[mandrake/qt] kmess en kmerlin ./configure error
ze geven uiteindelijk allebei hetzelfde:
[root@62 kmerlin-1.2]# ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... missing
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking how to run the C preprocessor... gcc -E
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking how to run the C++ preprocessor... /lib/cpp
checking whether g++ supports -frepo... no
checking whether g++ supports -instances=explicit... no
checking for ld used by GCC... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependant libraries... pass_all
checking for ranlib... ranlib
checking for strip... strip
checking whether -lc should be explicitly linked in... yes
checking for objdir... .libs
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
finding the maximum length of command line arguments... 73729
checking if gcc supports -c -o file.o... yes
checking if gcc supports -fno-rtti -fno-exceptions ... yes
checking whether the linker (/usr/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking command to parse /usr/bin/nm -B output... ok
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
creating libtool
updating cache /dev/null
ltcf-cxx: with_gcc=no ; with_gnu_ld=no
ltcf-cxx.sh: error: problem compiling test program
checking for g++ option to produce PIC... -DPIC
checking if g++ PIC flag -DPIC works... no
checking if g++ static flag works... no
checking if g++ supports -c -o file.o... no
checking if we can lock with hard links... yes
checking how to hardcode library paths into programs... unsupported
checking command to parse /usr/bin/nm -B output... failed
checking if libtool supports shared libraries... no
checking whether to build shared libraries... no
checking whether to build static libraries... yes
appending configuration tag "CXX" to libtool
checking for msgfmt... msgfmt
checking for gmsgfmt... msgfmt
found msgfmt program is not GNU msgfmt; ignore it
checking for xgettext... :
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for main in -lutil... yes
checking for main in -lcompat... no
checking for crypt in -lcrypt... yes
checking for socklen_t... size_t
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for inet_ntoa... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for res_init... no
checking for killpg in -lucb... no
checking for int... yes
checking size of int... 4
checking for long... yes
checking size of long... 4
checking for char *... yes
checking size of char *... 4
checking for char... yes
checking size of char... 1
checking for dlopen in -ldl... yes
checking for shl_unload in -ldld... no
checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking for IceConnectionNumber in -lICE... yes
checking for libXext... yes
checking for Xinerama... no
checking for pthread_create in -lpthread... yes
checking for extra includes... no
checking for extra libs... no
checking for libz... -lz
checking for libpng... -lpng -lz -lm
checking for libjpeg6b... no
checking for libjpeg... -ljpeg
checking for Qt... configure: error: Qt (>= Qt 3.0.1) (headers and libraries) not found. Please check your installation!
For more details about this problem, look at the end of config.log.
(de install error van kmess aan het eind ziet er hetzelfde uit, met Qt)
ik heb dus wel qtlib geinstalleerd...:(
Maar waarschijnlijk libqt3-devel niet en dat zou wel eens heel goed je probleem kunnen verhelpen.
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Verwijderd schreef op 27 February 2003 @ 23:01:
Het gaat om qtlib-dev, als je iets zelf compileerd
Verder krijg ik de indruk uit de bovenstaande paar regels die ik uit je posting heb gelicht, dat je geen compiler (om precies te zijn g++(of gpp, of hoe ze dat ding ook in Mandrake mogen noemen) hebt geinstalleerd..
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • deadinspace
  • Laatst online: 09-09 13:51
deadinspace
The what goes where now?
En natuurlijk heb je ook in de FAQ gekeken? ;)
  • albiez
  • Laatst online: 16-07 22:24
Check dit topic. En geef mee in de prefix van configure
