Hij is uit
met nieuwe feautures
http://download.nullsoft....client/winamp290_full.exe
http://download.nullsoft.com/winamp/client/winamp290_std
http://download.nullsoft....client/winamp290_lite.exe
http://download.nullsoft..../winamp290_full_noaod.exe (zonder aol troep)
Changelog:
* hot new default skin, done by none other than the evil robot turned good, Steve Gedikian
* added integrated full featured video support (NSV and DirectShow (AVI,ASf,MPEG,etc))
* added library (complete with media database, shoutcast listing, playlist editing,
CD listing, mass tag editting, plugin API for portable devices, and more!)
* updated Winamp's window docking code to be more robust/extensible
- made AVS dock use this new API
* updated PCM equalizer with code from 4Front Technologies/George Yohng. Quality is a lot better.
* updated equalizer default skin to show the true +12db/-12db range (the 20db was a veeery old typo)
* a ton of new WM_WA_IPC API calls.
- general purpose plugin window support
- extended metadata system for getting more than just title/length of items.
- lots of exposed features via IPC
* updated to PP's latest input and output plugins
* focus/Z order change on window close related bugfixes
* added track numbers and song lengths in HTML generated playlists
* removed all ATL code, shoved EXE size by 20kb
* added digital audio extraction in in_cdda.dll
(needs WNASPI32.DLL under Windows 9x/ME)
* added Alt+M shortcut for minimizing Winamp
* added Ctrl+(Keypad +)/Ctrl+(Keypad -) shortcuts in playlist editor for changing font size
* fixed stop after current menu item trash related bug
* added ultravox support for in_mp3
* made in_mp3 not display 'unknown X' for empty id3 tags
* installer uses leet new NSIS 2.0b3
* improvements to the setup process
* made the keep on screen code multimonitor smart and better
* fixed & error in tooltips in winamp and winampa's systray icons
* and TONS more! (new SDKs will be posted soon.)
Ik vind die nieuwe library echt kicken
Changelog:
