Probleem met Star Trek Voyager.
  • Black-Death
  • Laatst online: 22-10 10:53
Ik heb zojuist de game Star Trek Voyager: Elite Force maar weer eens geinstalleerd. Meteen de expansion overheengegooid. Maar telkens als ik wil opstarten krijg ik dit:
ST:V EF v1.20 win-x86 Apr 10 2001
----- FS_Startup -----
Current search path:
C:\Program Files\Raven\Star Trek Voyager Elite Force\baseef\pak3.pk3 (1685 files)
C:\Program Files\Raven\Star Trek Voyager Elite Force\baseef\pak2.pk3 (794 files)
C:\Program Files\Raven\Star Trek Voyager Elite Force\baseef\pak1.pk3 (67 files)
C:\Program Files\Raven\Star Trek Voyager Elite Force\baseef\pak0.pk3 (19069 files)
C:\Program Files\Raven\Star Trek Voyager Elite Force/baseef
21615 files in pk3 files
execing default.cfg
execing efconfig.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Skipping check for DirectInput
Joystick is not active.
------- Force Feedback Initialization -------
...inhibited, not initializing
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Working directory: C:\Program Files\Raven\Star Trek Voyager Elite Force
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\3dfxvgl.dll' ): failed
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Dit spel heeft al op mijn, welliswaar oude, systeem gedraaid.
Ik zou echt niet weten welke drivers ik heb, en welke versie van DirectX ben ik ook niet helemaal zeker van.
Pentium 3 500 mhz
128 sd-ram
voodoo 3000 16 mb
windows 98se
[ als die ATi er nou wat sneller was had ik mn nieuwe pc al gehad :( ]
  • Hahn
  • Laatst online: 17:09
Duidt op een brakke driver denk ik. Download gewoon de nieuwste drivers voor je Voodoo 3, volgens mij heeft Guru3D die drivers nog wel :)
The devil is in the details.
  • Black-Death
Ok, ik zal even een kijkje nemen.
Thnx Marco
Edit :: de pagina http://www.guru3d.com/files/ laadt hier helemaal niet :S. kan iemand misschien even een directe link naar de drivers geven?
[ Voor 65% gewijzigd door Black-Death op 01-03-2003 17:27 ]
  • DroogKloot
DroogKloot
depenisvanjezus
http://search.gathering.t...=12&data%5Bsearch%5D=Zoek
http://search.gathering.t...=53&data%5Bsearch%5D=Zoek
Voorstel: neem deze vraag 'es op in de FAQ, telkens dezelfde links posten gaat ook vervelen. :D
Guru3Dfiles is down!. Brakke drivers idd, kijk anders op Voodoofiles. Ik denk dat je de standaard drivers hebt, weet je niet welke drivers je hebt ga dan naar je bureaublad -> Eigenschappen ->
instellingen -> Geanvanceerd-> Adapter -> eigenschappen -> stuurprogramma, ;)
Voor je DirectX kijk je naar start -> uitvoeren en type dxdiag, daar staat als het goed is welke directx-versie je hebt.
Succes ;)
[ Voor 6% gewijzigd door Verwijderd op 01-03-2003 19:08 ]
  • Black-Death
Direct X 9
Drivers:: ik zie geen Eigenschappen bij Adapter
Maar ik heb dus wat drivers gedownload na 10 minuten wachten op elke pagina van Guru3d. Maar het blijft hetzeldfe probleem.
Download de laatste versie van OpenGL van: http://www.opengl.org/ Ik weet niet of het gaat helpen maar proberen is wel een moeite waard. ;)
http://ucguides.savagehelp.com/Quake3/displaydrivers.html lees dat eens door, first hit met zoeken op voodoo3 opengl drivers ;)
(en probeer je gebruik van :S te beperken tot MSN ;) )
