OpenBSD: pf.conf voorbeelden
  • 57 views sinds 30-01-2008
Ik ben vast niet de enige die op dit moment aan het vogelen is met een OpenBSD pf-firewall. Is het een idee om hier je pf.conf's te posten, zodat we wat nieuwe ideeen opkunnen doen?
Als aftrap volgt hier mijn eigen laptopt (test) firewall config:
# firewall config ne3 192.168.1.12 17/3/3 GS
# options: limit nr. of fragments to 30000
set limit frags 30000
# options: limit nr. of state table entries to 25000
set limit states 25000
# options: name of interface pf collect stats:
set loginterface "ne3"
# options: timeout options: timeout of statefull connect to 20 secs
set timeout tcp.first 20
# options: timeout options: timeout of idle established connection to 300 secs
set timeout tcp.established 300
# options: timeout options: timeout after cloning state connection to 5 secs
set timeout tcp.closed 5
# normalize traffic
scrub in on ne3 all
# enable localhost traffic
pass in quick on lo0 all
pass out quick on lo0 all
# enable remote control from 192.168.1.10, (max concurrent connections: 3 label: ssh)
pass in quick on ne3 proto tcp from 192.168.1.10 to 192.168.1.12 port = 22 flags S keep state (max 3) label "ssh"
# block return-rst/return-icmp
block return-rst out log on ne3 proto tcp all
block return-rst in log on ne3 proto tcp all
block return-icmp out log on ne3 proto udp all
block return-icmp in log on ne3 proto udp all
# rfc1918 (anti-spoof)
block in log quick from 0.0.0.0/8 to any
block out log quick from 0.0.0.0/8 to any
block in log quick from 127.0.0.0/8 to any
block out log quick from 127.0.0.0/8 to any
block in log quick from 169.254.0.0/16 to any
block out log quick from 169.254.0.0/16 to any
block in log quick from 192.0.2.0/24 to any
block out log quick from 192.0.2.0/24 to any
block in log quick from 192.88.89.0/24 to any
block out log quick from 192.88.89.0/24 to any
block in log quick from 224.0.0.0/4 to any
block out log quick from 224.0.0.0/4 to any
block in log quick from 240.0.0.0/4 to any
block out log quick from 240.0.0.0/4 to any
# enable outgoing traffic (only from user ger)
pass out quick on ne3 from any to any user ger flags S keep state
# default rulez!
block in log all
block out log all
wat wil je hiermee bereiken?
je kan beter een topic starten met wat je nou precies wil doen met je firewall hoe je dat tot nu toe hebt gerealiseerd en wat er eventueel nog aangepast kan worden... zoals bij de logging of eventueele flood protecties...
gewoon je firewall config hier neer kwakken komt neer op een opsom-topic en daar is toestemming voor nodig O-)
Zie de post van Caesium. Altijd eerst ff contact opnemen met een moderator voordat je dit soort topics start. Iig denk ik dat je weinig kans hebt op GoT. Waar je wel je rulesets kwijt kunt, is op de PF Wiki. Dat is een wiki speciaal gemaakt voor pf rulesets en alles wat daarbij komt kijken. Succes :)
[ Voor 5% gewijzigd door Verwijderd op 18-03-2003 12:33 ]
