Ghost Recon crashen bij opstarten
  • MewBie
  • Laatst online: 00:05
Als ik Ghost Recon opstart crashed hij en staat het volgende in de Ikecrash.log:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
GHOSTRECON caused an Access Violation in module GHOSTRECON.EXE at 017f:0045282f.
Exception handler called in Main Thread.
Error occurred at 2/15/2003 11:47:40.
C:\PROGRAM FILES\RED STORM ENTERTAINMENT\GHOST RECON\GHOSTRECON.EXE, run by M. Bastiaan.
1 processor(s), type 586.
64 MBytes physical memory.
Read from location ffffffff caused an access violation.
Registers:
EAX=00000000 CS=017f EIP=0045282f EFLGS=00010246
EBX=01927418 SS=0187 ESP=00c7fa6c EBP=ffffffff
ECX=01927410 DS=0187 ESI=00000001 FS=4657
EDX=007d46b0 ES=0187 EDI=00000002 GS=0000
Bytes at CS:EIP:
8b 88 04 02 00 00 8b 44 24 10 8d 14 40 8d 9c 40
Stack trace:
0045282F: GHOSTRECON.EXE! <no symbol>, <no file>, <no line>
    Module list: names, addresses, sizes, time stamps and file times:
C:\PROGRAM FILES\RED STORM ENTERTAINMENT\GHOST RECON\GHOSTRECON.EXE, loaded at 0x00400000 - 4874240 bytes - 31313931 - file date is 10/1/2001 16:48:04
C:\WINDOWS\SYSTEM\D3D8.DLL, loaded at 0x00920000 - 1188864 bytes - 3dedc941 - file date is 12/12/2002 00:14:32
C:\WINDOWS\SYSTEM\DINPUT8.DLL, loaded at 0x70000000 - 196608 bytes - 3d3741e1 - file date is 10/30/2001 08:10:00
C:\WINDOWS\SYSTEM\SHLWAPI.DLL, loaded at 0x70bd0000 - 282896 bytes - 372f3215 - file date is 5/5/1999 22:22:00
C:\PROGRAM FILES\RED STORM ENTERTAINMENT\GHOST RECON\DBGHELP.DLL, loaded at 0x72a00000 - 163088 bytes - 3af32067 - file date is 8/10/2001 09:27:10
C:\WINDOWS\SYSTEM\WSOCK32.DLL, loaded at 0x75e30000 - 40960 bytes - 374aa9e9 - file date is 2/8/2003 09:17:12
C:\WINDOWS\SYSTEM\WS2HELP.DLL, loaded at 0x75e70000 - 24576 bytes - 374aa9e9 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\WS2_32.DLL, loaded at 0x75e90000 - 73728 bytes - 374aa9e9 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\WINTRUST.DLL, loaded at 0x76140000 - 57344 bytes - 374aa9e7 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\WININET.DLL, loaded at 0x76160000 - 463120 bytes - 374aa9e7 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\MSVCRT.DLL, loaded at 0x78000000 - 278581 bytes - 38c58112 - file date is 7/15/2000 00:00:00
C:\WINDOWS\SYSTEM\MSWSOCK.DLL, loaded at 0x794d0000 - 86016 bytes - 374aa9c7 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\MSSIP32.DLL, loaded at 0x79a30000 - 40960 bytes - 374aa9c4 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\MSOSS.DLL, loaded at 0x79e60000 - 151552 bytes - 374aa9c3 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\RSABASE.DLL, loaded at 0x7ca00000 - 94480 bytes - 36275822 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\IMAGEHLP.DLL, loaded at 0x7cd80000 - 114688 bytes - 374aa9b0 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\CRYPT32.DLL, loaded at 0x7edd0000 - 385024 bytes - 374aa9a4 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\RPCRT4.DLL, loaded at 0x7fb90000 - 339968 bytes - 374aa99c - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\OLE32.DLL, loaded at 0x7ff20000 - 790528 bytes - 374aa99b - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\NTDLL.DLL, loaded at 0x82d74000 - 20480 bytes - 3546ab93 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\DDRAW.DLL, loaded at 0xbaaa0000 - 358400 bytes - 3dedc926 - file date is 12/12/2002 00:14:32
C:\WINDOWS\SYSTEM\DSOUND.DLL, loaded at 0xbeaf0000 - 457728 bytes - 3dedc967 - file date is 12/12/2002 00:14:32
C:\WINDOWS\SYSTEM\WINMM.DLL, loaded at 0xbfdf0000 - 65536 bytes - 374aa99a - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\VERSION.DLL, loaded at 0xbfe70000 - 24576 bytes - 374aa999 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\ADVAPI32.DLL, loaded at 0xbfe80000 - 65536 bytes - 374aa999 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\GDI32.DLL, loaded at 0xbff20000 - 155648 bytes - 353ec272 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\USER32.DLL, loaded at 0xbff50000 - 69632 bytes - 374aa999 - file date is 5/5/1999 22:22:00
C:\WINDOWS\SYSTEM\KERNEL32.DLL, loaded at 0xbff70000 - 475136 bytes - 371fc2b4 - file date is 5/5/1999 22:22:00
kan iemand mij vertellen wat deze melding ongeveer inhoud?
ik zat zelf te denken aan te weinig intern geheugen, maar ik kan dat verder niet testen omdat dit de enige comp in huis is met SDRAM geheugen.
Please leave a message after the beep.
*beeeeep*
  • Rafe
  • Laatst online: 27-06-2025
Even je specs vermelden, niet iedreen heeft signature's aanstaan op het forum.
Uit je error rapport ("64 MBytes physical memory.") kan ik zien dat het om deze PC gaat, klopt dat?
Vertel ook even om welke windows versie het gaat, welke driver versies je van je hardware heb, dat soort dingen.
Heb je ook de laatste patch geinstalleerd?
  • MewBie
Rafe schreef op 15 February 2003 @ 11:56:
Het klopt idd dat het deze PC is, heb ook maar ff alle specs geupdate (klopte niet meer) en het is dus W98SE. En als ik de laatste patch installer doet ie t helemaal niet meer, zelfs niet op een computer waar hij het nu wel gewoon doet.
*beeeeep*
  • Hahn
  • Laatst online: 17:09
Wil je met die PC een server draaien? Want GR gaat echt niet normaal draaien op de PC hoor ;)
Hoe crasht ie eigenlijk? Hij springt gewoon terug naar Windows of krijg je misschien een error?
Als er een command is om GR zonder GUI te laden zou ik kijken of het daar mee lukt :)
The devil is in the details.
  • MewBie
Ik draai nu ook spellen op die computer waar ik niet van dacht dat ze het deden, NFS5 op 800*600 met alles op zn hoogst bijvoorbeeld, en of het mogelijk is om zonder GUI te draaien weet ik niet.
En de foutmelding is gewoon een ongeldige bewerking met zo ongeveer de tekst als in mn eerste post
[ Voor 22% gewijzigd door MewBie op 15-02-2003 14:16 ]
*beeeeep*
