Stats van de maand Juni!
  • 113 views sinds 30-01-2008
Hier volgt een overzicht van de maand Juni van de Dutch Power Cows !!
datum...leden..geflushed...is%........blokjes......gem. per lid........100% flush
1 juni.......2015........869........43%......674.168..........776..................1.563.64
2 juni.......2033........915........45%....1.055.224..........962.................1.955.746
3 juni.......2051........880........43%.......879.820........1000.................2.051.000
4 juni.......2076........958........46%.......844.207..........881.................1.828.956
5 juni.......2104......1058........50%....1.265.454........1196..................2.516.384
6 juni.......2130......1040........49%....1.029.226..........990..................2.108.700
7 juni.......2157......1044........48%.......973.292..........932..................2.010.324
8 juni.......2182......1023........47%.......955.363..........934..................2.037.988
9 juni.......2189......1006........46%....1.032.735.........1027.................2.248.103
10 juni.....2201........895........41%......660.681...........738.................1.624.338
11 juni.....2214........891........40%......766.062...........860.................1.904.040
12 juni.....2227........954........43%.......801.365..........840................1.870.680
13 juni.....2238......1095........50%....1.105.159.........1009................2.258.142
14 juni.....2249......1085........48%....1.139.717.........1050................2.361.450
15 juni.....2261......1082........48%....1.069.393..........989.................2.236.129
16 juni.....2275......1037.......45,5%.....917.824..........885.................2.013.375
17 juni.....2283........932.......41,6%.....781.163..........838.................1.913.154
18 juni.....2297........947.......41,2%.....880.459..........928.................2.131.616
19 juni.....2306.......1057......45,8%....1.104.508.......1045.................2.409.770
20 juni.....2318.......1080......46,6%.....950.923..........880.................2.039.840
21 juni.....2328.......1078......45,9%.....981.367..........910.................2.118.480
22 juni.....2348.......1105......47.1%.....912.296..........826.................1.939.448
23 juni.....2353.......1072......45,6%.....928.633..........866.................2.037.698
24 juni.....2360........953.......40,4%.....763.802..........801.................1.890.360
25 juni.....2368........986.......41,6%.....873.380..........886.................2.098.048
26 juni.....2376.......1103......46,4%....1.176.505.......1067.................2.535.192
27 juni.....2382.......1116......46,8%....1.175.489.......1053.................2.508.246
28 juni.....2396.......1128......47.1%....1.035.173........918..................2.199.528
29 juni.....2399.......1106......46,1%....1.131.111.......1023.................2.454.177
30 juni.....2408.......1094......45,4%....1.055.807........965..................2.323.720
In de maand juni hebben we 393 nieuwe leden mogen verwelkomen.
Het gemiddeld aantal leden dat per dag heeft geflushed is : 1020
Dat is gemiddeld 43,9% van het totaal aantal leden van DPC.
Het totale aantal blokjes dat is geflushed is 28.246.138 , wat een gemiddelde opleverd van 941.538 blokjes per dag.
Verder was de laagste flush op 10 juni met 660.681 wu’s en de hoogste hadden we op 26 juni met 1.176.505 wu’s
Mo-Bees will sting Ya, if you don’t watch your back!
  • BrZ
  • Laatst online: 16-10 20:56
BrZ
Hmm... er komen wel steeds minder snel nieuwe leden bij...
(en bovenste regel klopt niet helemaal Mo-Bees.....)
kan je alsjeblieft alle stats van het hele jaar posten, dan kunnen we daar een mooi grafiekje van maken ;)
NEED MORE, NEED MORE STATS
nee, dat kan ik niet omdat ik pas sinds 1 juni deze stats bij hou haha
  • SuperRembo
  • Laatst online: 20-08-2025
Als je de overall stats sorteerd op de laatste flush datum, zie je hoeveel actieve leden er zijn:
datum......DPC...........AT
24/6.......1393.........862
17/6.......1514.........922
10/6.......1612.........966
1/6.........1768.......1005
1/5.........1973.......1107
1/4.........2091.......1180
totaal.....2493.......2371
AT lijkt dus net zo groot als DPC, maar heeft veel veel minder actieve leden.
Mo-Bees: Waar haal jij je data eigenlijk vandaan? De overall teamstats geven 2493 leden aan, jij 2408?
| Toen / Nu
  • brikoe
  • Laatst online: 11-03-2022
brikoe
Volgens mij neemt hij die gewoon uit de DPC-hitparade. Want dat waren er gisteren ook 2408.
Check this out: http://www.elmarvanloon.nl/
yep, ik gebruikte eerst ook dat andere getal, maar iemand zei dat dat niet klopte, en dat ik het aantal van de hitparade moest aan houden.
dus dat doe ik ook.
  • NightBird
  • Laatst online: 23-10 22:31
NightBird
DPC-Crew Coding
Het verschil is als volgt te verklaren:
De 2408 komt uit http://stats.distributed.net/rc5-64/tlist.php3?low=1&limit=100&source=y , dit is dus het aantal mensen dat nu bij de DPC zit.
Die 2493 komt uit http://stats.distributed.net/rc5-64/tmember.php3?team=10313 , en dat is het aantal mensen dat ooit blocks voor de DPC heeft geflusht.
Voor de niet-rekenaars: er zijn dus 85 mensen die na lid geweest te zijn van DPC zijn overgestapt naar een ander team.
WatHoorJeWaar · Asobakken
Eerdere projecten: Leading Courses · Brandstof-zoeker.nl · Voertuig-zoeker.nl
  • MarcyDarcy
  • Laatst online: 20-10 21:52
Waar halen ze het lef vandaan :(
wat NightBird zegt.
yep dat is wat ik toen ook te horen krijg, dus gebruik ik het aantal van de Hitparade!
