[PC]Warcraft 3 Strategy's
  • 90 views sinds 30-01-2008
eejz, ik speel WC3 nu al een tijdje, en heb een best goede strategy gevonden :)
tzou leuk zijn als iedereen hier gevonden of gemaakt strats invoerd.
Night Elf Strategy: Chimaera Rush!
Strategy submitted by Titties
This detailed Chimaera rush strategy will certainly catch your opponent off guard if done correctly. It even tells you how to keep your opponent busy while teching, and includes information on which heroes to use.
Upgrade the Tree of Life(yes, right away).
Build an altar with one wisp.
Put two wisps on wood and two on gold.
When the altar is done, make a keeper of the grove.
Make a Moonwell with the wisp that made the Altar.
When you have 90 wood, click on the wisp that is going to get a little 5 over it next, when it does that put it on gold, do the same with the other one,(that means that you have 100 wood) When the moon well is done put the wisp on gold.
Make a Demon Hunter as now you can do it!
Your keeper should be one second from completion. He should get the spell entagleing roots, and go to the enemys base.
Build two wisps when you have the money. (put all the wisps made on wood)
Make two more wisps.
Take two wisps out of gold and on wood.
Keep your enemy busy with your hero, do hit and run attacks, dont let your hero die though!
Entangle peasants making buidings, this will prevent them from making the buildings.
Now while you do that make a moonwell, put two wisps on gold.
Get Mana Burn for your demon hunter, and mana burn your enemys hero(s).
Build about 22/30 wisps before upgrading the tree of ages. (upgrade tree then)
Build two moonwells.
Allways keep your enemy busy with your heros so he cant leave his base.
Build an Ancient of Wind when the Tree upgrade is half way done.
After the Upgrade is complete build two Chimaera Roosts.
When The chimaera roosts are done start making chimaeras.
Make about four or six of them before attacking.
Buy a Wand of negation to get all the bad buff spells off your chimaeras. Enjoy!
This strategy will work best on humans, because they usually build many footmen, that dont have ranged attacks to damage your heros so much.
iets wat ook stoer is met night elfs is het volgendee:
bouw n ancient of war bij t kamp van de tegenpartij (maar zorg dat ze je niet zien)
zorg voor een hero, en tegen ded tijd dat je hero klaar is voor 2 archers bij je AoW
daarna ga je daar nog een AoW bouwen. Tegen de tijd dat je daar een hero en een AoW hebt, bouw je in je eigen kamp een huntress hall.
en dan nu komt t
Als het goed is heb je voor de Keeper of the Groove gekozen, met als skill Treants.
Uproot je AoW en val met al je troops de vijand aan., zorg dat je archers en hero bij je AoW in de buurt zijn, en summon wat treants als afleiding voor de AoW.
Blijf ondertussen huntress bouwen bij je AoW, en bouw er voor zekerheid nog een AoW bij.
je Aow is een super sterke unit aan het begin, hij heeft 1000hp, en doet 44 dammage.
  • agentorangina
  • Laatst online: 20-08-2024
Hmmm.. ik zie hier al meteen Lame elf tactic #1, AoW's. Gelukkig werkt het niet meer in de expansion :) .
voor War3 is er ook een grote topic, daar kan je beter posten.
http://gathering.tweakers.net/forum/list_messages/721116
mjah maar dat vind ik een beetje te groot topic :) dis meer om strategy's met elkaar uit te wisselen. En waarom is AoW lame? dan is een Dot attack ook lame zeker :P
  • The Will
  • Registratie: Mei 2001
  • Laatst online: 17:45
Mja, ik denk toch dat het beter in het grote WC3 topic kan. :)
There is no magic.
