Het grote Leadtek K7NCR18D Pro topic
  • 53 views sinds 30-01-2008
  • Chickendorp
<table width="538" border="0" cellspacing="1" cellpadding="2" class="text" bgcolor="#999999" align="center">
<tr valign="top">
<td width="140" bgcolor="#eeeeee" class="text-red">Form
factor </td>
<td bgcolor="#eeeeee" >ATX 304.8mm x 243mm
(12"x 9.6")</td>
</tr>
<tr valign="top">
<td width="140" rowspan="2" bgcolor="#FFFFFF" class="text-red">CPU
Support </td>
<td bgcolor="#FFFFFF">AMD Athlon/XP/Barton,
Duron Socket A processors</td>
</tr>
<tr valign="top" bgcolor="#FFFFFF">
<td>CPU Bus Frequency range: 200 to 333MHz
(DDR)</td>
</tr>
<tr valign="top">
<td width="140" bgcolor="#eeeeee" height="33" class="text-red">Platform
Processors </td>
<td bgcolor="#eeeeee"> NVIDIA nForce2-ST(nForce2
SPP + nForce2 MCP-T)</td>
</tr>
<tr valign="top">
<td width="140" bgcolor="#FFFFFF" class="text-red">CPU/MEMORY/PCI
clock</td>
<td bgcolor="#FFFFFF">CPU Bus Frequency
range: 200 to 333MHz (DDR)</td>
</tr>
<tr valign="top">
<td width="140" rowspan="2" bgcolor="#FFFFFF" class="text-red">Main
Memory </td>
<td bgcolor="#FFFFFF">Supports 3 184 -pin
DIMM sockets for DDR -SDRAM module (PC2100,
PC2700, PC3200)</td>
</tr>
<td>Support up to 3GB of memory</td>
</tr>
<tr valign="top">
<td width="140" rowspan="3" bgcolor="#eeeeee" class="text-red">Expansion
slots</td>
<td bgcolor="#eeeeee">1 x 32bit 8X AGP
slot.</td>
</tr>
<tr valign="top" bgcolor="#eeeeee">
<td>4 x 32bit PCI slot.</td>
</tr>
<td>1 x ACR slot.</td>
</tr>
<tr valign="top">
<td width="140" bgcolor="#FFFFFF" class="text-red">Adjustment
for Best performance setting</td>
<td bgcolor="#FFFFFF">Adjustable CPU clock(100~200MHz)/
ratio(max to 24x). Vcore(1.1~2.0V),Vmem(2.5~2.7V),
AGP Vddq(+0.2V & +0.1V).</td>
</tr>
<tr valign="top">
<td width="140" rowspan="2" bgcolor="#eeeeee" class="text-red">Two
Ultra ATA 33/66/100/133 IDE ports </td>
<td bgcolor="#eeeeee">Supports up to PIO
mode 4, Multi-word DMA mode2 and Ultra
ATA 66/100/133 MB/Sec</td>
</tr>
<td>Bus master drivers for most well-known
OS</td>
</tr>
<tr valign="top">
<td width="140" rowspan="7" bgcolor="#FFFFFF" class="text-red">Double
stack back-panel I/O connectors </td>
<td bgcolor="#FFFFFF">PS/2 Mini-Din mouse
& keyboard ports</td>
</tr>
<td>RJ45 connector (Lan version only)</td>
</tr>
<td>Four USB2.0 Ports</td>
</tr>
<td>One External Bracket with two USB2.0
ports (Optional)</td>
</tr>
<td>One 25pin D-SUB female printer port</td>
</tr>
<td>Two 9pin D-SUB male serial port for
COM1 & COM2</td>
</tr>
<td width="200">Line_In, Line_Out and
Mic_In jacks</td>
</tr>
<tr valign="top">
<td width="140" rowspan="4" bgcolor="#eeeeee" class="text-red">System
BIOS </td>
<td bgcolor="#eeeeee">AWARD BIOS, supports
PnP, APM, Multi-Device booting features
(Floppy, LS120, CD-ROM, IDE, SCSI, ZIP,
ATAPI)</td>
</tr>
<td>Supports ACPI 1.0b (Advanced Configuration
Power Interface): S1, S3 (Suspend to
RAM), S4 ( Suspend to DISK )</td>
</tr>
<td>Boot-up anti-virus support</td>
</tr>
<td>2MB flash ROM</td>
</tr>
<tr valign="top">
<td width="140" bgcolor="#FFFFFF" class="text-red">Speed
Gear II Hardware Monitor</td>
<td bgcolor="#FFFFFF">Hardware Monitor
provides main system information. You
can read CPU/System Fan speed and temperature
to provide the best overclocking capacity
from Hardware Monitor.</td>
</tr>
<tr valign="top">
<td width="140" rowspan="3" bgcolor="#eeeeee" class="text-red">BIOS
PC Health hardware monitoring</td>
<td bgcolor="#eeeeee">Two thermal sensors
protecting CPU and system</td>
</tr>
<td bgcolor="#eeeeee">5 voltages monitoring
input (+3.3V, +5V, Vddq, Vmem, Vcore)</td>
</tr>
<td bgcolor="#eeeeee"> With AMD XP series
CPU, built-in CPU over temperature shutdown
(O.T.S.) and overheated warning message
functions to protect CPU from burnout.
According to O.T.S. function, a temperature
warning message window is going to pop-up
as long as CPU is overheated, meanwhile,
your system will be immediately shutdown
to protect CPU from burnout.</td>
</tr>
<tr valign="top">
<td width="140" rowspan="9" bgcolor="#FFFFFF" class="text-red">Package
contents</td>
<td bgcolor="#FFFFFF">WinFast K7NCR18D-Pro
socket A motherboard </td>
</tr>
<td bgcolor="#FFFFFF">WinFast software
pack CD</td>
</tr>
<td bgcolor="#FFFFFF">User's manual</td>
</tr>
<td bgcolor="#FFFFFF">Ultra ATA 100/133
IDE cable</td>
</tr>
<td bgcolor="#FFFFFF">720KB / 1.44MB /
2.88MB Floppy connecting cable</td>
</tr>
<td bgcolor="#FFFFFF">USB module (Optional)</td>
</tr>
<td bgcolor="#FFFFFF">IEEE1394 ACR card</td>
</tr>
<td bgcolor="#FFFFFF">SPDIF output RCA
jack bracket</td>
</tr>
<td bgcolor="#FFFFFF">Bundled Ulead Video
Studio6.0 and Cool 3D 3.0 editing software</td>
</tr>
<tr valign="top">
<td width="140" bgcolor="#eeeeee" class="text-red">CPU
Support </td>
<table width="398" border="0" cellspacing="1" cellpadding="2" bgcolor="#666666" class="channel">
<tr bgcolor="#eeeeee">
<td>
<div align="center">VENDER</div>
</td>
<td>
<div align="center">CPU Model</div>
</td>
<td>
<div align="center">L2 Cache</div>
</td>
<td>
<div align="center">Clock(MHz)</div>
</td>
<td>
<div align="center">Multiplier</div>
</td>
</tr>
<tr bgcolor="#FFFFFF">
<td>
<div align="center">AMD</div>
</td>
<td>
<div align="center">Duron 1.3G</div>
</td>
<td>
<div align="center">64</div>
</td>
<td>
<div align="center">100</div>
</td>
<td>
<div align="center">13</div>
</td>
</tr>
<td>
</td>
<td>
<div align="center">Duron 1.2G</div>
</td>
<td>
</td>
<td>
</td>
<td>
<div align="center">12</div>
</td>
</tr>
<td>
</td>
<td>
<div align="center">Duron 1G</div>
</td>
<td>
</td>
<td>
</td>
<td>
<div align="center">10</div>
</td>
</tr>
<td>
</td>
<td>
<div align="center">Athlon 1.4
G</div>
</td>
<td>
<div align="center">256</div>
</td>
<td>
<div align="center">133</div>
</td>
<td>
<div align="center">10.5</div>
</td>
</tr>
<td>
</td>
<td>
<div align="center">Athlon Xp
1400+</div>
</td>
<td>
</td>
<td>
</td>
<td>
</td>
</tr>
<td>
</td>
<td>
1600+</div>
</td>
<td>
</td>
<td>
</td>
<td>
</td>
</tr>
<td>
</td>
<td>
1700+</div>
</td>
<td>
</td>
<td>
</td>
<td>
<div align="center">11</div>
</td>
</tr>
<td>
</td>
<td>
1900+</div>
</td>
<td>
</td>
<td>
</td>
<td>
</td>
</tr>
<td>
</td>
<td>
1800+</div>
</td>
<td>
</td>
<td>
</td>
<td>
<div align="center">11.5</div>
</td>
</tr>
<td>
</td>
<td>
2100+</div>
</td>
<td>
</td>
<td>
</td>
<td>
</td>
</tr>
<td>
</td>
<td>
2200+</div>
</td>
<td>
</td>
<td>
</td>
<td>
<div align="center">13.5</div>
</td>
</tr>
<td>
</td>
<td>
2400+</div>
</td>
<td>
</td>
<td>
</td>
<td>
<div align="center">15</div>
</td>
</tr>
<td>
</td>
<td>
2600+</div>
</td>
<td>
</td>
<td>
<div align="center">166</div>
</td>
<td>
<div align="center">12.5</div>
</td>
</tr>
<td>
</td>
<td>
2700+</div>
</td>
<td>
</td>
<td>
</td>
<td>
</td>
</tr>
<td>
</td>
<td>
2800+</div>
</td>
<td>
<div align="center">512</div>
</td>
<td>
</td>
<td>
</td>
</tr>
<td>
</td>
<td>
3000+</div>
</td>
<td>
</td>
<td>
</td>
<td>
</td>
</tr>
</table>
</td>
</tr>
</table>
</td>
</tr>
</table>
</td>
</tr>
<tr>
<td bgcolor="#FFFFFF" background="../image/g.4.1.gif">[img]"../image/space.gif"[/img]</td>
</tr>
<tr>
<td bgcolor="#EEEEEE">
<table width="558" border="0" cellspacing="0" cellpadding="2">
<tr>
<td align="center" width="140"><a href="winfast_k7ncr18dpro_1.html" class="title4">overview
& feature</a></td>
<td align="center" class="title6" bgcolor="#cc0000" width="140">specification</td>
<td align="center">
<!--<a href="winfast_k7ncr18dpro_3.html" class="title4">review</a>-->
</td>
<td align="center">
<!--<a href="winfast_k7ncr18dpro_4.html" class="title4">technology supports</a>-->
</td>
</tr>
</table>
</td>
</tr>
</table>
</td>
</tr>
</table>
<table width="560" border="0" cellspacing="0" cellpadding="3" align="center">
<tr>
<td align="right"><a href="../support/download.asp?pronameid=273&lineid=3">[img]"../image/download.gif"[/img]</a><a href="#">[img]"../image/buy.gif"[/img][img]"../image/mail.gif"[/img]</a><a href="#">[img]"../image/print.gif"[/img]</a></td>
</tr>
</table>
</td>
</tr>
<tr>
<td height="30">
<table width="570" border="0" cellspacing="0" cellpadding="0" align="center" class="text3">
<tr>
<td width="530"><a href="../index.html" class="text3">HOME</a> > <a href="../product.html" class="text3">PRODUCTS</a>
> <a href="../motherboard.html" class="text3">MOTHERBOARD</a> > <a href="winfast_k7ncr18dpro_1.html" class="text3">WINFAST K7NCR18D PRO</a> > SPECIFICATION</td>
<td width="40"><a href="#top">[img]"../image/gotop.gif"[/img]</a></td>
</tr>
</table>
</td>
</tr>
</table>
<!-- #EndEditable -->
</td>
</tr>
</table>
</td>
</tr>
  • Abbadon
  • Laatst online: 11:24
:? Vind je het erg dat ik deze dicht doe, hier snapt niemand een jota van :+
