[slack9]divx wil niet afspelen onder user
  • Slaiter
Slaiter
Firesnake
Ik gebruik mplayer om o.a. avi af te spelen, maar als ik een avi inlaad onder user krijg ik de melding dat er geen file is:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
Using GNU internationalization
Original domain: messages
Original dirname: /usr/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MPlayer 0.90rc4-3.2.2 (C) 2000-2003 Arpad Gereoffy (see DOCS)
CPU: Advanced Micro Devices Athlon 4 PM Palomino
/Athlon MP Multiprocessor/Athlon XP eXtreme Performance (Family: 6, Stepping: 2)
Detected cache-line size is 64 bytes
CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE
Reading config file /usr/local/etc/mplayer/mplayer.conf: No such file or directory
Reading config file /home/slaiter/.mplayer/config
[cfg] read config file: /home/slaiter/.mplayer/gui.conf
Reading config file /home/slaiter/.mplayer/gui.conf
vo: X11 running at 1152x864 with depth 24 and 32 bpp (":0.0" => local display)
Reading /home/slaiter/.mplayer/codecs.conf:
can't open '/home/slaiter/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: 50 audio & 135 video codecs
Font /home/slaiter/.mplayer/font/font.desc loaded successfully! (206 chars)
Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Using usleep() timing
Can't open input config file /home/slaiter/.mplayer/input.conf : No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
Falling back on default (hardcoded) input config
SKIN dir 1: '/home/slaiter/.mplayer/Skin'
SKIN dir 2: '/usr/local/share/mplayer/Skin'
Playing /home/slaiter/Blade 2 [DVD-Rip].avi
File not found: '/home/slaiter/Blade 2 [DVD-Rip].avi'
Exiting... (Quit)
ik heb al geprobeerd de avi te chmoden, maar ook daarmee geen resultaat. Dat de file goed is weet ik zeker onder root speelt hij nl zonder problemen af, maar ik wil avi bestandjes ook gewoon onder normale user kunnen afspelen.
Gewone dvd-tjes en andere video formaten geven geen problemen.
[ Voor 12% gewijzigd door Slaiter op 04-04-2003 16:15 ]
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Slaiter schreef op 04 April 2003 @ 16:02:
Je zou natuurlijk eens kunnen proberen te doen wat er in de foutmelding staat lijkt me ;)
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • Slaiter
Slaiter
Firesnake
die foutmelding staat los van het probleem wat ik heb en heeft alleen te maken met de sound playback dat die kan overslaan, maar niets met het niet openen van de film zelf.
[ Voor 7% gewijzigd door Slaiter op 04-04-2003 16:09 ]
  • deadinspace
  • Laatst online: 09-09 13:51
deadinspace
The what goes where now?
mplayer zegt ook "file not found" als hij een file niet kan openen vanwege foute permissies (lekker handig). Zijn de permissies op de file wel goed? Oftewel: mag je die file wel lezen als user?
  • Slaiter
Slaiter
Firesnake
geen leesrechten bedoel je?
wat kan ik dan meer doen dan chmodden (wat ik gedaan heb) om lees rechten in die file te krijgen?
