linux package problemen (debian)
  • E - man
  • Laatst online: 14-11-2025
Hmm ik heb hier een distributie die afgeleid is van Debian.
ik had al het een en ander geinstalleerd met APT-GET dus daar zit het probleem niet.
Het ging fout toen ik wine wou installeren
Hier begon ik:
Asus :~# apt-get install wine
Reading Package Lists... Done
Building Dependency Tree... Done
Sorry, wine is already the newest version.
You might want to run `apt-get -f install' to correct these:
Sorry, but the following packages have unmet dependencies:
libwine: Depends: libarts (>= 4:2.2.2-1) or
libarts-alsa (>= 4:2.2.2-1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Asus :~#
Hij mist libarts dus die maar ff installeren (dit is al vaag, want normaal voldoet ie zelf aan de dependencies).
Asus :~# apt-get install libarts
The following NEW packages will be installed:
libarts
0 packages upgraded, 1 newly installed, 0 to remove and 12 not upgraded.
6 packages not fully installed or removed.
Need to get 0B/623kB of archives. After unpacking 2470kB will be used.
(Reading database ... 31759 files and directories currently installed.)
Unpacking libarts (from .../libarts_4%3a2.2.2-13.woody.5_i386.de B) ...
dpkg: error processing /var/cache/apt/archives/libarts_4%3a2.2.2-13.woody.5_i386.deb (--unpack):
trying to overwrite `/usr/lib/mcop/Arts/Synth_ADD.mcopclass', which is also in package libarts1
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Asus :~#
DPKG heeft een fout veroorzaakt, nou dan doe ik het toch zelf wel...., dus NIET :?
Asus :~# cd /var/cache/apt/archives/
Asus:/var/cache/apt/archives# dpkg -i libarts_4%3a2.2.2-13.woody.5_i386.deb
Unpacking libarts (from libarts_4%3a2.2.2-13.woody.5_i386.de ...
dpkg: error processing libarts_4%3a2.2.2-13.woody.5_i386.deb (--install):
wie kan me verder helpen *D ?
  • BOOTZ
  • Laatst online: 10-09 09:46
en wat gebeurt er als je doet wat apt-get de eerste keer al voorstelde: 'apt-get -f install' ?
Maak je eigen poll
  • E - man
hmm doet ie t ook niet, ik weet niet wat ie precies zij, maar ik heb ondertussen alweer het een en ander geprobeerd
Het komt erop neer dat libwine libarts (>= 4:2.2.2-1) or
libarts-alsa (>= 4:2.2.2-1) nodig heeft.
Maar dat is het probleem nog niet.
als ik dan de laatste versie van libarts wil installeren geeft ie aan dat ie een probleem heeft met libarts1 en dat degene is die al voor libarts zorgt
en ik kan libarts1 niet verwijderen aangezien kdelibs4, kdelibs4-bin, libarts1-qt, arts etc. ervan afhankelijk zijn.
dus ik heb geprobeerd:
Asus:~/My Documents# dpkg -i --auto-deconfigure libarts-alsa_2.2.2-13.woody.6_i386.deb
dpkg: considering removing libarts1 in favour of libarts-alsa ...
dpkg: yes, will remove libarts1 in favour of libarts-alsa.
(Reading database ... 31630 files and directories currently installed.)
Unpacking libarts-alsa (from libarts-alsa_2.2.2-13.woody.6_i386.deb) ...
De-configuring libkonq4, so that we can remove libarts1 ...
De-configuring kdelibs4-bin, so that we can remove libarts1 ...
De-configuring kdelibs4, so that we can remove libarts1 ...
De-configuring kbattleship, so that we can remove libarts1 ...
De-configuring libarts1-mpeglib, so that we can remove libarts1 ...
De-configuring libarts1-glib, so that we can remove libarts1 ...
De-configuring libarts1-bin, so that we can remove libarts1 ...
De-configuring libarts1-audiofile, so that we can remove libarts1 ...
De-configuring libarts1-qt, so that we can remove libarts1 ...
De-configuring xmmsarts, so that we can remove libarts1 ...
dpkg: error processing libarts-alsa_2.2.2-13.woody.6_i386.deb (--install):
trying to overwrite `/usr/bin/artsd', which is also in package libarts1-bin
daarna dus /usr/bin/artsd verwijderd en opnieuw geprobeerd maar precies hetzelfde bericht
  • _JGC_
  • Laatst online: 02:04
Jij gebruikt onofficiele KDE3 pakketjes en een officiele Wine. Vanaf KDE3 is libarts veranderd van naam naar libarts1 en willen wine en KDE3 niet meer samenwerken. Oplossing die je zou kunnen doen is wine met apt-get source vanuit source bouwen en in de control file de verwijzing evt aanpassen.
  • E - man
Hmm dat wordt me nog wat, ik denk dat ik wel weer iets heb om minimaal een uurtje of 2 bezig te zijn.
het eerste probleem heb ik al uitzoeken hoe die sources.list werkt :D
E: Sorry, you must put some 'source' URIs in your sources.list
_/-\o_ maar bedankt je hebt me al aardig op weg geholpen
[ Voor 15% gewijzigd door E - man op 22-02-2003 09:47 ]
  • active2
  • Laatst online: 21:19
active2
Google is your friend
deb-src ftp://ftp.debian.nl/debian stable main contrib non-free
Google, Het mirakel van de 21e eeuw!!!!
http://www.debian.org/doc/manuals/apt-howto/index.en.html
ofwel apt-get install apt-howt-en (voor het offline gebeuren)
  • E - man
Allemaal bedankt voor de hulp :D
[ Voor 15% gewijzigd door E - man op 22-02-2003 19:36 ]
