[bind]nameserver wilt niet alle subdomains doorgeven
  • Ankh
  • Registratie: Mei 2001
  • Laatst online: 22:36
we hebben al meerdere dingen geprobeerd, maar een of andere vage manier, blijven de subdomeinen niet goed werken. De ene werkt wel de andere niet :/
mijn named.conf
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
// generated by named-bootconf.pl
options {
        directory "/var/named";
         * If there is a firewall between you and nameservers you want
         * to talk to, you might need to uncomment the query-source
         * directive below.  Previous versions of BIND always asked
         * questions using port 53, but BIND 8.1 uses an unprivileged
         * port by default.
        // query-source address * port 53;
// a caching only nameserver config
controls {
        inet 127.0.0.1 allow { localhost; } keys { rndckey; };
zone "." IN {
        type hint;
        file "named.ca";
zone "localhost" IN {
        type master;
        file "localhost.zone";
        allow-update { none; };
zone "0.0.127.in-addr.arpa" IN {
        type master;
        file "named.local";
zone "only4clans.com" IN {
        type master;
        file "only4clans.com/domain.zone";
zone "76.212.62.in-addr.arpa" IN {
        type master;
        file "only4clans.com/reverse.zone";
include "/etc/rndc.key";
het gaat dus om het domein www.only4clans.com die naar het ip 62.212.76.219 gaat. (daar draait de naamserver ook op. dus ns1.only4clans.com gaat naar dit ip)
wanneer we kijken naar de domain.zone en reverse.zone zien deze er zo uit:
domain
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
$TTL 1W
@   IN  SOA ns1.only4clans.com. webmaster.only4clans.com. (
            2002031603 ;
            8H ;
            2H ;
            1W ;
            11h );
@               IN NS           ns1.only4clans.com.
@               IN MX        10 mail.only4clans.com.
@               IN A            62.212.76.219
mail.only4clans.com.            IN A            62.212.76.219
ns1.only4clans.com.             IN A            62.212.76.219
davarious.only4clans.com.   IN A        62.212.76.220
ftp.only4clans.com.             IN A            62.212.76.219
limpids.only4clans.com.         IN A            62.212.76.219
dale.only4clans.com.            IN A            62.212.76.219
first.only4clans.com.           IN A            62.212.76.219
g-liga.only4clans.com.          IN A            62.212.76.219
ugt.only4clans.com.             IN A            62.212.76.219
ttk.only4clans.com.             IN A            62.212.76.219
matt.only4clans.com.            IN A            62.212.76.219
sft.only4clans.com.             IN A            62.212.76.219
team-bf.only4clans.com.         IN A            62.212.76.219
i-playaz.only4clans.com.        IN A            62.212.76.219
domination.only4clans.com.      IN A            62.212.76.219
team-kokosnuss.only4clans.com.  IN A            62.212.76.219
stc.only4clans.com.             IN A            62.212.76.219
dynamic.only4clans.com.         IN A            62.212.76.219
csglobal.only4clans.com.        IN A            62.212.76.219
insane.only4clans.com.          IN A            62.212.76.219
huhn.only4clans.com.            IN A            62.212.76.219
rzg.only4clans.com.             IN A            62.212.76.219
lanium.only4clans.com.          IN A            62.212.76.219
toomster.only4clans.com.        IN A            62.212.76.219
c.sportz.only4clans.com.        IN A            62.212.76.219
radikalz.only4clans.com.        IN A            62.212.76.219
theclq.only4clans.com.          IN A            62.212.76.219
ml.only4clans.com.              IN A            62.212.76.219
3dp.only4clans.com.             IN A            62.212.76.219
ut2k3.only4clans.com.           IN A            62.212.76.219
fof.only4clans.com.             IN A            62.212.76.219
dcbaby.only4clans.com.          IN A            62.212.76.219
reverse:
29
30
31
32
33
34
35
36
37
38
39
40
41
$TTL 1W
            2002031604 ;
            8H ;
            2H ;
            1W ;
            11h );
219     IN PTR      www.only4clans.com.
219     IN PTR      ns1.only4clans.com.
219     IN PTR      limpids.only4clans.com.
219     IN PTR      dale.only4clans.com.
219     IN PTR      first.only4clans.com.
219     IN PTR      g-liga.only4clans.com.
219     IN PTR      ugt.only4clans.com.
219     IN PTR      ttk.only4clans.com.
219     IN PTR      matt.only4clans.com.
219     IN PTR      sft.only4clans.com.
219     IN PTR      team-bf.only4clans.com.
219     IN PTR      i-playaz.only4clans.com.
219     IN PTR      domination.only4clans.com.
219     IN PTR      team-kokosnuss.only4clans.com.
219     IN PTR      stc.only4clans.com.
219     IN PTR      dynamic.only4clans.com.
219     IN PTR      csglobal.only4clans.com.
219     IN PTR      insane.only4clans.com.
219     IN PTR      huhn.only4clans.com.
219     IN PTR      rzg.only4clans.com.
219     IN PTR      lanium.only4clans.com.
219     IN PTR      toomster.only4clans.com.
219     IN PTR      c.sportz.only4clans.com.
219     IN PTR      radikalz.only4clans.com.
219     IN PTR      theclq.only4clans.com.
219     IN PTR      ml.only4clans.com.
219     IN PTR      3dp.only4clans.com.
219     IN PTR      ut2k3.only4clans.com.
219     IN PTR      fof.only4clans.com.
219     IN PTR      dcbaby.only4clans.com.
220     IN PTR      davarious.only4clans.com.
219             IN PTR      ftp.only4clans.com.
ik heb al hulp gehad van iemand, die er best veel van af weet. maar hij kreeg het ook niet aan de praat...
Ik neem trouwens als voorbeeld fof.only4clans.com.
hier thuis:
(11:58:08)     dns: resolving (fof.only4clans.com)...
(11:58:08)     dns: unable to resolve (fof.only4clans.com)
en op de server zelf:
[root@wfh1 etc]# host -t any fof.only4clans.com
fof.only4clans.com has address 62.212.76.219
Wie weet waarom dit nou niet gewoon werkt :?
Zal ongetwijfeld te maken hebben met de negative caching door de DNS-server die jij thuis gebruikt/aanspreekt :)
Overigens wel eens van CNAMES gehoord?
dig fof.only4clans.com
; <<>> DiG 9.2.2rc1 <<>> fof.only4clans.com
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 64139
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;fof.only4clans.com. IN A
;; ANSWER SECTION:
fof.only4clans.com. 604800 IN A 62.212.76.219
;; AUTHORITY SECTION:
only4clans.com. 604800 IN NS ns1.only4clans.com.
;; Query time: 55 msec
;; SERVER: 192.168.1.3#53(192.168.1.3)
;; WHEN: Wed Mar 19 12:19:42 2003
;; MSG SIZE rcvd: 70
[ Voor 69% gewijzigd door Verwijderd op 19-03-2003 12:20 ]
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
[rick@rick rick]$ host fof.only4clans.com
[rick@rick rick]$ host 62.212.76.219
219.76.212.62.in-addr.arpa domain name pointer bouncers.only4clans.com.
[rick@rick rick]$
Welke nameserver gebruik je 'hier thuis' ?
  • Ankh
Verwijderd schreef op 19 March 2003 @ 12:18:
1. bedoel je het updaten van quicknets DNS server? de afgelopen dagen heb ik er namelijk niets aan verandert. Omdat ik ook dacht dat het daar aan ligt . maar omdat sommige wel doen en andere niet, snap ik er dus de ballen van :?
ik gebruik dus de dns server van quicknet, maar ik heb een router hier staan die dns cache heeft :? kan het daar dan aan liggen :?
[edit1] cnames ik zoek er ff naar O-) ik heb deze config van de server niet gemaakt :) ik leer namelijk alleen maar van :D :o
maar die jongen die het gedaan had, snapte het ook al niet :D
[edit2]
[root@scarabaeus root]# dig fof.only4clans.com
; <<>> DiG 9.2.1 <<>> fof.only4clans.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 57876
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; Query time: 19 msec
;; SERVER: 213.73.255.52#53(213.73.255.52)
;; WHEN: Wed Mar 19 12:27:12 2003
;; MSG SIZE  rcvd: 36
hij kan hem dus niet echt vinden :?
zo te zien aan de server is het een dns server van quicknet..
[ Voor 40% gewijzigd door Ankh op 19-03-2003 12:28 ]
dig @ns1.quicknet.nl only4clans.com fof.only4clans.com
; <<>> DiG 9.2.2rc1 <<>> @ns1.quicknet.nl only4clans.com fof.only4clans.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 45438
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 0
;only4clans.com. IN A
;; ANSWER SECTION:
only4clans.com. 351863 IN A 62.212.76.219
only4clans.com. 428371 IN NS ns.
only4clans.com. 428371 IN NS ns1.leaseweb.nl.
;; Query time: 29 msec
;; SERVER: 213.73.255.52#53(ns1.quicknet.nl)
;; WHEN: Wed Mar 19 12:27:08 2003
;; MSG SIZE rcvd: 93
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 56098
;; Query time: 36 msec
[ Voor 24% gewijzigd door Verwijderd op 19-03-2003 12:29 ]
  • Ankh
zo te zien is dat nog de oude config van de nameserver
er staat de ns. nog in (die natuurlijk niet bestaat :) )
Yupz :)
TTL waardes wat verlagen zorgt ervoor dat caching korter duurt.
Voordat aanpassingen in de DNS over de hele wereld gepropageerd zijn ben je zo een week of meer verder ;)
  • Ankh
Verwijderd schreef op 19 March 2003 @ 12:31:
Yupz :)
hmm j ah dat duurt wat lang :P
zijn er ook nog TTL waardes die dan aanbevolen worden :?
[edit]
deze bedoel je dus:
$TTL 1W
:o ?
[ Voor 8% gewijzigd door Ankh op 19-03-2003 12:34 ]
RaMMSTeiN schreef op 19 March 2003 @ 12:32:
Als jij niet veel aan je DNS verandert, dan kun je hele hoge waardes pakken, zodat er langer gecached wordt.
Wil je DNS onderhoud gaan plegen in de toekomst, dan zet je ruim van te voren de TTL omlaag naar erg lage waardes, waarna je het aanpast en je de TTL weer omhoog kunt zetten. :)
  • Ankh
Verwijderd schreef op 19 March 2003 @ 12:34:
mha we hebben dus een "hosting bedrijfje" voor clans wat opzich zeer goed loopt :) dus er zal wel wat dingen moeten veranderen bij de dns server.. dus dan kan ik hem beter laag houden...
Mag ik dan een tipje geven over DNS? :)
Ga je daar a.u.b. echt een beetje in verdiepen en zorg ervoor dat je DNS-server zelf ook goed beveiligd is.
  • Ankh
Verwijderd schreef op 19 March 2003 @ 12:41:
tips zijn altijd welkom :)
idd dat lijkt me wel errug nodig :P
ik heb hem nu ff op 11h gezet kijken of dat viel uit maakt :)
Thnx in ieder geval
  • RvdH
RvdH
Mag/Kan dat wel, zoveel PTR records op 1 ip-adres? Heeft toch weinig nut lijkt me, krijg je elke keer random een andere hostname als je dat IP op vraagt..
  • Ankh
strlen schreef op 19 March 2003 @ 12:19:
[rick@rick rick]$
^^^^^ bedoel je dit?
strlen schreef op 19 March 2003 @ 13:48:
Per ip kan er maar 1 PTR zijn als ik t goed heb, dat klopt dus sowieso niet. Verder je PC cachet de zooi van Quicknet. Even je dnsflushen en klaar,
Zie je windows bak via cmd en dan "ipconfig /all" krijg je een mooie waslijst voor je neus :P
Verwijderd schreef op 19 March 2003 @ 14:46:
Jij hebt zeker ook heel goed de commando's bekeken die ik in deze topic gegeven heb? :+
  • Ankh
[root@wfh1 root]# dig @ns1.quicknet.nl fof.only4clans.com
; <<>> DiG 9.2.1 <<>> @ns1.quicknet.nl fof.only4clans.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 11358
;; Query time: 7 msec
;; WHEN: Thu Mar 20 11:49:33 2003
het werkt nog steeds niet :? ik heb gewoon de TTL verandert en de nameserver opnieuw gestart... wat doe ik nog fout :?
  • xzenor
  • Laatst online: 14-10-2022
xzenor
Ja doe maar. 1 klontje suiker.
update je wel je serial na iedere update?
als je serial hetzelfde blijft dan denkt de andere kant namelijk dat de lijst niet veranderd is en doetie dus geen refresh.
als je je serial ophoogd denkt de andere kant "heej, nieuwere serial, ff binnehalen!"
  • Ankh
owh ok
al gevonden :+
[ Voor 46% gewijzigd door Ankh op 20-03-2003 12:29 ]
  • xzenor
xzenor
en?
  • Ankh
kheb de serial verandert.. maar dan moeten ze het bij quicknet nog door krijgen :D
  • xzenor
xzenor
root@tnt$ nslookup fof.only4clans.com
Server: scorpio.tnt.intern
Address: 192.168.2.100
Address: 62.212.76.219
maar:
> server 213.73.255.52
Default Server: ns1.quicknet.nl
Address: 213.73.255.52
> fof.only4clans.com
*** No address (A) records available for fof.only4clans.com
en die van xs4all geeft ook gewoon een goeie reply
quicknet is blijkbaar een BEEEEETJE traag met z'n updates
Vaagjes, ns2.quicknet.nl kent'm al wel, maar ns1.quicknet.nl kent'm nog niet.
[ Voor 73% gewijzigd door xzenor op 20-03-2003 12:56 ]
  • Ankh
ik heb quicknet een email gestuurd kijken wat ze er over zeggen. wel grappig dat ns2 hem al wel heeft :)
  • xzenor
xzenor
hmmmm hij heeft 'm nog steeds niet
  • Ankh
ik heb het gevraagd, die dns server wordt maar 1 keer per dag geupdate.. tis zeer raar.. vanmorgen crashed de apache ook nog eens :S
  • CyBeR
CyBeR
overigens, niet helemaal related, maar wel belangrijk:
Dit is DNS pollution. DNS is niet bedoeld voor 'leuke' namen, het is hierarchisch. Maak er liever een echte hostname van, bijvoorbeeld www.only4clans.com. Zie ook www.dnsspam.nl.
Zinnen horen niet thuis in DNS.
  • Ankh
dat is voor irc, dus bouncers :) daarvoor worden ze enkel gebruikt :)
  • CyBeR
CyBeR
RaMMSTeiN schreef op 22 March 2003 @ 18:31:
Het blijft DNS pollution, en is dus ongewensd, en lame.
Daarbij werkt het op irc toch niet, om andere redenen.
  • Ankh
CyBeR schreef op 22 maart 2003 @ 18:38:
misschien dns pollution het staat wel mooi
(19:34:35)     &#8212;&#8250; query with (wfh|SCaRaB) (~scarab@warlocks.from.hell.powered.by.only4clans.com)
werkt wel dus ;)
