[winxp] sql2000 + cmserver + .net
  • nhimf
  • Laatst online: 31-08 19:16
nhimf
Lekker belangrijk allemaal
Ik heb hier een winxp professional uk vak staan.
Hierop draait iis.
Hierop moet de cmserver van ms komen te draaien. Nou heeft deze server ook sql2000 nodig.
Hier zit dus het probleem. Zoals bekend draaid sql2000 enterprise & standard niet op winxp.
Kan ik dan de trial versie draaien of msde? Of moet cmserver echt de "normale" versie hebben?
Iemand enig idee?
de requirements van cmserver:
Microsoft Windows® 2000 Server or Windows 2000 Advanced Server with Service Pack 2 (SP2), or Microsoft Windows XP Professional with Service Pack 1 (SP1) and Microsoft Internet Information Service 5.0
Note: Content Management Server 2002 will run on the upcoming production versions of Windows Server 2003 with the application of Service Pack 1 for Content Management Server 2002. SP1 is scheduled for availability within 90 days of the Windows Server 2003 release to manufacturing.
Microsoft .NET Framework with SP2
Microsoft SQL Server™ 2000 with SP3
Microsoft Internet Information Services (IIS) 5.0
Microsoft Internet Explorer 6 or later
en die van sql2000
• SQL Server 2000 Enterprise Edition and Standard Edition run on Microsoft Windows® 2000 Server, Windows 2000 Advanced Server, Windows 2000 Datacenter Server operating systems, Microsoft Windows NT® Server version 4.0 Service Pack 5 (SP5) or later, and Windows NT Server 4.0 Enterprise Edition with SP5 or later
• SQL Server 2000 trial software and SQL Server 2000 Developer Edition run on the operating systems listed above for the Enterprise and Standard Editions as well as on Windows XP Professional, Windows XP Home Edition, Windows 2000 Professional and Windows NT Workstation 4.0 with SP5 or later.
• SQL Server 2000 Personal Edition¹ and SQL Server 2000 Desktop Engine run on the operating systems listed above for Enterprise and Standard Editions, as well as on Windows 98, Windows Millennium Edition (Windows Me), Windows XP Professional, Windows XP Home Edition, Windows 2000 Professional, and Windows NT Workstation 4.0 with SP5 or later.
ps. Aan de harware eisen voldoe ik, dus dat is het probleem niet.
Ik stink niet, ik ruik gewoon anders
met MSDE kan je een probleem krijgen met CMS denk ik omdat je een gelimiteerd aantal users hebt en alleen NTLM identificatie.
Verder heeft het dezelfde functionaliteit zo'n beetje en kan je ook sp3 voor msde downloaden vanaf microsoft.
En het *zou* kunnen zijn dattie die sql nodig heeft voor de dashboard die misschien niet in msde zit.
  • nhimf
nhimf
Mja de cms gaat draaien als test, dus niet in productie, dus max 2 a 3 users tegelijk. Maar normaal hooguit 1 (ikzelf).
Nou ik ben iig cmserver trial en sql2000 trial aan het downen, als het werkt dan post ik wel een update hier.
[ Voor 33% gewijzigd door nhimf op 25-03-2003 10:18 ]
  • nhimf
nhimf
Ok het is een paar dagen geleden alweer, maar de trial van sql2000 werkt gewoon en de trial van cms erbij, dan gaat het ook goed.
Dus voor mensen die dit ook willen: installeer de trials dan gaat het goeg, alleen heb je 120dagen om het uit te proberen ;)
