13-04-2003 01:02 ]
Verwijderd schreef op 13 April 2003 @ 00:59:
case "$1" in
        *start)
                $CLIENT -hide
                $CLIENT -hide
                exit 1
Begin es met die '*' weg te halen voor je start/stop/reload cases. Dus 'start)', 'stop)' en 'reload)' ipv '*start)', '*stop)' etc...
:( helpt niet
  • bkor
Draai je nogsteeds Debian? Die start dacht ik in runlevel 2 (zie /etc/inittab) ipv 3 of 5 zoals RedHat/Mandrake. De foutmelding geeft al aan dat de proxy wordt gestopt ipv gestart.
Volgende regel is dus fout als ut Debian is (moet een S zijn):
bkor thanx dat werkt :)
