IS dit waar, deze tips?
- Do not use PCI slot #2 and #6, it shares IRQ with AGP Video Card
- Disable Serial and Parallel Ports if you don't use them.
- Disable onboard sound if you want to use a sound card. Disable the onboard game port and midi port as well.
- For Windows XP user, apply SP1 before install nVidia unversial driver 2.0
- USB Keyboard does not work during Driver Updates.
- AC97 at Post : Disable [disable pc speaker sound at boot]
- Disable AGP Fastwrite to get more 3Dmarks2001se points
- Set AGP frequency between 66 mhz ~ 70 mhz
- Use Winflash.exe which is in the magic bios install directory to flash your bios. Make sure you are not over clock when you flash your bios
When system over clocking too much and it won't even post, hit the reset botton and hold down the INSERT key while repeatly tapping the DELETE key to get into bios [Watch Dog Feature]
ze zijn van http://8rda.com/page2.htm
