Wie weet nog de parameter die bij een biosflash gegeven moet worden om nog hoger het voltage te krijgen in de softmenu...
Kan dat? Ook bij een KT7?
Unix doesn't prevent a user from doing stupid things, because that would necessarily prevent them from doing brilliant things.
while true ; do echo -n "bla" ; sleep 1 ; done
THE ABIT BIOS TRICK _ STEP BY STEP FOR NEWBIES !
On request :-)
1 : First of all download the desired bios and flashprogram (awdflash.exe).
2: Execute the downloaded .exe bios file.
3: Format a diskette with the copy systemfiles command.
( Or go to the Dos prompt and write : format a:/s )
4: Copy the .bin file you got after excecuting the .exe bios file to the floppy.
Write down the name of the .bin file ( i.e. Bh6_kg.bin )
5: Copy the awdflash.exe program to the floppy.
6: Reboot the computer.
7: When the computer beeps (post's) and starts counting your ram push delete to get into the bios.
Step 1: Set your bios settings to default - remember the cpu speed too.
Step 2: Set voltage to user defined and thereafter boost it up to 2.3 Volts.
Step 3: In the Bios Features Setup; set the boot sequence to : a,c,scsi.
and enable " Boot Up Floppy Seek"
Step 4: Save settings and restart.
Now the computer will start from the floppy.
When you see your floppy drive ( A:) you are ready to flash the bios .
1:Type awdflash and the flashprogram starts.
2:Type in the name of the .bin file(i.e BH6_kg.bin) - or the one you wrote down previously ; and Enter.
3: The flash program will ask you if you want to save the old bios - answer yes !
4: Save the old bios to the floppy with any name you like - I use "old" .
5: After the flash program have saved the old bios it will ask you if you want to program the bios - answer NO.
6: The flash program will now terminate and return to your floppy drive.
( What you have done now is to save your old bios - and you now have the opportunity to flash back to the previously bios again. When you do the bios trick you dont have the opportunity to save the bios. )
Now you are ready to trick your bios voltage settings !
7:The trick is NOT to start the flashprogram as you did previously : lets say you have downloaded the kg bios and now you have a file called Bh6_kg.bin on your floppy - Right ?
8: Type excactly as follows for the BH6kg.bios : awdflash.exe bh6_kg.bin /py /sn /cc
9:Another example - if you downloaded the BH6jj.bios : awdflash.exe bh6_jj.bin /py /sn /cc
10: Restart and go into your bios settings - now you will see that 2.3Volts is set to be default for your Celeron.
Frank Monroe advises you not to go higher than 2.5 Volts - I also reccommend to read his faq .
I have my C366 at 2.6 Volts and it's been running almost perfectly for three months, I've had crashes in test programs.
But everything in my machine is taken to the limit so I don't know what causes these random crashes.
@Nils H Gjendem '99
Famous last words : If you destroy anything - blame yourself !
If you succeed send me a mail - and thank me for writing this for you in my spare time !
Remember - I could have been drinking beer and having a good time instead :-)
On request :-)
@Nils H Gjendem '99
Zo, weer iets te doen voor de zondagmiddag... TNX:)
Have Fun ermee maar wel voor eigen risico heOp zaterdag 18 november 2000 23:41 schreef Demoniac het volgende:
Ja dat wil ik ook wel eens weten werkt dit ook voor een abit kt7????????????!!!!!!!!!?????????????????:9:9*D
Denk het wel.... er staat toch bovenaan dat het voor de Abit mammaplankjes in het algemeen isOp zondag 19 november 2000 12:33 schreef suprguard het volgende:
Werkt dit dus ook voor een abit kt7??
iemand het al geprobeerd??
ben benieuwd....
En Demo, fijne zondagmiddag gehad ? Is het de moeite waard om te proberen ?Op zaterdag 18 november 2000 23:41 schreef Demoniac het volgende:
Zelf geprobeerd (kt-7raid)
Niks nakkes nada jongen !
Bios wordt wel geflest, maar max. volt blijft 1,85
Wel na terugzetten oude bios registry errors en een hoop gezooi.
Iemand anders meer zuig6 ?
Yoepie! Deze truck werkt..... NIET!!!!
Had het kunnen weten, dat dit niet ging werken, maar was het proberen waard.
Yep, Bios is te tricken, maar blijft gewoon de maximale voltagewaarden geven. tevens kan je alle registerisettings opnieuw gaan instellen.
Wordt dan dus toch solderen....
Alhoewel ik er langer over nadenk....
het kan natuurlijk ook zijn, dat het door de nieuwe versie(s) awdflash.exe programma komt, dat deze truuk niet (meer???) werkt.
Het kan zeker zo zijn, dat een eerdere versie van awdflash nog wel werkt, en de voltages met rust laat.
Dit truukje werkte nl ook bij het upgraden van mijn oude MP7040a ricoh CDROM fikker naar een MP7060a. Hier checkte de oude firmwareupdate-proggie ook, en de nieuwe niet meer.
Heeft er iemand een oudere versie van awdflash liggen misschien? Probeer het hier eens mee.
hmm solderen?? vertel! heb je een link?Op maandag 20 november 2000 15:28 schreef John_Hoek het volgende:
must_overklok_verder.. so help me plzz
blaat? BLAAAAAAAAT!
GoT-ver, nee niet echt fijne zondag! nadat ik um geflest had nog steeds max 1,85 maar multiplier 9 en hoger deden het niet meer!
Toen opnieuw geflest, nix. Beta UZ geflest, nix. UL weer en met /cc /cd ofzo alles uit de bios gewist en toen deed ie het weer.
NIET AAN BEGINNEN DUS!!!
truuk werkte wel hoor. Ik heb 'm bij mij ook gehad (per ongeluk). Ik had eerst een celly266@448 (jawel de ORIGINELE en al op 448 toen de PII-450 nog maar net te koop was
op een abit bx6 en om die speed te halen moest ik het voltage al op max zetten. toen een keer bios geflashed en kreeg tot mijn grote schrik een foutmeldig tijdens flashen.
Na reboot bleek alles het nog te doen, alleen kan ik nu voltages selecteren van 1.5 tot 3.5
1 nadeel: Hij herkent het default voltage van mijn huidige cel300a@450 niet goed, dus standaard wou hij 'm op 3.5 volt zetten.
Jaja op zo'n oud mobotje werkt ie mischien wel maar op een kt7 niet
Jongens, wie heeft er een oude versie van AWDFlash.exe?
Ga ik het daar eens mee proberen. Kans bestaat dat het dan wel lukt op een KT7!
wat noemen wij oud tegenwoordig ?Op dinsdag 21 november 2000 08:21 schreef John_Hoek het volgende:
