Hoi all,
Ik probeer op mijn solaris 9 machine centericq 4.9.2 te compileren.
de volgende vereisten heb ik al geinstalleerd staan :
ncurses-5.3
pkgconfig-0.15.0
glib-2.2.1
libsigc++-1.2.3
als ik nu "./configure --prefix=/misc1/centericq --with-glib-prefix=/usr/sfw --enable-locales-fix" vindt hij keurig alles wat hij zegt nodig te hebben, maar als ik dan "make" draai gebeurt er het volgende :
bash-2.05# make
make all-recursive
make[1]: Entering directory `/opt/sources/centericq-4.9.2'
Making all in kkconsui-0.1
make[2]: Entering directory `/opt/sources/centericq-4.9.2/kkconsui-0.1'
Making all in include
make[3]: Entering directory `/opt/sources/centericq-4.9.2/kkconsui-0.1/include'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/opt/sources/centericq-4.9.2/kkconsui-0.1/include'
Making all in src
make[3]: Entering directory `/opt/sources/centericq-4.9.2/kkconsui-0.1/src'
c++ -DPACKAGE=\"kkconsui\" -DVERSION=\"0.1\" -DLOCALES_HACK=1 -I. -I. -I../include -I../../kkstrtext -I../../kkstrtext-0.1 -g -O2 -c texteditor.cc
In file included from ../include/linkedlist.h:6,
from ../include/texteditor.h:13,
from texteditor.cc:46:
../include/conf.h:13:23: _G_config.h: No such file or directory
In file included from ../include/texteditor.h:17,
../include/conscommon.h:17:21: ncurses.h: No such file or directory
In file included from ../include/abstractui.h:6,
from ../include/texteditor.h:18,
../include/screenarea.h:9: `chtype' was ../include/screenarea.h:9: parse error before `>' token
texteditor.cc: In member function `void ktool::texteditor::sethlcolor(int)':
texteditor.cc:594: `COLOR_PAIR' undeclared (first use this function)
texteditor.cc:594: (Each undeclared identifier is reported only once for each
function it appears in.)
texteditor.cc:594: `A_BOLD' undeclared (first use this function)
texteditor.cc:594: `attrset' undeclared (first use this function)
texteditor.cc: In member function `void ktool::texteditor::draw_print(char*,
int, int)':
texteditor.cc:601: `printw' undeclared (first use this function)
texteditor.cc: In member function `void ktool::texteditor::showline(int, int,
int, int)':
texteditor.cc:971: `mvhline' undeclared (first use this function)
texteditor.cc: In member function `void ktool::texteditor::draw(int)':
texteditor.cc:990: `refresh' undeclared (first use this function)
texteditor.cc: In member function `void ktool::texteditor::edbackspace()':
texteditor.cc:1110: `KEY_LEFT' undeclared (first use this function)
texteditor.cc:1123: `KEY_UP' undeclared (first use this function)
texteditor.cc:1124: `KEY_END' undeclared (first use this function)
texteditor.cc: In member function `void ktool::texteditor::eddelline()':
texteditor.cc:1189: `KEY_HOME' undeclared (first use this function)
texteditor.cc: In member function `void ktool::texteditor::edenter(bool)':
texteditor.cc:1236: `KEY_DOWN' undeclared (first use this function)
texteditor.cc: In member function `void ktool::texteditor::edmove(int, int)':
not declared in this scope
texteditor.cc:1344: `KEY_RIGHT' undeclared (first use this function)
texteditor.cc:1405: `KEY_PPAGE' undeclared (first use this function)
texteditor.cc:1421: `KEY_NPAGE' undeclared (first use this function)
texteditor.cc: In member function `int ktool::texteditor::open()':
texteditor.cc:1632: `KEY_BACKSPACE' undeclared (first use this function)
texteditor.cc:1652: `KEY_IC' undeclared (first use this function)
texteditor.cc:1652: `KEY_DC' undeclared (first use this function)
make[3]: *** [texteditor.o] Error 1
make[3]: Leaving directory `/opt/sources/centericq-4.9.2/kkconsui-0.1/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/opt/sources/centericq-4.9.2/kkconsui-0.1'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/sources/centericq-4.9.2'
make: *** [all-recursive-am] Error 2
bash-2.05#
Ik heb hier al met de search gezocht en via google gezocht maar ik kan niets vinden hierover.
Heeft iemand een idee van wat er fout gaat en hoe het moet worden opgelost?
ncurses-5.3
pkgconfig-0.15.0
glib-2.2.1
libsigc++-1.2.3
bash-2.05# make
make all-recursive
Making all in src
int, int)':
int, int)':
bash-2.05#
