^^ zou je dus even een titel kunnen voorstellen
^^ ook handig om even op te reageren
DMA forceren onder XP: [google=xp force dma] ==>
If you are sure your drive is DMA but XP seems stuck on PIO. First check in device manager under IDE controllers that you have it set to "DMA if available" for your DVD Rom. If you reboot and recheck and it is still stuck on PIO which mine were then go to run and type in regedit. Find the following key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E96A-E325-11CE-BFC1-08002BE10318}\000X
000X "X" being the number of the controller such as 0001 for primary and 0002 for secondary. Under this location find the key "MasterIdDataCheckSum" or "SlaveIdDataCheckSum" depending on which one your drive is and delete the value for the key. this will force XP to redetect your drive after reboot. Please be careful when editing your registry.
Voor 1% gewijzigd door
F_J_K op 29-03-2003 17:33
. Reden: layout verbeterd ]
