overclocken toshiba 420 CDT (p100)=mogelijk maar hoe?
  • Zandor
  • Laatst online: 24-06 23:24
maar hoe :)
Ik heb in nieuwsgroepen gelezen dat dit oude beestje probleemloos kan naar FSB 60/66 mhz ipv de standaard 50mhz....
dus van de standaard processorsnelheid 100mhz naar 120/133
Alleen is mijn vraag hoe?
Ik heb me rot gezocht op internet, maar kan het echt niet vinden hoe dit nu moet.
E8400, P5K EPU, patriot extreme 800 4GB, EN9600gt, hoontech dsp24v, samsung F1 1TB, dell 2407wfp, canon LBP5200
Canon 50D, 17-85IS, 28-135 IS, 100-300mm, 50mm 1.8
  • Zandor
kan iemand japans ??? :)
Hier staat namelijk het antwoord
http://www2.justnet.ne.jp/~toshio_h/sp420.html
  • Sick Nick
  • Laatst online: 26-10 18:29
Sick Nick
Drop the top!
Page of Satellite Pro420
This machine the based clock is the 66mhz.
As for remodelling method 2 passing, as for one the takeover of the based clock
With the method of doing and every peripheral circuit the clock raising as for this
It is the same as the GTR590 and the like. In other things the clock of CPU
With magnification ratio modification with the normal *1.5 as a *2.0 the MAX 133mhz
Of doing it is the method, the 133mhz worry as for one the based clock
Dropping into the 60Mhz, also drive is possible with the 120Mhz.
Disassembly of the machine completely is the same as the GTR590, but time fast mode
To as for modification it is necessary to start pulling the mother.
Being to be the mother of the same form it does, the GTR and this type but you remove
To being very serious, when you take in the photograph, 20 it is rank necessary being
Publication is spared. The removal of the mother does
As for one is given up the person who is good you think remodelling.
It is that rank serious, the possibility of breaking it is large.
With it publishes when the mother is removed with ゆ う thing.
It illustrates converts, being something which it does in square of the photograph above.
Immediately on side of wiring of the condenser of the C10 the one for tip/chip resistance
Being to be a pattern, the jumper it does this.
Because of this the based clock * it operates with 2 time speed.
Next is modification of the based clock, the remodelling point
The GTR590 and this type being to be the completely same on the baseplate
Concerning location you spare, as for point of difference illustration
Please refer to.
When jumper resistance is inserted in the W6 the among these, the base
The 60Mhz/90Mhz (CPU) with it becomes. In case of *2 120Mhz
Don't you think? is. When you insert in the W7 in the association, the based 50Mhz/75
The Mhz (CPU) is, with the *2 of course it is the 100Mhz.
Well it is experiment here. The jumper is inserted in both when
It moves with some Mhz, probably will be? Why, the 37.5mhz (there is an error,
CPU clock indication at time of *1.5) and the like with ゆう vague
The っ ち ゃ it was in frequency. Then as for here basic
It is about to be supposed insert tip/chip resistance, with the jumper
It moves, but for safety tip/chip resistance should be used.
From the ジヤンク baseplate resistance of 100 - the 10k you remove
You tried moving with the 133mhz, but from usually thermal rise a little
Quick ones use sufficiently it may, is, then the America TOSHIBA
Getting the FAN.ZIP with the WWW server, to one for insurance
You will use.
Hoop dat je er wat mee kan :p babelfish rulez!
  • Zandor
ja natuurlijk, babelfish ! 8)7
thanx..
nu moet ik het nog wel uitzoeken (zo goed is babelfish ook weer niet ;)) maar hiermee zou het wel moeten kunnen lukken
  • Zandor
gelukt,
loopt nu soepeltjes op 133mhz
photoshop start nu in 80 sekonden op ipv 120 ! kijk das winst :P
  • GA!S
GA!S
295 g/km
Zandor schreef op 03 maart 2003 @ 00:12:
gelukt,
En als je nu zelf ff de babblefish uit wil hangen voor de database: wat heb je nou precies gedaan? :+
de betaler vervuilt
  • Zandor
ok ok hier komt ie
moederbord helemaal demonteren, echt een rotklus..
naast de processor op de printplaat (aan de onderzijde) zit een condensor C10, goed zoeken, kleine lettertjes..
blubje soldeer op de twee kontaktjes die er vlak naast liggen. en multiplier is van 1,5 naar 2. Bordje liep op 66 mhz standaard al.
en dan.....
juist ja de hele boel weer in elkaar schroeven en klaar :)
  • GA!S
GA!S
295 g/km
sweeeeet
Er leuk, heb hier nog een 166 MMX (300 CDT) liggen. Eens kijken of we die naar 233 kunnen krijgen als ik eens een keer tijd te veel heb (vrij zeldzaam, maar het idee is leuk).
de betaler vervuilt
  • Zandor
check this!
http://www.hicat.ne.jp/home/toshio-h/sat300.html
wel ff door bablefish gooien... gaat over de 300
idd 233 schijnt goed haalbaar te zijn!
[ Voor 16% gewijzigd door Zandor op 03-03-2003 00:35 ]
  • Marctraider
  • Laatst online: 25-10 09:58
mhh zou het ook bij mijn 480CDT werken ?
ik kan niks vinden op die site want ik kan sowiezo geen japans...
die andere gast kon ook voor zijn 320cdt vinden :S
sorry dat ik deze topic weer kick by the way..
  • GA!S
GA!S
295 g/km
Erg veel verschil tussen de 320 en de 480 is er niet. Volgens mij exact dezelfde notebook onderhuids. TX chipset, yamaha sound, C&T videokaart. Allemaal precies hetzelfde.
Wat overklokken betreft: het is een 233 MMX, zit toch wel erg dicht tegen het max van die ouwe P1 core aan. Daarbij betwijfel ik dat het mogelijk is om je bussnelheid te vergroten, blijft over het opkrikken van je multiplier en of die verder gaat dan 3.5.
de betaler vervuilt
  • Marctraider
zal ik gewoon hetzelde proberen als die andere gasten ?
hoeveel % kans dat ie kapot gaat ?
  • GA!S
GA!S
295 g/km
MarcTraider schreef op 29 november 2003 @ 01:29:
Als je werkelijk denkt dat dat gaat werken dan zou ik er niet eens aan beginnen om die kast open te schroeven... Als je dat doet loopt ie namelijk op 200 i.p.v. 233....
de betaler vervuilt
