FAILURE AFTER FLASHING BIOS
  • 48 views sinds 30-01-2008
Hello
Hm maybe someone can help me here
I have a Gainward GeForce4 PowerPack! Pro/650 TV/DVI 64MB Golden Sample
card and i flashed the newest bios on it
it did say flashing succesfull
after that i rebooted i dont get to seen nothing anymore on the monitor
it stayes white and after a while my monitor says OUT OF RANGE
Seems the freq is f**ked
I did try with another monitor on it and same failure
i did put another graphic card in the computer and everything works ok
so there is nothing wrong with the comp
Any one know how to fix it?
Solution?
greets Mave0
This is a Dutch computerforum, the main language here is Dutch, so refrase your sentences, otherwise no one will help you I guess :)
  • Twistedmark
  • Laatst online: 08-09 21:48
Put a PCI videocard in the computer and then flash the original bios on it?
wat boeit het nou of het in het engels of in het nederlands is.
[ Voor 75% gewijzigd door Twistedmark op 01-04-2003 20:04 ]
gewoon nederlands kent de topicstarter wel te kunnen lijkt me
hoe kun je anders deze vraag in het juiste forum plaatsen als je geen Nederlands kunt :?
ik bedoel Videoplanken & Beeldkanonnen go figure :)
You could also try to put another bios from the exact same type vga card in it, boot your pc, remove the bios, insert the corrupt original one, and then flash it again (preferably by the one that was on it before you flashed it).
  • OnTracK
  • Laatst online: 15:49
Why did you want to flash the firmware in the first place?, it won't get more performace I believe.
Maybe you downloaded a corrupt one or something like that. Try to flash it back
IF you're ever going to post another topic here, DO NOT use caps-lock, I hope that your topic is allowed to stay open ('cause we've got some pretty nasty mods here >:), got to watch myself here)
and vwk, I think most tweakers can speak quite a bit of English
and dredge: "video..."? :Z
[ Voor 12% gewijzigd door OnTracK op 01-04-2003 20:09 ]
Not everybody wins, and certainly not everybody wins all the time.
But once you get into your boat, push off and tie into your shoes.
Then you have indeed won far more than those who have never tried.
  • Kevinp
  • Laatst online: 05-09 18:35
als het een engelsman in nederland is kan je wel een beedjenederlands. maar om iets echt te begrijpen praat je engels dus iedereen die het antwoord weet. vertaal het ff en zet het hier neer. GOT goes international.
d'r is maar één ding in het leven wat moet, en dat is dood gaan.
  • BalusC
BalusC
Carpe diem
Da's gewoon een Nederlander.
Dat is aan zijn IP en aan zijn brakke Engelse grammatica te zien :+
Maargoed, de topicstarter moet in het vervolg maar even een nieuw topic netjes in het Nederlands schrijven en niet meer crossforum gaan posten :P
  • My-life
  • Laatst online: 06-09 23:47
Twistedmark schreef op 01 april 2003 @ 20:01:
Nou dat boeit zoveel dat jij het volgens mij niet snapt... Of ik snap het ff niet...
(dan sta ik nu dus wel dik voor paal :+ )
  • GA!S
GA!S
295 g/km
Try to create a bootable floppy with the flash program + parameters in the autoexec.bat. Reboot with that disk an have some patience. After that, reboot your system and see if it's back alive.
de betaler vervuilt
  • Grrrrrene
Don't yell like that please and don't post greetings below your posts.
This topic is now locked
[ Voor 91% gewijzigd door Grrrrrene op 01-04-2003 20:13 ]
  • Pollewob
Dit gaat vooral over de Taal van de topicstart :P
Probeer het maar opnieuw (in het Nederlands) in een nieuw topic ajb :)
