[php 4.3.1] gd compileerd niet
  • mrfatmen
  • Laatst online: 22:24
ik draai slackware 8.1.
en heb php 4.3.1 nu draaien en alleen doet me gd het niet.
deze is tegenwoordig meegeleverd alleen als ik "./configure --with-gd"
doe dan gaat alles goed alleen als ik dan make doe krijg ik vage meldingen.
29
30
31
32
33
34
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:752: `fontkey_t' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:752: parse error before `fontkey'
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:756: `FT_BitmapGlyph' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:771: `tc_cache' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:789: `fontkey' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:791: parse error before `)'
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:798: `slot' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:798: invalid type argument of `->'
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:800: `FT_F26Dot6' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:810: `linespace' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:813: `matrix' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:813: `FT_Fixed' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:818: `penf' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:819: `pen' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:820: `bbox' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:822: `use_kerning' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:823: `previous' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:826: `render_mode' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:826: `FT_LOAD_MONOCHROME' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:833: `tmpstr' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:836: `next' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:867: invalid type argument of `->'
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:938: `glyph_index' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:944: `ft_kerning_default' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:944: `delta' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:949: `err' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:957: `image' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:960: `glyph_bbox' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:988: `render' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:990: `ft_glyph_format_bitmap' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:992: `ft_render_mode_normal' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:1001: `bm' undeclared (first use in this function)
/mrfatmen/php-4.3.1/ext/gd/libgd/gdft.c:1001: parse error before `image'
make: *** [ext/gd/libgd/gdft.lo] Error 1
en zo gaat hij nog even door, iemand anders dit probleem ook, en hebben die al een oplossing gevonden?
Heeft uw auto pijn? Ga dan naar de onderdelenlijn
Het bedrijf waar ik met veel plezier werk - Mijn eigen vertrouwde domein
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Hij probeert met freetype 1 te compilen, terwijl je waarschijnlijk 2 hebt..
--with-freetype-dir=/pad/naar/freetype-2/source
