29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
Copyright (C) 2002 Martin Bravenboer
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
package org.pandoramix.xml;
import org.xml.sax.Attributes;
import org.xml.sax.helpers.DefaultHandler;
import org.xml.sax.SAXException;
import java.lang.reflect.*;
import java.util.HashMap;
import java.util.StringTokenizer;
public class DispatchingContentHandler extends DefaultHandler
private static final Class[] START_ELEMENT_PARAMETERS;
private static final Class[] END_ELEMENT_PARAMETERS;
static
START_ELEMENT_PARAMETERS = new Class[]{Attributes.class};
END_ELEMENT_PARAMETERS = new Class[0];
private final HashMap _methods;
private final boolean _debug;
public DispatchingContentHandler()
this(false);
public DispatchingContentHandler(boolean debug)
super();
_methods = new HashMap();
_debug = debug;
protected String transformElementToMethod(String qName)
StringBuffer result = new StringBuffer(qName.length());
StringTokenizer tokenizer = new StringTokenizer(qName, "-");
while(tokenizer.hasMoreTokens())
String token = tokenizer.nextToken();
result.append(Character.toUpperCase(token.charAt(0)));
result.append(token.substring(1, token.length()));
return result.toString();
public void startElement(String namespaceURI, String localName, String qName, Attributes atts) throws SAXException
Method startElementMethod = getMethod("startElement", new Class[0]);
invoke(startElementMethod, new Object[0]);
Method method = getMethod("start" + transformElementToMethod(qName), START_ELEMENT_PARAMETERS);
invoke(method, new Object[]{atts});
public void endElement(String namespaceURI, String localName, String qName) throws SAXException
Method endElementMethod = getMethod("endElement", new Class[0]);
invoke(endElementMethod, new Object[0]);
Method method = getMethod("end" + transformElementToMethod(qName), END_ELEMENT_PARAMETERS);
invoke(method, new Object[0]);
private void invoke(Method method, Object[] arguments) throws SAXException
if(method != null)
try
method.invoke(this, arguments);
catch(InvocationTargetException exc)
System.err.println("Exception caused by method: " + method.toString());
throw new SAXException((Exception)exc.getTargetException());
catch(Exception exc)
if(exc instanceof SAXException)
throw (SAXException)exc;
else
throw new SAXException(exc);
private Method getMethod(String methodName, Class[] parameters)
Method result;
if(_methods.containsKey(methodName))
result = (Method) _methods.get(methodName);
else
result = getMethod(getClass(), methodName, parameters);
if(_debug && result == null)
System.out.println("No method: " + methodName);
_methods.put(methodName, result);
return result;
public static Method getMethod(Class methodClass, String methodName, Class[] parameterTypes)
try
return methodClass.getMethod(methodName, parameterTypes);
catch(NoSuchMethodException exc)
return null;
catch(SecurityException exc)
return null;
