Uit die tekst word je ook niet veel wijzer
. Download
hier eens de nieuwste detonators, pak ze uit in een aparte map. Quote uit de readme.txt:
1. These drivers must be installed by a user with Windows 2000/XP Administrator
privileges. Please consult your system administrator or Microsoft
Windows 2000/XP User's Manual for more information on Administrator
privileges.
2. Start Microsoft Windows 2000/XP.
3. From the Start menu, select Settings.
4. Select Control Panel.
5. Select System.
6. Select Device Manager.
7. Under Display adapters, select the name of the NVIDIA adapter you have
installed. If you do not see a Display adapters option, or if your NVIDIA
adapter is not listed, under Other Devices, select Video Controller (VGA
Compatible).
8. Select the Driver tab.
9. Select Update Driver.
10. Select Next.
11. Select Next.
12. Verify that "Specify a location" has a check mark next to it. If it does
not, click in the box next to "Specify a location" to place a check mark
in the box. Select Next.
13. Enter the path to the NVIDIA drivers in the "Copy manufacturer's files
14. If you get a dialog box that states "A suitable driver for this device
is already installed.", click in the box next to "Install one of the
other drivers" to place a check mark in the box, then select Next.
Otherwise, select Next, then proceed to step 16.
15. Select the following driver from the list. NVIDIA RIVA TNT is used an
example; make sure to select your NVIDIA adapter from the list.
Description Provider Manufacturer Location
NVIDIA RIVA TNT NVIDIA NVIDIA a:\nv4_disp.inf
Select Next.
16. Select Finish.
17. Select Close.
18. Windows 2000/XP will ask if you wish to restart the computer. Select Yes.
Dan ga ik er ff vanuit dat je 2k/XP hebt en je een verkeerde of halve driver probeert te installeren.
