Hoi,
ik heb net APACHE, PHP, en MYSQL geinstalleerd:
heb MyPHPAdmin gedl en onder HTDOCS gezet....
nu krijg ik de volgende error
Warning: mysql_result() [function.mysql-result]: Unable to jump to row 0 on MySQL result index 11 in c:\apache\apache\htdocs\phpmyadmin\libraries\common.lib.php on line 572
my.cnf staat op C:\
en ziet er zo uit:
# Example mysql config file.
# Copy this file to c:\my.cnf to set global options
# One can use all long options that the program supports.
# Run the program with --help to get a list of available options
# This will be passed to all mysql clients
[client]
#password=my_password
port=3306
#socket=MySQL
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# The MySQL server
[mysqld]
port=3306
#socket=MySQL
skip-locking
set-variable = key_buffer=16K
set-variable = max_allowed_packet=1M
set-variable = thread_stack=64K
set-variable = table_cache=4
set-variable = sort_buffer=64K
set-variable = net_buffer_length=2K
server-id = 1
# Uncomment the following if you want to log updates
#log-bin
# Uncomment the following rows if you move the MySQL distribution to another
# location
basedir = c:/apache/mysql/
datadir = c:/apache/mysql/data/
# Uncomment the following if you are NOT using BDB tables
#skip-bdb
# Uncomment the following if you are using Innobase tables
#innodb_data_file_path = ibdata1:100M
#innodb_data_home_dir = c:\ibdata
#innodb_log_group_home_dir = c:\iblogs
#innodb_log_arch_dir = c:\iblogs
#set-variable = innodb_mirrored_log_groups=1
#set-variable = innodb_log_files_in_group=3
#set-variable = innodb_log_file_size=5M
#set-variable = innodb_log_buffer_size=8M
#innodb_flush_log_at_trx_commit=1
#innodb_log_archive=0
#set-variable = innodb_buffer_pool_size=16M
#set-variable = innodb_additional_mem_pool_size=2M
#set-variable = innodb_file_io_threads=4
#set-variable = innodb_lock_wait_timeout=50
[mysqldump]
quick
set-variable = max_allowed_packet=16M
[mysql]
no-auto-rehash
# Remove the next comment character if you are not familiar with SQL
#safe-updates
[isamchk]
set-variable = key_buffer=8M
set-variable = sort_buffer=8M
[myisamchk]
[mysqlhotcopy]
interactive-timeout
Het pad naar phpMyAdmin is:
C:\Apache\Apache\htdocs\phpMyAdmin
en een stukje uit config.inc.php:
$cfgPmaAbsoluteUri = 'http://localhost/phpMyAdmin';
* Server(s) configuration
$i = 0;
// The $cfgServers array starts with $cfgServers[1]. Do not use $cfgServers[0].
// You can disable a server config entry by setting host to ''.
$i++;
$cfgServers[$i]['host'] = 'localhost'; // MySQL hostname
$cfgServers[$i]['port'] = ''; // MySQL port - leave blank for default port
$cfgServers[$i]['socket'] = ''; // Path to the socket - leave blank for default socket
$cfgServers[$i]['connect_type'] = 'tcp'; // How to connect to MySQL server ('tcp' or 'socket')
$cfgServers[$i]['controluser'] = ''; // MySQL control user settings
// (this user must have read-only
$cfgServers[$i]['controlpass'] = ''; // access to the "mysql/user"
// and "mysql/db" tables)
$cfgServers[$i]['auth_type'] = 'config'; // Authentication method (config, http or cookie based)?
$cfgServers[$i]['user'] = 'root'; // MySQL user
$cfgServers[$i]['password'] = 'paswoord'; // MySQL password (only needed
// with 'config' auth_type)
$cfgServers[$i]['only_db'] = ''; // If set to a db-name, only
// this db is displayed
// at left frame
// It may also be an array
// of db-names
$cfgServers[$i]['verbose'] = ''; // Verbose name for this host - leave blank to show the hostname
$cfgServers[$i]['bookmarkdb'] = ''; // Bookmark db - leave blank for no bookmark support
$cfgServers[$i]['bookmarktable'] = ''; // Bookmark table - leave blank for no bookmark support
$cfgServers[$i]['relation'] = ''; // table to describe the relation between links (see doc)
// - leave blank for no relation-links support
heeft iemand een idee..
thanks
my.cnf staat op C:\
en ziet er zo uit:
[client]
port=3306
#socket=MySQL
# The MySQL server
[mysqld]
port=3306
#socket=MySQL
skip-locking
server-id = 1
#log-bin
# location
#skip-bdb
[mysqldump]
quick
[mysql]
no-auto-rehash
#safe-updates
[isamchk]
[myisamchk]
[mysqlhotcopy]
interactive-timeout
$i = 0;
$i++;
// at left frame
// of db-names
thanks
