Windows start maar niet op...
Ik heb hier een Packard Bell Platinum pc die al 2 jaartjes oud is.
Specs:
Video:
Leadtek WinFast 3D S320 II TNT2 Pro 32 MB videocard + TV-out
Name: WinFast 3D S320II (also referred to as TNT2 Pro video board)
Type: 2D/3D accelerator card
Manufacturer: Leadtek
Sub: TV-Out connector 6-pins S-video/RCA
Display Properties For The WinFast 3D S320 II Graphics Card
Sound:
Aztech PCI 288 Q3D II sound card
Name: AZTECH PCI 288-Q3D II
Type: PCI sound card
Manufacturer: AZTECH
Sub: Aztech PCI 288 Q3D II Sound Card Cables And Connectors
Core:
Saturn (Phoenix+) MS-6309 ATX form-factor motherboard
Internal name: Saturn (MS-6309)
Marketing name: Phoenix+
Type: ATX motherboard
Manufacturer: MSI
Sub: Saturn Motherboard BIOS Setup Screens
Saturn Jumpers and Connectors
Storage Components:
HDD 15 GB Quantum LB15A LCT10 UDMA66 5400rpm
Name: Quantum LB15A LCT10
Type: IDE Hard disk UDMA66 5400 rpm
Manufacturer: Quantum
DVD 10x/40x Pioneer 114FW
Pioneer 114FW 10x/40x DVD
Sub: Troubleshooting
Pioneer 114FW DVD Connections
Pioneer 114FW DVD Jumpers
Philips CDD4401 CD-R / CD-RW Drive
Product name: CDD4401
Type: 4x CD-R / CD-RW Writer, 32x CD-ROM Player
Manufacturer: Philips
Modem :
Aztech MSP3880-W Modem Board
Name: MSP3880-W Modem Board
Type: data/fax modem board
Manufacturer: Aztech
Network Network card:
ACCTON EN1207D-TX4 PCI LAN Board
Name: EN1207D-TX4 LAN Board
Type: LAN Adapter PCI Card
Manufacturer: Accton
Sub: Setup, Configuration And Diagnose Utility For The AcctonEN1207D-TX4 Network Interface Card
Casing:
Gulliver 2 chassis
ATX mini tower case
Sub: Gulliver 2 chassis upgrade information
Interface card :
Askey SD10-D82 IEEE1394 (FireWire)
Type: IEEE1394 (FireWire) PCI add-in card
Manufacturer: Askey
bron: http://support.packardbel...MySupport&cat=PRI&lang=6&
Probleem?
Sinds vorig maand is hij constant aan het rebooten. Dus nadat de BIOS zijn zaakjes heeft gedaan en de windows startup scherm(winlogo met zwarte achtergrond + "loading-bar" " verschijnt, dan start ie opnieuw op.
Ik dacht...OK, HD naar de klippen, dus maar een nieuwe.
Ik heb er een nieuwe HD erin gegooid, Win XP erop geïnstalleerd en nadat windows al zijn files gekopiëerd heeft naar de schijf en de pc opnieuw start om de installatie te beginnen, dan geeft ie dezelfde fout. Hij geeft de "loading-scherm" en daarmee houd het op.
Ik dus denken...OK, BIOS maar updaten. Dat ook gedaan en ja hoor, hij blijft het nog steeds doen.
Ik heb alle hardware eruit gegooid behalve de HB, MB, videokaart en DVD-ROM. Nog steeds geen succes...
Ik heb zitten proberen met 3 harde schijven en geen van ze schijnt het beter te doen.
Ik heb van alles mogelijk uitgeschakeld wat te maken heeft met Stroombeheer in de BIOS, maar dat baat ook niet.
Ik heb de videokaart in een andere pc gegooid om hem te testen, en die doet helemaal poeslief.
Dus...kan iemand me zeggen wat ik over het hoofd zie?
Of mag ik mijn MB aan mijn hond geven om ermee te spelen, wat ik ben min of meer van overtuigd dat het daaraan ligt?
En owja, ik heb win2000pro ook uitgeprobeerd...zonder succes ;(
Het enigste wat ik wel opmerkte wat dit:
Ik heb een CDrewriter en een DVD-Rom erin liggen op dezelfde IDE-kabeltje.
Als ik nou de CD-Rew uitschakel, dan zie ik mijn log-in scherm 3 seconden langer.
Maar met beide aangesloten zie ik die log-in scherm maar 1 seconde.
Maar in beide gevallen start de pc weer opnieuw op.
In de opstartvolgorde van de BIOS maken de verschillende combinaties ook niets uit.
HIJ BLIJFT MAAR IN EEN OPSTART-LOOP...EN HET IRRITEERT ME AL 3 WEKEN LANG.
Wie kan mij misschien nog een paar hints geven?
  • bazs2000
  • Laatst online: 17-09 22:41
bazs2000
Pixels zo groot als een atoom
Ik heb laatst een dergelijk probleem gehad, dit bleek een rotte geheugenmodule te wezen. Memtest kon geen fouten ontdekken maar nadat ik deze module had vervangen werkte mijn systeem weer. Een defecte HD leidt maar zelden tot jouw probleem, defect geheugen kan voor dit soort rare toestanden zorgen. :)
Krankzinnige muziek vind je hier.
