mgs 2 dogtags probleem
  • swopdark
  • Laatst online: 30-11-2025
swopdark
ja doe maar...
[MGS2] sommige bewakers zijn niet bang voor je gun en geven dus ook niet hun dogtag af, hoe kan je die dan toch krijgen? ik heb even lopen zoeken op andere topics maar er wordt niet over gesproken.
Playstation 3 - PSN ID: Sw0pDiller | XBOX360 Premium - Gamertag: ZakkeWasser | DELL New Studio 17 laptop
  • inXs
  • Laatst online: 20:23
inXs
known as inXs
swopdark schreef op 29 maart 2003 @ 14:15:
http://www.avault.com
http://gameguru.box.sk
staan genoeg guides, is denk ik wel ergens met de search te vinden ;)
superB
  • swopdark
swopdark
ja doe maar...
sorry heb gezocht maar zal wel blind zijn maar ik kan er weinig over vinden, heeft niemand gewoon even de gouden tip?
  • Genghis Khan
First you must hold up a guard, do this by going up to them without them seeing you and hold up your gun towards them without shooting. Then snake or raiden will shout freeze and they will stand with their hands up, now move so that you are facing them. You can move to face them by taking down your gun and running round, or, hold L1 with square still held to move around with your gun held up. Now point your gun at their groin or head to make them shake and give up their dogtag. A summary is below.
1. Hold up a guard.
2. Move to their front.
3. Point your gun at their head or groin to make them give up the tag.
If the guard is against a wall you can hold them up, let your gun down and use square and a direction to drag them away from the wall. Then get their dogtag. If you need a dogtag off a sleeping guard either spay them with coolant or keep on picking up and droping them, then when they wake up have your gun pointed at them to make them hold up.
There are some guards called "tough guys" by many that wont give you their digtags and will often try to attack you or dodge your attacks. These guards will keep on saying stuff like "are you going to shoot me?", it is fairly easy - and also fun - to get dogtgs off these guards as long as you know how. Use your SOCOM or USP to shot them in their leg ar arm, this shows thm you mean business, then point your gun at their head or groin and they will give you their tag. Do not tranquilise them, they will still act tough when you wake them up. On the tanker level you will have to fight olga and get the USP before you can get some guards' dogtags. Also you can just point a massive weapon like a nikita at them and then they wont challenge you.
Best moeilijk he dat zoeken? :{.
  • inXs
inXs
known as inXs
Gebruik je wel de goede term: "dogtag" vind ik idd nergens, maar kijk hier eens:
http://www.gamefaqs.com/console/ps2/game/28489.html
edit: Uhmm naja zie verhaal kaaskop :)
[ Voor 18% gewijzigd door inXs op 29-03-2003 14:29 ]
superB
  • swopdark
swopdark
ja doe maar...
thx kaaskop!
