Ik heb net een Debian (woody) install gedaan.
Alles ging goed alleen kan ik de x server niet starten.
ik krijg in mn log file deze foutmelding.
"(EE) Screen(s) found, but none have a usable configuration."
ik weet alleen niet echt wat ik daar mee aan moet.
ik heb een dell 17fs-en monitor en een geforce 2 mx kaart
Hieronder staan de log file, en de XF86Config-4 file.
Ik ben blij met alle hulp, want ik ben op dit moment op windows aangewezen
(/var/log/XFree86.0.log)
This is a pre-release version of XFree86, and is not supported in any
way. Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org. Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.4.17 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Fri Apr 11 18:22:59 2003
(==) Using config file: "/etc/X11/XF86Config-4"
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "nvidia video card"
(**) |-->Input Device "Generic Keyboard"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc101"
(**) XKB: model: "pc101"
(**) Option "XkbLayout" "us"
(**) XKB: layout: "us"
(==) Keyboard: CustomKeycode disabled
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Generic Mouse"
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
Entry deleted from font path.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/Speedo,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(++) using VT number 7
(WW) Cannot open APM
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.4
XFree86 XInput driver : 0.2
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.4
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0305 card 1043,8033 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8305 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:04:0: chip 1106,0686 card 1043,8033 rev 22 class 06,01,00 hdr 80
(II) PCI: 00:04:1: chip 1106,0571 card 0000,0000 rev 10 class 01,01,8a hdr 00
(II) PCI: 00:04:2: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
(II) PCI: 00:04:3: chip 1106,3038 card 0925,1234 rev 10 class 0c,03,00 hdr 00
(II) PCI: 00:04:4: chip 1106,3057 card 0000,0000 rev 30 class 06,00,00 hdr 00
(II) PCI: 00:0a:0: chip 13f6,0111 card 13f6,0111 rev 10 class 04,01,00 hdr 00
(II) PCI: 00:11:0: chip 105a,0d30 card 105a,4d33 rev 02 class 01,80,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0110 card 14af,7103 rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 1 I/O range:
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd6000000 - 0xd7dfffff (0x1e00000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd7f00000 - 0xe3ffffff (0xc100000) MX[B]
(II) Bus -1: bridge is at (0:4:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(II) Bus -1: bridge is at (0:0:0), (-1,-1,0), BCTRL: 0x08 (VGA_EN is set)
(--) PCI:*(1:0:0) NVidia GeForce2 MX rev 161, Mem @ 0xd6000000/24, 0xd8000000/27, BIOS @ 0xd7ff0000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xd5800000 - 0xd5ffffff (0x800000) MX[B]E
[1] -1 0 0xe4000000 - 0xe7ffffff (0x4000000) MX[B]E
[2] -1 0 0xd7ff0000 - 0xd7ffffff (0x10000) MX[B](
[3] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MX[B](
[4] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MX[B](
[5] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]E
[6] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]E
[7] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]E
[8] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]E
[9] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
[10] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
[11] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]E
[12] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]E
[13] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]E
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xd5800000 - 0xd5ffffff (0x800000) MX[B]E
[6] -1 0 0xe4000000 - 0xe7ffffff (0x4000000) MX[B]E
[7] -1 0 0xd7ff0000 - 0xd7ffffff (0x10000) MX[B](
[8] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MX[B](
[9] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MX[B](
[10] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[11] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[12] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]E
[13] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]E
[14] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]E
[15] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]E
[16] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
[17] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
[18] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]E
[19] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]E
[20] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]E
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
ABI class: XFree86 Server Extension, version 0.1
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.1.9
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) LoadModule: "pex5"
(II) Loading /usr/X11R6/lib/modules/extensions/libpex5.a
(II) Module pex5: vendor="The XFree86 Project"
(II) Loading extension X3D-PEX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "speedo"
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading font Speedo
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) LoadModule: "xie"
(II) Loading /usr/X11R6/lib/modules/extensions/libxie.a
(II) Module xie: vendor="The XFree86 Project"
(II) Loading extension XIE
(II) LoadModule: "nv"
(II) Loading /usr/X11R6/lib/modules/drivers/nv_drv.o
(II) Module nv: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.0.1
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.2
(II) NV: driver for NVIDIA chipsets: RIVA128, RIVATNT, RIVATNT2,
RIVATNT2 (A), RIVATNT2 (
, RIVATNT2 (Ultra), RIVATNT2 (Vanta),
RIVATNT2 M64, RIVATNT2 (Integrated), GeForce 256, GeForce DDR,
Quadro, GeForce2 GTS, GeForce2 GTS (rev 1), GeForce2 ultra,
Quadro 2 Pro, GeForce2 MX, GeForce2 MX DDR, Quadro 2 MXR,
GeForce 2 Go, GeForce3, GeForce3 (rev 1), GeForce3 (rev 2),
GeForce3 (rev 3)
(II) Primary Device is: PCI 01:00:0
(--) Chipset GeForce2 MX found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[10] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[11] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[12] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]E
[16] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]E
[17] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]E
[18] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]E
[19] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]E
[20] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]E
[21] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]E
[22] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]E
[23] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]E
[24] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[25] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) Reloading /usr/X11R6/lib/modules/linux/libint10.a
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(--) NV(0): Chipset: "GeForce2 MX"
(**) NV(0): Depth 24, (--) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
(**) NV(0): Option "UseFBDev" "true"
(==) NV(0): Using HW cursor
(**) NV(0): Using framebuffer device
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/X11R6/lib/modules/linux/libfbdevhw.a
(II) Module fbdevhw: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 0.0.2
(II) UnloadModule: "nv"
(II) UnloadModule: "fbdevhw"
(II) Unloading /usr/X11R6/lib/modules/linux/libfbdevhw.a
(II) UnloadModule: "vgahw"
(II) Unloading /usr/X11R6/lib/modules/libvgahw.a
(II) UnloadModule: "int10"
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
en dan nu de config file
(/etc/X11/XF86Config-4
### BEGIN DEBCONF SECTION
# XF86Config-4 (XFree86 server configuration file) generated by dexconf, the
# Debian X Configuration tool, using values from the debconf database.
# Edit this file with caution, and see the XF86Config-4 manual page.
# (Type "man XF86Config-4" at the shell prompt.)
# If you want your changes to this file preserved by dexconf, only make changes
# before the "### BEGIN DEBCONF SECTION" line above, and/or after the
# "### END DEBCONF SECTION" line below.
# To change things within the debconf section, run the command:
# dpkg-reconfigure xserver-xfree86
# as root. Also see "How do I add custom sections to a dexconf-generated
# XF86Config or XF86Config-4 file?" in /usr/share/doc/xfree86-common/FAQ.gz.
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "pex5"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
Load "xie"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/psaux"
Option "Protocol" "PS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Generic Mouse"
Driver "mouse"
Option "SendCoreEvents" "true"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
EndSection
Section "Device"
Identifier "nvidia video card"
Driver "nv"
BusID "PCI:01:00:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
HorizSync 30-64
VertRefresh 50-130
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Generic Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
GeForce3 (rev 3)
Fatal server error:
no screens found
Section "Files"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "pex5"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
Load "xie"
EndSection
Driver "keyboard"
EndSection
Driver "mouse"
EndSection
Driver "mouse"
EndSection
Section "Device"
Driver "nv"
BusID "PCI:01:00:0"
EndSection
Section "Monitor"
HorizSync 30-64
VertRefresh 50-130
Option "DPMS"
EndSection
Section "Screen"
DefaultDepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
EndSection
Section "DRI"
Mode 0666
EndSection
