problemen met X-tra units, TOTALA
  • 129 views sinds 30-01-2008
ik heb alle mini packs met extra units voor totala gedownload maar als ik meerdere packs tegelijk installeer krijg ik bij het laden van de game een fout melding. weet iemand hier wat tegen? de units heb ik hier vandaan.
tnx
  • Halfkakkende
  • Laatst online: 11:38
Halfkakkende
Vandring
Er is een programma voor dat heet Conflict Crusher (www.wickham.newbury.sch.uk/richard/games/ta/tacc.htm). Dit programma zorgt ervoor dat alle units met een dubbel ID niet geladen worden.
TA Conflict Crusher is a program designed to FIX conflicts between 3rd party units in the game Total Annihilation by Cavedog.
Why is this good? Well in Total Annihilation, each unit and weapon is allocated a unique ID number that identifies it to the game. Also it has a position on a build menu that defines which unit builds it and on which menu and button.
This is all fine, but say you download a unit from unit group A and a unit from group B. Both these new units could have the same ID (the unit ID being the same isn't too dangerous though), or worse they could have new weapons, which allocate the same unique ID to each of them. If two weapons have the same ID, TA will ignore one of them and possibly crash during startup. This results in one of your new units being unable to fire or whatever.
Also the new units could be built by the same unit on the same menu and same button. I know this sounds unlikely, but think if you then download another 50 new units, and the odds increase a lot.
If two units share the same button, only one of them will show up, making you unable to build the other one. These problems affect gameplay and stability.
This is where TA Conflict Crusher comes in. The program will load up your TA unit files and scan for conflicting weapon and unit IDs, as well as build menu positions. If one is found, you have the option to click a button to allocate an unused ID to the unit or weapon, or select a new menu position for build menu conflicts. VERY useful. No more unpacking, opening in notepad, running TA Unit Manager, finding free IDs, writing to notepad and repacking the file. TA Conflict Crusher can do all of this in one button press!
But the program doesn't stop there! There are more options such as advanced HPI editing, build menu exploring, free ID checks, menu alignment and more! Check out the Features section for more details.
Happy Annihilating :)
MUZIEK!
top maar het linkje werkt niet :'(
uhm zoek eens op TAUCC daar staat er volgens mij wel 1.
kep hem inmiddels gevonden maar ik blijf problemen houden met de x-tra packs. iemand nog iets?
niemand?
ja dat is waarschijnlijk om het feit dat 2 units in dezelfde slot zitten. Hierdoor kan ie over de zeik gaan
dat heb ik volgens mij al verholpen met die conflict crusher.
wat heb je dan allemaal geinstalleerd :?
Aangezien je het beste gewoon de TAUIP 2.1 packed kan gaan downloaden en daarbij de TAUCC unitpack erbij kan gaan gooien dan moet je toch echt elke unit hebben.
