Geluid laat computer crashen
Comp gegevens :
Processor(s)
Model : AMD Athlon(tm) XP 2400+
Speed : 2.01GHz
Model Number : 2400 (estimated)
Performance Rating : PR2907 (estimated)
Type : Standard
L2 On-board Cache : 256kB ECC synchronous write-back
System Mainboard
Bus(es) : ISA AGP PCI USB
MP Support : No
System BIOS : Phoenix Technologies, LTD 6.00 PG
System Mainboard : nVidia-nForce
System Chipset : Nvidia Corp Unknown (01E0)
Front Side Bus Speed : 2x 134MHz (268MHz data rate)
Installed Memory : 512MB
Video System
Monitor/Panel : Iiyama HM903DT, VisionMaster Pro 454
Adapter : NVIDIA GeForce2 MX/MX 400 (Microsoft Corporation)
Physical Storage Devices
Removable Drive : Floppy disk drive
Disk Drive : Maxtor 6 Y060L0 SCSI Disk Device (57.3GB)
Disk Drive : Promise 1+0 Stripe/RAID0 SCSI Disk Device (57.3GB)
Disk Drive : ST330630 A SCSI Disk Device (28.5GB)
CD-ROM/DVD : E-IDE CD -956E/AKV SCSI CdRom Device (CD 52X Rd)
Logical Storage Devices
1.44MB 3.5" (A:) : N/A
Hard Disk (C:) : 8.4GB (5.4GB, 65% Free) (FAT32)
Hard Disk (D:) : 57.3GB (8.7GB, 15% Free) (NTFS)
Hard Disk (E:) : 28.5GB (21.8GB, 77% Free) (FAT32)
Hard Disk (F:) : 48.9GB (17.6GB, 36% Free) (NTFS)
CD-ROM/DVD (Z:) : 447MB (0MB, 0% Free) (CDFS)
MultiMedia Device(s)
Device : Standard Game Port
Device : Creative AudioPCI (ES1371,ES1373) (WDM)
Operating System(s)
Windows System : Microsoft Windows XP Professional Ver 5.01.2600 Service Pack 1
Network Adapter(s)
Networking Installed : Yes
Adapter : NVIDIA nForce MCP Networking Adapter
Adapter : Realtek RTL8139 Family PCI Fast Ethernet NIC
IRQ gegevens :
0 : System timer
1 : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
3 : COM2
3 : Communications Port (COM2)
4 : COM1
4 : Communications Port (COM1)
6 : Standard floppy disk controller
8 : System CMOS/real time clock
9 : Microsoft ACPI-Compliant System
11 : NVIDIA nForce PCI System Management
12 : PS/2 Compatible Mouse
13 : Numeric data processor
14 : Primary nForce™ IDE Channel
15 : Secondary nForce™ IDE Channel
16 : Win XP Promise FastTrak 376 (tm) Controller
17 : Realtek RTL8139 Family PCI Fast Ethernet NIC
19 : Creative AudioPCI (ES1371,ES1373) (WDM)
19 : NVIDIA GeForce2 MX/MX 400 (Microsoft Corporation)
22 : NVIDIA nForce MCP Networking Adapter
Het probleem :
Bij het afspelen van geluid, in welk formaat of met welk programma ook, is er 30% kans dat de computer hangt
Werkzaamheden tot nu toe :
Andere geluidskaart : geen effect
Herinstallie windows : geen effect
Controle bad sectors : niks gevonden
Mijn ideeen zijn op op dit moment, wie heeft dit al een keer meegemaakt
Als je een onboard geluidschip naast deze kaart hebt moet je deze misschien disablen in de bios.
Verder kan je de geluidskaart even in een ander PCI slot proberen.
Je zou voor de zekerheid ook ff het geheugen kunnen testen met bijvoorbeeld memtest.
[ Voor 56% gewijzigd door Verwijderd op 05-04-2003 18:25 ]
Zowel bij de onboard audio als een pci kaart is hetzelfde probleem
Verwijderd schreef op 05 April 2003 @ 18:26:
Maar probeer eens de onboard chip uit te schakelen in de bios. Anders ff een andere PCI gleuf proberen. Ik schat de kans niet groot dat dat het probleem is, maar je weet nooit.
  • Mike Jarod
Kijk eens in je logfiles of je iets ziet wat er mee te maken heeft? (deze comp>rechtermuis>beheren>logboeken)
Computer maakt geen logs van de crashes helaas, daar heeft die geen tijd voor. Verder zijn geen er warnings of errors te zien
De bios Audio had ik al uitgeschakeld tijd ik de eerste PCI kaart probeerde. Helaas bleef het probleem
  • NaliXL
  • Laatst online: 30-07 19:19
Die onboard geluidskaart en de ingebouwde, hebben die niet dezelfde chipset toevallig? In dat geval kan het natuurlijk ook een driver-probleem zijn. Hoe dan ook : ik zie dat je een NForce chipset hebt. Die heeft bij mijn weten hardware-acceleratie, die live in Dolby Digital kan encoden en naar de S/PDIF sturen. Misschien dat dat problemen veroorzaakt? Kun je misschien die acceleratie uitschakelen?
Genoeg is meer dan veel, en tart den overvloed
Kan maar alleen als ik die optie zou kunnen vinden en tot nu toe hab zoiets nog niet gezien
NaliXL schreef op 05 April 2003 @ 18:39:
Ik neem aan dat wanneer je de gehele geluidschip uitschakelt in de bios, dat de acceleratie ook uit staat, of zeg ik nu iets geks?
Probeer nog ff een andere pci gleuf en memtest. Ik heb met mijn Soundblaster 1024 ook wel eens problemen gehad die verholpen werden door hem in een ander PCI slot te zetten.
  • Mike Jarod
BIOS update/downgrade?
Load BIOS defaults?
DirectX opnieuw installeren?
Tja tis misschien een gedoe, maar als je nog een andere HD hebt zou je eens 98se oid kunnen installen, kijken of ie dan ook nog vastloopt. Zo ja dan hardware probleem.
Zo maar wat kreten ;)
Memory getest en is goed, de pci kaart ga ik dan nu in een ander slot zetten
  • Mike Jarod
Wat voor mobo heb je eigenlijk? Dat zie ik namelijk niet staan in bovenstaande tekst. Kijk ook hier eens: Tikken in geluid Soundmax.
  • Tags NL
  • Registratie: December 1999
  • Laatst online: 13-09 00:15
Tags NL
Harmful or Harmless?
Sorry voor het posten in dit oude topic, maar mijn broertje had een vergelijkbaar probleem. De oplossing was daar het updaten van de driver voor de Fasttrak 376 controller. Met de versie 1.0.0.19 had hij een storend/haperend geluid en hing de computer soms, met versie 1.0.0.29 was het probleem opgelost. De driver is af te halen op msi.com.tw onder support/driver/mainboard ide...
https://powershellisfun.com
